RV.Net Open Roads Forum: Wet front wheel bearings - Workhorse 22
 > Wet front wheel bearings - Workhorse 22
Lobstah
Northeast
Posted: 08/10/12 05:03am Link  |  Quote  |  Print  |  Notify Moderator
Interesting. My sight glass has a black circle on it that is about 1/2" in from the outer edge. That puts the line about 1/2" below the center of the glass, or 1/2" above. My understanding is the bottom of the sight glass is the reference point. Mine has been overfilled since I bought it, over 3yrs ago, and never caused an issue until about 2mos ago. Since then I've been monitoring it more closely, and it has yet to drop below the bottom line on the sight glass.
Jim
2005 Pace Arrow 36D
Very Understanding Wife
2 Boxers
4 Cats
rgatijnet1
Posted: 08/10/12 05:48am Link  |  Quote  |  Print  |  Notify Moderator
Daboo wrote:
rgatijnet1 wrote:
Daboo wrote:
Hate to beat a dead horse, butttttt, the circle around the cover.the circle is the "minimum level" according to the inprint on the cover...so that tells me that is as low as the level should be...I will it keep it just below the rubber plug..wish Workhorse was still alive, so I could talk to a rep...so many answers on this forum
I assume that you don't like to use the Workhorse owner's manual, do you? It clearly says to add oil to bring it UP TO the level mark on the sight glass. It DOES NOT say fill it above the level mark. It DOES NOT say fill it up to the rubber plug. You can interpret things any way that you like but don't add words to what the Workhorse owner's manual clearly says.
I did read the manual and it says not to let the oil get below the minimum line around the cover...it doesn't say anything about a level mark, and there is no level mark on the sight glass...the mark on the cover is the minimum level..so many answers....soooooo
My Workhorse Manual W0004539A manual says fill to "level" and also has a picture. No question at all what the correct amount of oil is.
Daboo
Texas Panhandle USA
Posted: 08/10/12 07:17am Link  |  Quote  |  Print  |  Notify Moderator
oh well..what page of the manual are you looking at..
Served proudly 1957-1965..U.S. Air Force
rgatijnet1
179
Wherever I happen to park
Posted: 08/10/12 07:22am Link  |  Quote  |  Print  |  Notify Moderator
Regarding "Wish workhorse was still around..."
They are, Just a name change is all, Navistar. if I have spelled it correctly.
And Monaco (Again spelling?) is still around, you may not have heard but Navistar changed their name to the parent as well.
chili's trip
Full time
Posted: 08/10/12 08:34am Link  |  Quote  |  Print  |  Notify Moderator
Daboo wrote:
still there is no firm answers...so many different answers and no Workhorse to talk to..guess I will keep it where it is....good day and have a great one
Have you looked at your Workhorse chassis guide as has been suggested? Try looking under front wheel bearings and you will find a picture. Good luck.
Jack H
2005 Fleetwood Bounder 32W 8.1.
2009 Honda Fit Sport
