RV.Net Open Roads Forum: Towing: Help: The Travel Trailer is Not Level
Search only in Towing
Open Roads Forum  >  Towing
 > Help: The Travel Trailer is Not Level
RVM5
New Mexico
Posted: 07/12/12 11:04pm Link  |  Print  |  Notify Moderator
We have a Suburban 2500 and are pulling a travel trailer with it. Both the car and travel trailer are new to us. When my husband, set up the travel trailer to the car the tongue of the trailer is angled up. My understanding is that the travel trailer needs to be level. How do we fix this? In order to be even, we need the tongue down about 3 inches. The weight distributing hitch is adjustable and is adjusted to the lowest position.
2008 Jayco Jay Feather 213 EXP
2012 Suburban 2500
Tvov
CT
Posted: 07/13/12 05:15am Link  |  Print  |  Notify Moderator
Can you post pictures? That would help. Also make and model of hitch.
You might need some sort of drop hitch.
2008 F-250 CrewCab 5.4L,
naturist
Lynchburg, VA
Posted: 07/13/12 05:16am Link  |  Print  |  Notify Moderator
No doubt the adjustment bar needs to be flipped over to go down instead of up. If it IS already down, I'd have to ask where on earth they put the hitch itself. Did they mount it right under the back window or something?
Flipping that part of the hitch over should get it low enough for anything, except perhaps one of those raised swamp buggys, you know, the kind that you need a ladder just to climb in.
APT
SE Michigan
Posted: 07/13/12 08:14am Link  |  Print  |  Notify Moderator
Trailer level to slightly nose down provides a more stable towing experience.
You need to lower the ball. The easiest way is using an adjustable shank. I had to buy a longer shank when I went from a half ton pickup to 2500 Burb. This is what I have now.
2017 Subaru Outback 3.6R
skipnchar
Topeka or somewhere else
Posted: 07/13/12 08:28am Link  |  Print  |  Notify Moderator
You SHOULD be using an adjustable hitchhead assembly on your truck. this allows you to raise or lower the ball and get the trailer level before setting up the weight distributing system (to keep it level and weight correct on all four wheels of the tow vehicle). If you don't START level you can't GET to level by adjusting the hitch.
Here is a link to the part you need to make the correct changes to your hitch. Adjustable Shank
ScottG
Bothell Wa.
Posted: 07/13/12 08:56am Link  |  Print  |  Notify Moderator
The part you adjust the hitch height on is called a draw bar and you may need to but a longer one that allows for lower adjustment. This is especially common on 4WD vehicles. They're not cheap though, I had to buy one for my previous trailer and it was about $100 but it did allow me to get a near perfect level.
Scott, Grace and Wesly
2018 Silver Fox 32A - many mods to come!
H0NDA eu2000i
fla-gypsy
North Florida
Posted: 07/13/12 07:33pm Link  |  Print  |  Notify Moderator
As others have responded, you need a draw bar that can flipped over or one that has a longer mounting point that makes it adjustable. Be certain you get one rated for your size trailer. Like this:
http://www.etrailer.com/Accessories-and-Parts/Reese/RP54970.html
This member is not responsible for opinions that are inaccurate due to faulty information provided by the original poster. Use them at your own discretion.
RVM5
New Mexico
Posted: 07/13/12 08:09pm Link  |  Print  |  Notify Moderator
Thanks everyone. We found instructions on measuring to get the right shank. We'll get a new one.
