RV.Net Open Roads Forum: Wet front wheel bearings - Workhorse 22
 > Wet front wheel bearings - Workhorse 22
wolfe10
Posted: 07/17/12 05:20pm Link  |  Quote  |  Print  |  Notify Moderator
Park the coach on LEVEL area. Let it sit for 10 minutes so oil level stabilizes.
Verify that oil is to the FULL ring on the clear plastic outer cover. Not over or under.
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
Daboo
Texas Panhandle USA
Posted: 07/28/12 02:32pm Link  |  Quote  |  Print  |  Notify Moderator
there is no "full" mark on my bearing covers...it is a circle around the outside of the plastic...I called workhorse and was advised that they quit giving out tech info..I recently installed new covers///easy job..then I filled them to the bottom of the rubber plug...I have got so many answers to the question of what level the oil should be, that I plan on keeping the oil level at the bottom of the rubber plug...could not find any specs or instructions on the fill level....good motoring to you and yours
Served proudly 1957-1965..U.S. Air Force
Tom_Anderson
Concord, CA
Posted: 07/28/12 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
If the oil is at the bottom of the plug, it's too full. It needs to be at the circle below the plug. Think of the circle as a line. It's only circular so that part of it will always be at the bottom, allowing you to check the oil level. It doesn't mean the oil level should be "inside" the circle.
Tom_Anderson
Concord, CA
Posted: 07/28/12 06:42pm Link  |  Quote  |  Print  |  Notify Moderator
By the way, Workhorse doesn't make seals. So even the OEM seals are going to be "aftermarket". I wouldn't use a cheap, no-name seal, but a National, CR, or Stemco will be perfectly fine (talking about the inner seal here).
JackMS
Gulfport
Posted: 07/28/12 08:35pm Link  |  Quote  |  Print  |  Notify Moderator
A turkey baster works great to get the oil to the right level. Just don't reuse it for the turkey.
Not sure what your cover seal is made of, but if it is thick rubber, make sure it is not over tightened. It should be even with the cap all around, not bulging out.
2005 Holiday Rambler Neptune 34pdd, Cummins ISB 300, Allison 2500MH, Onan 8.0QD
Toad-2001 Chevy 2500 CC 4WD
Toad-2012 Honda CRV, Blue Ox Aventa II
Daboo
Texas Panhandle USA
Posted: 08/07/12 11:47am Link  |  Quote  |  Print  |  Notify Moderator
still there is no firm answers...so many different answers and no Workhorse to talk to..guess I will keep it where it is....good day and have a great one
Daboo
Texas Panhandle USA
Posted: 08/09/12 10:03am Link  |  Quote  |  Print  |  Notify Moderator
Hate to beat a dead horse, butttttt, the circle around the cover.the circle is the "minimum level" according to the inprint on the cover...so that tells me that is as low as the level should be...I will it keep it just below the rubber plug..wish Workhorse was still alive, so I could talk to a rep...so many answers on this forum
rgatijnet1
Posted: 08/09/12 10:20am Link  |  Quote  |  Print  |  Notify Moderator
I assume that you don't like to use the Workhorse owner's manual, do you? It clearly says to add oil to bring it UP TO the level mark on the sight glass. It DOES NOT say fill it above the level mark. It DOES NOT say fill it up to the rubber plug. You can interpret things any way that you like but don't add words to what the Workhorse owner's manual clearly says.
sundancer268
Charlevoix
Posted: 08/09/12 01:05pm Link  |  Quote  |  Print  |  Notify Moderator
When buying a used coach the manual is not always there and sometimes impossible to replace. I ran into that with a couple of used vehicles.
U. S. Navy (RETIRED) 1993
1995 Gulf Stream Scenic Cruiser 34' Diesel Pusher Cummins B5.9 12 Valve Engine, Allison MD-3060 6 Speed Transmission.
TOAD: 2005 Ford Focus Automatic Station Wagon
Road Master Sterling All-Terrain
Daboo
Texas Panhandle USA
Posted: 08/09/12 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
I did read the manual and it says not to let the oil get below the minimum line around the cover...it doesn't say anything about a level mark, and there is no level mark on the sight glass...the mark on the cover is the minimum level..so many answers....soooooo
