RV.Net Open Roads Forum: Class A Motorhomes: Need Brakes
 > Need Brakes
Norm & Deb
Brown Co. Indiana
Posted: 07/12/12 01:52pm Link  |  Quote  |  Print  |  Notify Moderator
My 2002 Monaco Knight needs brakes, rotors, calipers, pads, etc. Large truck place in Indy having trouble finding out what kind of brakes are on it so they can order replacement parts. They contacted Monaco, but no help there up to this point. Monaco is supposed to be still checking and call us back. That was 3-4 days ago. Anybody know anything about these brakes, or who to contact for part numbers for replacement brake parts.
Norm
2001 Monaco Knight 38' DP Triple Slide
2001 4WD Blazer in back
"Everything I will ever tell you will be 100% the truth, or would be 100% the truth if it actually happened."
Norm & Deb
Brown Co. Indiana
Posted: 07/12/12 01:53pm Link  |  Quote  |  Print  |  Notify Moderator
Ammend that, its a 2001 Monaco Knight.
C-Leigh Racing
Nashville NC
Posted: 07/12/12 03:17pm Link  |  Quote  |  Print  |  Notify Moderator
Need to know which chassis you have under the coach, then it will be easy finding parts.
Neil
mscamping
any place, USA
Posted: 07/12/12 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
Bosch, would be my thoughts..Mike M..
2003 Holiday Rambler Neptune 36 PBD - ISB 300 Cummins- Allison MH2000 5 speed
2009 HHR w/Blue Ox Aventa II & SMI Stay-n-Play Duo
FMCA 331658 HRRVC 105155 Chapter - 57- Good Sam Life Member - Coach Net - 3/4 timers
Mike & Sharon
SCOMP225
Brownsburg,Indiana
Posted: 07/12/12 07:07pm Link  |  Quote  |  Print  |  Notify Moderator
Who's doing the Brakes ?
Chuck
1992 American Eagle
burgess001
Springfield, MO USA
Posted: 07/12/12 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
Does Monaco still have their proprietary chassis. It may not still be in production???
Jerry and Katie
More than 20 great years motorhoming and still loving it...
2004 DSDP 3810 (more than I needed...less than I wanted)
2004 Trailblazer (too heavy but well worth dragging)
Norm & Deb
Brown Co. Indiana
Posted: 07/12/12 08:49pm Link  |  Quote  |  Print  |  Notify Moderator
I believe its a Roadmaster chassis.
Diplomat Don
Moorpark, Ca
Posted: 07/12/12 10:56pm Link  |  Quote  |  Print  |  Notify Moderator
Norm......The Monaco archives say you have this chassis:
Chassis Roadmaster RM4C
Engine Cummins 260hp ISB w/electronic fuel injection.
Cubic Inch Displacement 359
Torque 550 lbs.ft. Max @ 1900 rpm
Transmission Allison T-1000 4-Speed
Alternator 160 Amp
Rear Axle Ratio 4.88:1
Suspension Neway Air Suspension w/4 Outboard Mounted Airbags & 4 Shock Absorbers
Don & Mary
2005 Monaco Diplomat 36SKT
400 Cummins
2012 Chevrolet Silverado LTZ CrewCab 4WD
2013 Polaris RZR 800 LE
topflite51
In The Desert of Nevada
Posted: 07/13/12 07:19am Link  |  Quote  |  Print  |  Notify Moderator
I was told once, that all the information you needed for brakes on Monaco DP's Roadmaster chassis were the tag info on the axles, never verified it. Don't know if this helps.
David
Just rolling along enjoying life
w/F53 Southwind towing a 87 Samurai or 01 Grand Vitara looking to golf or fish
Simply Despicable
Any errors are a result of CRS.
mscamping
any place, USA
Posted: 07/13/12 06:02pm Link  |  Quote  |  Print  |  Notify Moderator
Are they disc or drum?? They should be Bosch if they're disc.. Do you have air brakes?? If you do, you don't have a Roadmaster chassis, you have a Freightliner with drum air brakes.. Mike M..
PS:Norm, the shop should be able to tell when they take them apart?? They may be stalling because they don't want to work on a motorhome.. You might want to take it somewhere else?? Just a thought..
 > Need Brakes
