Sean32
Brampton Ontario Canada
Searched, no luck.
The rig has a female quick-connect propane port with shut off and dust cap. The rig's cooker has the male nipple to insert into. The regulator is at the tank, front left corner of the treller.
Bought a BBQ. It has a 3ft hose, regulator in the hose, and a standard QQC connection for a tank connection.
I would like to be able to connect this BBQ to the low pressure/quick connection on the trailer,but not have to disconnect the cooker.
I want to: replace the hose on the BBQ with a 10ft'er, nipple on one end, female on the BBQ end with a new BBQ controller valve with nipple on the BBQ end. I found this at Camco, part number 57609.
I still need some way to T off the rig's female port- either a brass T, or Y, with 1 nipple (male), 2 female quick connects (I cannot find that anywhere). OR, get a licenced tech to create a T using short hoses, with a nipple on the end of a 6" piece, a splitter in the middle, then 2 other 6" hoses each with a female connection on its ends.
Any ideas/help?
2009 F150 4x4 Platinum with Max Tow, Pullrite 12K slider with pins, 2010 Keystone Cougar 27SAB with aluminum rims, remote, and Polar
Francesca Knowles
Port Hadlock, Washington
The tee in this kit attaches between the regulator and the tank. The extra connection is for campstove/lantern-type connections. I'm not sure what you mean by a "QQC" connection, but you might need an adapter with this setup...
Link
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
Sean32
Francesca Knowles wrote: The tee in this kit attaches between the regulator and the tank. The extra connection is for campstove/lantern-type connections. I'm not sure what you mean by a "QQC" connection, but you might need an adapter with this setup...
Link
Sorry- fat fingers- I meant QCC.
This solution would require a 20+ ft propane hose to go from the tank/this T, which is front left, to the back right corner where the rig's cooker is. Something that I wanted to avoid.
Thanks for the reply.
geysergazer
On the Road for a year or two or....
You cannot do what you want to because your Grill operates on high pressure. That is why it came supplied with it’s own high pressure regulator. 11” WC is all that is available at the trailer's outside quick-connect. You will need to do something like what I did:
Lew
jhab03
Parts Unknown
geysergazer wrote: You cannot do what you want to because your Grill operates on high pressure. That is why it came supplied with it’s own high pressure regulator. 11” WC is all that is available at the trailer's outside quick-connect. You will need to do something like what I did:
Lew
What are the parts you used here? I have the same BBQ and want to do the same set up but have been confused as to what fittings I would need.
James
BarneyS
S.E. Lower Michigan
James,
Here is a close up view of what he did. Looks to me like he just used the Extend A Flow or something very similar. It looks like a T is connected between the top tank and before the regulator. He also has a tank pressure gauge there.
Barney
edited 07/14/12 06:47am by BarneyS *
Hensley "Arrow" 1400# hitch
2002 Ford F250 Super Duty, 7.3L PSD
Visit our website here
geysergazer
There are some more PICs and an explanation on our Blog:
http://traveldolphin.blogspot.com/2012/04/more-cooking-power.html
I started with this thing and disassembled it:
Then I installed a 1/4”NPT brass Tee between the Pigtail and the Regulator:
I can only Post 640X480 PICs here (to not hog bandwidth on a busy Forum) but if you go to the PICs on our Blog and click twice you’ll get big images wherein you can clearly see what I did. It’s one of those occasional simple ideas that actually works.
Yes, I did in effect create an ‘Extend-a-Stay’ but with an Acme connection on the third leg.
Lew
jhab03
Parts Unknown
Thats exactly what I needed to see.
Thanks
Sean32
My bbq is low pressure, so my solution will work.
I see a regulator at your bbq, are you sure your bbq isn't low pressure as well?
If so, the regulator, in our local code anyways, MUST be at the source, or, tank. This way, if there is a hose leak, it would be low pressure gas escaping, not high pressure.
geysergazer
Both ‘high pressure’ and ‘low pressure’ Propane grills require regulators. A ‘high pressure’ grill like the Coleman Roadtrip I have has a regulator on it’s inlet line that sets the pressure at 15~16PSI. A ‘low pressure’ appliance, be it a furnace, stove or Grill, uses Propane at 11”WC (a little less than 1/2PSI).
Lew
