RV.Net Open Roads Forum: Travel Trailers: Need new tires ALREADY!
 > Need new tires ALREADY!
Page of 8
panamacamper1
Maryland
Posted: 07/12/12 04:45pm Link  |  Quote  |  Print  |  Notify Moderator
I puchased a new Shadow Cruiser 280qbs, it has 205/75/14 load C tires.
I have maybe 1000 miles on them and I always check the tire preasure before trips.
My unit (unloaded) is around 5,200lbs and (loaded) around 6,600lbs. I know you have to run tires at max psi(50) to get full use of 6 ply on tires. It has double axles and each axle is measured at 4,555lbs.
I need to take her in and see if the axles are out of allignment or bent. Is this under warrentee if I am still with-in a year of purchase?
What tires would you recommend?
UPDATE: This is after I did the rotation of the two rear axle tires. Remember I have maybe 700 to 800 miles on these tires. TT was brand new.
Bald on the inside (original left rear axle tire)
Bald on the inside (same tire) picture the other tire bald on the outside.
tread burned off the outside edge, this is from the tire before i rotated them, so it is bald on the outside
These are the tires that I have
* This post was edited 07/13/12 11:05pm by panamacamper1 *
johnrbd
San Joaquin Valley
Posted: 07/12/12 04:54pm Link  |  Quote  |  Print  |  Notify Moderator
Recommended tires - MAXXIS!
You may have to go to a ST215/75/14 D rating (1870 lbs @ 50 psi). Don't forget to get stainless steel valve stems installed.
As far as axle issues being under warranty, only the manufacturer and/or dealer can answer you question. They may "claim" that hitting a curb, pot hole, etc, caused the problem. Have patience but persistent in getting some assistance from them.
If all else fails, maybe you can get them to split the cost of repairs.
* This post was edited 07/12/12 05:08pm by johnrbd *
LakeN
North Carolina
Posted: 07/12/12 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
Max xis........just got new set......great ride!
'08 Toyota Tundra 5.7L with tow package/Prodigy
'12 Evergreen EverLite 31 RLS Compositek construction
jim87vette
Arizona
Posted: 07/12/12 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
What is the wear pattern?
08 GMC 3500 Dually Duramax
96 Chevy 2500 6.5
05 Yamaha Rhino
04 Gearbox 335FS 5er 14k wet
Huntindog
phoenix arizona USA
Posted: 07/12/12 05:46pm Link  |  Quote  |  Print  |  Notify Moderator
My unit (unloaded) is around 5,200lbs and (loaded) around 6,600lbs. I know you have to run tires at max psi(50) to get full use of 6 ply on tires. It has double axles and each axle is measured at 4,555lbs.This is a very unusual axle rating. Where did you find it?
Huntindog
2010 Palomino Sabre 30BHDS
TWO bathrooms...No waiting!
MICHELIN XPS RIBS LRE
2011 Silverado Big Dually 3500 4x4 CC D/A
EQUALIZER Hitch
100% BOONDOCKING
Check out Rusty and her pups at www.bluecollarbrittanys.com
panamacamper1
Maryland
Posted: 07/12/12 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
I found the axle rating here: http://www.cruiserrv.com/shadow-cruiser/specifications.html
Francesca Knowles
Port Hadlock, Washington
Posted: 07/12/12 05:51pm Link  |  Quote  |  Print  |  Notify Moderator
You don't say anything about what your tires look/perform like- how do you know you need new ones?
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
mapguy
Puget Sound
Posted: 07/12/12 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
4555 is the dry axle weight which is a meaningless number once the trailer is loaded up for a trip.
panamacamper1
Maryland
Posted: 07/12/12 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
I will go get pics of them right now.
dodge guy
Bartlett IL
Posted: 07/12/12 06:06pm Link  |  Quote  |  Print  |  Notify Moderator
14" "C" rated tires on a trailer with an approx GVWR of 7000lbs? Are they serious?!!!
Wife Kim
Son Brandon 11yrs
Daughter Marissa 10yrs
Dog Shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear 5Star tuner Y-pipe mod Hellwig sway bar
Reese HP dualcam Prodigy brake controller
A bad day of camping is
Page of 8
