RV.Net Open Roads Forum: Truck Campers: Leaking Hot Water Heater
 > Leaking Hot Water Heater
Nevrdun
Smethport, PA
Posted: 07/11/12 04:32am Link  |  Print  |  Notify Moderator
I have and '05 Lance 1030 and discovered when filling my hot water heater for the first time this year that it leaks from the drain plug. This is a new plug and I have not tried wrapping the threads of the plug yet. Any thoughts are greatly appreciated.
May I become the person my dog thinks I am
frank-2
Ontario
Posted: 07/11/12 04:57am Link  |  Print  |  Notify Moderator
Mine leaked also I wrapped it and it stopped but yesterday I put a new plug-in and as of right now there is no problems
hallock5
Posted: 07/11/12 06:07am Link  |  Print  |  Notify Moderator
I tightened mine snug, so far OK for a week.
2008 Jayco Eagle Superlite 28.5RLS
2002 Ford 4x4 SuperCab 7.3 (Jr International) Diesel
Sad to say, time to sell to a good home.
naturist
Lynchburg, VA
Posted: 07/11/12 06:10am Link  |  Print  |  Notify Moderator
That's what teflon tape is for: use it, no problems. If, however, you have a plastic plug, they can be tightened enough to stop leaking. If the plastic plug still leaks after you tighten it enough to worry it'll strip, then it needs to be replaced.
Dogbone
Ontario Canada
Posted: 07/11/12 06:27am Link  |  Print  |  Notify Moderator
Changed my plastic one to a brass one with the drain valve builtin, no problems now, teflon tape it also.
2007 5th Wheel Crossroads Cruiser 30SK
2003 Ford F250
69 Avion
Phoenix, Arizona
Posted: 07/11/12 07:28am Link  |  Print  |  Notify Moderator
I changed mine out to a drain valve with built in sacrificial anode.
Ford F-350 4x4 Diesel
1988 Avion Triple Axle Trailer
1969 Avion C-11 Camper
stevenal
Newport, OR, USA
Posted: 07/11/12 08:36am Link  |  Print  |  Notify Moderator
I find the aluminum threads corode. I chase the threads with a tap before installing the plug with both PTFE paste and teflon tape.
'18 Bigfoot 1500
Torklifts and Fastguns
'17 F350 Powerstroke Supercab SRW LB 4X4
narcodog
Georgia
Posted: 07/11/12 09:29am Link  |  Print  |  Notify Moderator
He has an Atwood, plastic is the one recommended. No anode rods, not needed.
I carry an extra plug and tape with me just in case. I always use tape and have had no problems yet.
fla-gypsy
North Florida
Posted: 07/11/12 11:06am Link  |  Print  |  Notify Moderator
Not a TC but I am still using the same 7 yo plug that came with mine. I wrap it with teflon tape each time I remove it.
This member is not responsible for opinions that are inaccurate due to faulty information provided by the original poster. Use them at your own discretion.
Nevrdun
Smethport, PA
Posted: 07/12/12 10:15am Link  |  Print  |  Notify Moderator
Thanks all, very helpful!
