carpetguy2
N.IL
I know there people going to say why a lifted truck.I been towing rvs all the time with lifted trucks and never a issue.My rig now is a 07 cc lb 8"lifted running 35x17 of course lbz diesel.
Looked at the new Vengeance toy hauler 40ft. Dealer said my bed rail measures at 63" to the ground.
They said it might work but I can put a lift on the trailer.Any one heard of this And being safe.Being top heavy.
I tow a 35 ft tt about 11k lbs empty.Itialian wife puts in 3k of food and crap
2007 chevy 3500 ltz CC LB Duramax
2010 Sandpiper 345 RET
2011 Harley Ultra limited
20 ft Searay 190 Seville
johnrbd
San Joaquin Valley
After lifting the trailer, you should be able to install storage bins underneath and have your wife store all her food and "Lucy's bolders" there. Than would help to help center of gravity down - a little.
Maybe additional fresh water/gray/black water tanks also.
Hurricane Owner
Riverside
Alot of the off roaders lift their trailers for the needed clearance off road. See lots of lifted trucks and 5ers out here in Cali. Haven't really noticed any problems.
rhagfo
Portland, OR
Most suggest a frame and spring shop. You are likely looking to lift the 5er about 6" to 8", best way is to add a sub frame at the wheels with the correct lift. This is usually done with 2"Xx" thick wall steel tubeing.
Russ & Paula
The Beagles Hedwig and Precious.
Portland, OR.
2005 Copper Canyon 293 FWSLS
2001 Dodge 2500 4X4, 5.9 Cummins 5 speed, 3.55 gears, Pacbrake, Power Puck, 258K
Dave&Monica
Ontario
rhagfo wrote: Most suggest a frame and spring shop. You are likely looking to lift the 5er about 6" to 8", best way is to add a sub frame at the wheels with the correct lift. This is usually done with 2"Xx" thick wall steel tubeing.
That should give you enough room to put 35x17 on the camper too! Should make it a real entertaining to tow in a big crosswind.
Good luck with your set-up...
Dave
2010 Rockwood 8280WS
2008 F250 CC Lariat SB 6.8L V10
SoCalDesertRider
SanDiego, CA, USA
rhagfo wrote: Most suggest a frame and spring shop. You are likely looking to lift the 5er about 6" to 8", best way is to add a sub frame at the wheels with the correct lift. This is usually done with 2"Xx" thick wall steel tubeing. Yep, subframe is the proper way to lift a trailer.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
SoCalDesertRider
SanDiego, CA, USA
carpetguy2 wrote: I know there people going to say why a lifted truck.I been towing rvs all the time with lifted trucks and never a issue.My rig now is a 07 cc lb 8"lifted running 35x17 of course lbz diesel.
I tow a 35 ft tt about 11k lbs empty.Itialian wife puts in 3k of food and crap Do you feel your lifted truck is safe? Your lifted trailer will be similarly safe/unsafe as your truck. Whatever your comfort level is will dictate what you do. Or, you can lower the truck back down to stock height and put some smaller tires on it....
retired-tech
flint mi
my biggest question would be how you can lift a 13'4" tall rig another 8". that would make it 14' tall. just a bit over the fed limit and a problem when towing in MI anyway.
2000 K3500 CCLB DRW 6.5 TURBO
2009 Cougar 320 SRX
2007 atlas 24 auto hauler
1987 GMC origional low miles
carpetguy2
N.IL
By no means would I want to jeaporized any one including self or family.I was concerned aswell of being top heavy.Was just seeing if it has been done and being safe.
My trucks are the way I like them and and I like to go to car truck shows with it.
edited 07/12/12 07:47am by an administrator/moderator *
jimmyfred
Tx
SoCalDesertRider wrote: carpetguy2 wrote: I know there people going to say why a lifted truck.I been towing rvs all the time with lifted trucks and never a issue.My rig now is a 07 cc lb 8"lifted running 35x17 of course lbz diesel.
.............Common sense , once again may preveil ! , jf
2003 Chevy 8.1 Dually 2Wdr.
1999 Travel Supreme , 33 RLSS
20K Reese , Prodigy etc.
