RV.Net Open Roads Forum: Fifth-Wheels: New 3750fl size of washer dryer space.
 > New 3750fl size of washer dryer space.
214mrj44
quinlan,tx.
Posted: 07/12/12 08:59pm Link  |  Print  |  Notify Moderator
Dealer dosent know what size I can put in. Dont want splindine or other rv size wd. would like a apartment size if it will fit. I am sure I wont be able to run both at same time because of amps. That is not a proublem. Does anyone have any ideas as what I can use. Mike
webbfoot
CALLAHAN FL
Posted: 07/12/12 10:11pm Link  |  Print  |  Notify Moderator
Well brother,
I had same intentions. Settled for the splendale combo tight fit to say the least. Height if in a 5'er is going to b your issue with an apartment size.
jimtoo
Perfectly Great!
Posted: 07/12/12 10:43pm Link  |  Print  |  Notify Moderator
Go to Home Depot or Lowes and check out the Whirlpool stackable apartment units. Hear they really work good. Dryer works with 120v.
Happy Camping
Drive Safe
Jim & Bette
Texas Sweetheart Rally
George West Storyfest, 1st Sat of Nov.
04 GMC 3500, CC,Dually,Duramax,Allison
CB Radio, MaxBrake, Turboliner, Ride Rites
09 Bighorn by Heartland, 3670RL, Trailair Pinbox, Equaflex.
Artemus Gordon
Redding California
Posted: 07/13/12 01:06am Link  |  Print  |  Notify Moderator
We bought Whirl Pool stackable. Yes tight but work great. It's the door opening where you run into issue, not interior space of closet ! We removed trim and they slipped right inside! On 50 amp service we run both and two air units! You should have 90 amp converter in the 3750. No problems even here in 114 weather!
kakampers
Fulltimer
Posted: 07/13/12 06:47am Link  |  Print  |  Notify Moderator
X2....on the Whirlpools. Just make sure both units run on 110V...Whirlpool does make a 220v unit in the 27" wide apartment size....our experience has been the same. Removed trim to install and can run both even while running both airs....
2013 Heartland Landmark Key Largo with Mor Ryde IS and disc brakes
2011 Chevy Silverado 3500 DRW Crew Cab Duramax Diesel
NC Hauler
Pence Springs WV
Posted: 07/13/12 06:55am Link  |  Print  |  Notify Moderator
You also may want to check on weight capacity of the floor structure where you are going to put your washer/dryer combo or stackables..I was doing some research on this topic and found that most floors where there is a washer/dryer prep, or hook up's is usually rated for 150-175# max. Thus the reason we went with the Splendide 2100XC...Takes up little room and there is just my wife and myself, so another reason we opted to go this route. Also affords us space above the unit to store other things in shelving. Different folks have different needs, the one we chose works best for my wife and I, we also wash and dry the grandkids clothes when they stay with us and it does the job and we don't have to worry about overloading the electcal system when we wash or dry, no matter the weather..
Jim & Kathy, (Boxers, Buddy & Sheba)
2016 Ram 3500 DRW Longhorn 4X4/CC/LB/Aisin/4.10/rear air assist ...Pearl White.
2016 DRV MS 36RSSB3/ W&D/ slide toppers/ DTV satellite/ 5.5K Onan propane gen.
B&W RVK3600 Hitch
Fulltiming in WV & TX
USAF 71-75 Viet Nam Vet
Mile High
CO
Posted: 07/13/12 09:38am Link  |  Print  |  Notify Moderator
Love my Splendide Aristons. Not sure why you would rule them out.
2013 Winnebago Itasca Meridian 42E
2013 Jeep Wrangler Unlimited Sahara Towed
214mrj44
quinlan,tx.
Posted: 07/13/12 07:02am Link  |  Print  |  Notify Moderator
The whirlpools sound like what we are looking for. What are the model # on them. Thanks Mike
Jim-Linda
Livingston, TX
Posted: 07/13/12 08:44am Link  |  Print  |  Notify Moderator
First, measure the entry door width, Probably around <27". MOST RV stackables are 24". We recently replaced our 14 year old Kenmore with a new one. Kenmore is made by Whirlpool.
Jim
ScottG
Bothell Wa.
Posted: 07/13/12 09:25am Link  |  Print  |  Notify Moderator
Some of the best results have come from using a stackable WD from sears that runs on propane. They provide fast drying without using much gas.
Scott, Grace and Wesly
2018 Silver Fox 32A - many mods to come!
H0NDA eu2000i
