RV.Net Open Roads Forum: Tow Vehicles: Diesel Owners change your fuel filter OFTEN
Search only in Tow Vehicles
 > Diesel Owners change your fuel filter OFTEN
Page of 5
ScottG
Bothell Wa.
Posted: 07/12/12 01:34pm Link  |  Quote  |  Print  |  Notify Moderator
The link doesn't work unless your willing to join and log in.
So what does it look like? It's common for diesel FF's to turn black from the asphaltane (sp?) in the fuel and causes no issues at all but it does make the filter look terrible.
Scott, Grace and Wesly
H0NDA eu2000i
coolbreeze01
Redding, Ca
Posted: 07/12/12 01:37pm Link  |  Quote  |  Print  |  Notify Moderator
Could rain water be getting in the fuel at the station or bulk plant?
2008 Dodge 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2007 Komfort 212 on 225 75R 15E Maxxis ST Tires.........
chevor
US/Canada
Posted: 07/12/12 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
I go 20 to 25,000 on fuel filters.
2010 Gmc 2500 Duramax,1ton rear springs, 90g box tank, 0ver 495,000 Odometer miles, 20k Curt fifth wheel, 18k Curt rear mount hitch. Cobra CB/Weather Radio, Bridgestone Duravis R500 HDs Rancho 9000 Shocks, Firestone Airbags, bypass oil filter, Fass 95HD
georam1
Clanton, Alabama
Posted: 07/12/12 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
I joined in 2007 and am signed in. I don't know about the rain water. I'm going to change service stations and see. I'm new to diesels and some have said this is normal. Don't know.
George, Tracey, Katelyn and Colby Ramsey
2008 Jayco Eagle 31.5FBHS Superlite 5th Wheel
2003 Chevy 2500HD 6.6l DMAX
DutchmenSport
Between Anderson, Pendleton, & Lapel, Indiana
Posted: 07/12/12 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
Don't know if it's needed or not, but I change fuel filters and oil filters every oil change (about every 5000 plus miles). Might cost a little more, but it only takes once to regret being cheap. I spent a lot (did I say a "lot ... I mean "I spent a LOT of money) when purchasing that truck. I'm not going to take the cheap route now with on-going maintenance!
DutchmenSport
2005 Chevy Silverado 3500 Dually Duramax 6.6L V8 Turbo
Century Truck Cap Commercial /Toolboxes
Northeast Outfitters Canoe
2006 Keystone Springdale Model 263DBL
Weight 4985, Carrying Capacity 2575, Hitch 560, Length 30'
Width 8', Height 10' 6"
Big Ray
Posted: 07/12/12 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
I was told to change mine every 15,000 miles. Is that a good idea?
2011 Rockwood 8314BSS Signature
2011 Ram 2500 crew cab SLT 4X4 with the 6.7 High Output Cummins
mtofell1
Oregon
Posted: 07/12/12 02:59pm Link  |  Quote  |  Print  |  Notify Moderator
I go by the DIC (which does factor in how the truck is being driven) and usually change at about 20% which is usually right around 10K miles. If I'm towing a lot it's closer to 8K or so.
coolbreeze01
Redding, Ca
Posted: 07/12/12 04:45pm Link  |  Quote  |  Print  |  Notify Moderator
Every 15K is recommended and works fine unless you happen to buy fuel heavily contaminated with water. It is recommended to drain a little fuel from the bottom of your fuel filter once a month. I drain into a clear container so I can see the water, if any is present.
Hannibal
Gas Station
Posted: 07/12/12 04:50pm Link  |  Quote  |  Print  |  Notify Moderator
If the filter is coffee black, that's normal. If it has barnacles growing on it, change interval needs to be shortened. I changed mine every 15k on my Cummins Rams.
'10 F250 XLT CC SB 5.4L 5spdTS 3.73
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins; '05 Hemi
'07 KZ Jag 28JFSS.
georam1
Clanton, Alabama
Posted: 07/12/12 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
Well with an 03 Dmax and the known injector problems with the LB7 engine I would rather change the filter every 5000 miles than replace the injectors. Not saying that I won't ever have to, but just want to get as much life out of them as I can.
Page of 5
