RV.Net Open Roads Forum: Tech Issues: Egos
 > Egos
Page of 7
travellerz71
Graniteville
Posted: 07/11/12 12:55pm Link  |  Quote  |  Print  |  Notify Moderator
I refuse to have a battle of wits with an unarmed person.
mangler
Calgary, Alberta, Canada
Posted: 07/11/12 01:14pm Link  |  Quote  |  Print  |  Notify Moderator
These forums encourage higher numbers of posts - even by the definition of " new members" etc. it should not take 50 posts to lose new member status (said the new member who joined in '04. You should be a "member" after a few useful posts, and a full or senior member after many helpful posts. Add a feature so members can declare a post was helpful, and then add up how helpful folks are being. It would be good to know at a glance how helpful other members consider a poster.
Encourage the right behaviour.
Maybe soon I will be a real member :-(
Travelling with the wife and two kids (16and14)...
5th: '08 Colorado 29BHDS (10-11,000 lbs wet)
TV : '04 Chevy Silverado 2500HD Duramax/Allison Crew Cab
mangler
Posted: 07/11/12 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
Oops - that post put me over - only took 8 years. Do I have to take back what I said?
bpounds
Whittier CA
Posted: 07/11/12 01:44pm Link  |  Quote  |  Print  |  Notify Moderator
Some people don't accept disagreements well. Just because someone disagrees with you, and tells you so, doesn't make them a know-it-all. They have as much right to their opinion, and the right to defend it, as you do.
And none of us are immune to this illness:
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
TEXAS
Centerville Tx
Posted: 07/11/12 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
2oldman wrote:
TEXAS wrote:
p people that will not post the model and serial number.
Of what value is a serial number ?
The full model and serial number.
Will tell me when it was made.
What options it left the factory with.
What print I need for checking things out.
What readings I should look for. When checking each item.
Which manual to look for.
What performance specs to look for.
Most of all.It tells me that I am looking at the same unit. That the customer is asking about. So that I don't give out the wrong answer and put someone in danger.
That is what it is good for.
2oldman
Winchester WA
Posted: 07/11/12 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
I'm sure in some cases the Ser# is relevant. But for portable generators, inverters, batteries, TVs, pumps.... and the like, it's not. I guess it depends what product we're talking about.
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 07/11/12 06:35pm Link  |  Quote  |  Print  |  Notify Moderator
Never argue with an idiot
They'll drag you down to their level then beat you with experience
-Mark Twain
dougrainer
Carrolton, Texas
Posted: 07/11/12 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
The MAIN thing is, You can NEVER post too much info if YOU want your problem fixed. To put it in perspective from a Experianced RV Tech---My RV will not start, WHAT is the problem??? You know what, there will be 20 posts in 2 days on what people think is the problem and NONE have any idea what they are talking about. Because there is NO info on what the problem is and NO facts on Year/Model/Brand and what it does NOT do. I LIKE to help, but I HATE when I post to the OP, post the Brand/Year/Model/ appliance Model and S/n and they NEVER respond, but do respond to other posts that are way out there on a supposed fix. Doug. Below is a current post that proves my case.
"I have searched all over the van and have found breakers but no fuses. I flipped the breakers back and forth (all were turned on, including the breaker found on the generator itself) and the microwave kicked on. So, assuming it was fixed, I head out camping and go to turn the AC on and and nothing. I flipped the breakers back and forth and nothing happens this time...
Being that this is an intermittent problem do you guys think I have a loose wire somewhere? If this does not work I am considering taking it to an RV shop, but I really really dont want to do that!
Am I missing a fuse box somewhere? "
daverich
Sharps RV Park in St. Joseph, MO until April 30.
Posted: 07/11/12 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
tkcas01 wrote:
Some people just thrive on conflict and argument - it is a game for them. The rest of us can just roll our eyes and ignore them, else we wallow in the muck with them.
Well said.
JC2
Mo
Posted: 07/11/12 07:52pm Link  |  Quote  |  Print  |  Notify Moderator
daverich wrote:
Well said.
I agree also. When someone gets to the point of being an annoyance, I click on their name and block receiving any further posts. Works everytime.
* This post was edited 07/12/12 07:59am by JC2 *
2004 Newmar DSDP 4015,370hp Cummins ISL,Spartan MM Chassis,2008 Saturn Vue,FMCA #402879,NKK 19776
Page of 7
 > Egos
