RV.Net Open Roads Forum: Class A Motorhomes: water stains on ceiling
 > water stains on ceiling
seahunter 1
Canmore Alberta
Posted: 07/13/12 06:42am Link  |  Print  |  Notify Moderator
I have a 98 Safari Sahara 30ft DP . After heavy rains in June , I had a tiny leak around my t.v. antenna and now I have some brown and blackish water stains on the fuzzy ceiling fabric . It's either from the glue in the plywood or the glue that the ceiling fabric is glued on with .I have re-caulked the roof , especially around the ( no-longer used ) t.v. antenna .
What can I use to get rid of the water stains on my ceiling ?
Seahunter 1.
klm
SIOUX FALLS, SD
Posted: 07/13/12 07:04am Link  |  Print  |  Notify Moderator
There are a couple of things you can try. I have had good luck using a spray oxyclean rug product. Spray on liberally, use a microfiber type cloth and rub the oxyclean into the fabric real good. Let it sit. Better? Might need a couple of applications. If the stain is really bad, you might need to use bleach/water, be sure to cover everything to protect it from the bleach. Protect yourself too, eyes, hands, etc. Might want to work it in with rags instead of spray. I would start with the oxyclean - can be bought in any grocery, WM - good luck
'02 KOUNTRY STAR DP
2012 HONDA FIT "PUMPKINMOBILE"
GILLIGAN- 1ST MATE CAT - 3 HR TOUR
donhoward49
Portland, Oregon
Posted: 07/13/12 07:26am Link  |  Print  |  Notify Moderator
Yes what klm says.. Some recommend Clorox cleanup but be careful with the bleach it might dissolve the glue and cause more problems.. Also on the TV antenna. if it is the crank-up and turn around, stem has rubber gaskets, so spray some silicone down from the top to soften up the rubber for a better seal.
Valkyriebush
Yuma, Az/Chimacum, Wa
Posted: 07/13/12 07:47am Link  |  Print  |  Notify Moderator
I had a leak on my shower sky light that left stains on the light colored lame carpet ceiling in the shower compartment. My wife mixed bleach and water in a spray bottle and dab cleaned it, its very hard to tell where the stain was now. Worked pretty good.
* This post was edited 07/16/12 07:53am by Valkyriebush *
Command Master Chief (AW) USN, (ret)
2003 Fleetwood Excursion 330 Turbo Cat 39D
2000 Jeep GC
2005 Big Ruckus (Rides Behind Jeep)
2003 VTX 1800
deaop01
Mansfield, Ohio
Posted: 07/13/12 08:24am Link  |  Print  |  Notify Moderator
When our antenna had a leak we used Spot Shot from Walmart. Spray it on dab it off with a damp cotton towel. May need to do it a couple of times. Make sure you rinse the towel often.
The Spot Shot comes in a spray bottle or a spray can. Don't buy the spray can it don't last very long. The bottle will last a long time for the same money.
Good luck
Ron
Betty and Ron
2002 Bounder 31W
8.1 with 5 speed Allison
2 slides
2005 Colorado toad
crasster
Dallas
Posted: 07/13/12 09:09am Link  |  Print  |  Notify Moderator
There is also some professional carpet cleaner sold at Sam's club that could remove the spot in the fuzzy fabric. Shout is also a good stain remover. If it is mold though, you are in for a real challenge and may either just have to replace the fabric to get rid of the mold stain or cover it up.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
Klueck
Posted: 07/13/12 03:03pm Link  |  Print  |  Notify Moderator
Oxyclean
Rapid Ray
Walnut, Ca.
Posted: 07/13/12 03:46pm Link  |  Print  |  Notify Moderator
I had a stain and was advised to use a paste made of peroxide and baking powder. Put the mixture upon the stain and let dry over night. Vacuum off the next day. WORKED FOR ME.
phillyg
SWFL
Posted: 07/14/12 07:04am Link  |  Print  |  Notify Moderator
A bit of Oxyclean and hot water in a spray bottle. Spray generously; wait a couple of minutes. Use a wet/dry vac to suck off the solution, or a carpet cleaner extension.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
cvbdsl
Winchester, ON
Posted: 07/15/12 02:19pm Link  |  Print  |  Notify Moderator
X2 - worked great. Just don't let it get too wet to saturate the glue etc.
Chris
2008 Holiday Rambler Scepter 42 PDQ
2013 Ford Edge - Ready Brute Elite Tow Bar/Blue Ox Base plate/Patriot Brake System
Retired Canadian Army WO (1971-2000)
