RV.Net Open Roads Forum: Tow Vehicles: Dodge 3500 Specs
Search only in Tow Vehicles
 > Dodge 3500 Specs
Bob Vaughn
Seffner, Fl.
Posted: 07/13/12 08:54am Link  |  Quote  |  Print  |  Notify Moderator
When checking the TL specs for the Dodge 3500 it shows the dual wheel tow capacity as being 6000 lbs more than the single wheel 3500. I wonder if this is a typo??
MPI_Mallard
McGregor Ontario,St. Cloud Florida
Posted: 07/13/12 09:56am Link  |  Quote  |  Print  |  Notify Moderator
I'm pretty sure it's correct,great truck by the way.
07' Dodge 3500 6 speed Cummins Diesel Dually/6.7L Bully-Chipped /
Exhst Brake/07' Cedar Creek 37CDTSD Daydreamer fiver
Mallard @ Frau Blücher
Red Green:
Now lets Bow your heads for the men's prayer.
I am a man, but I can change.
If I have to, I guess...
VintageRacer
Dundas, Ontario
Posted: 07/13/12 09:58am Link  |  Quote  |  Print  |  Notify Moderator
Probably not. The limit on the SRW is pin weight not exceeding GVWR, while the dually has a lot more payload capacity. Adding 6000 lbs of trailer adds 1200 - 1500 lbs of payload, at 20% to 25% rule of thumb. The manufacturers know that they can't exceed the total vehicle GVWR, so they leave the tricks and justifications based on loading up to the rear axle weight rating to us...
Brian
2005 F250 Supercab, Powerstroke, 5 speed automatic, 3.73 gears.
20 ft race car hauler, Lola T440 Formula Ford, NTM MK4 Sports Racer
1980 MCI MC-5C highway coach conversion
2004 Travelhawk 8' Truck Camper
NC Hauler
Asheville NC
Posted: 07/13/12 11:00am Link  |  Quote  |  Print  |  Notify Moderator
What model 3500 DRW truck? Mine is a 2010 with 4:10 rear end, GVWR is 12,200# and GCWR is 24,500#...The newer HO Cummins Dually with tow max package has same amount of HP, goes to 800ftlb of TQ, and though GCWR goes to 30,000#, the GVWR only goes up 100#, to 12,300#...
The dually 3500# offers quite a bit more payload than the 3500 SRW truck, almost like comparing apples to oranges..
Jim & Kathy
2013 Dodge 3500DRW Longhorn 4X4/CC/LB/Aisin tranny/4:10/Cummins: 385HP/850TQ
06 HR Presidential Suite 37RLQ/ 4 slide/ dual pane windows/Winegard SK3005 Satellite/Splendide XC2100 W/D
Boxers;Buddy& Sheba II
USAF 71-75 Nam Vet
WVU fan
Cummins12V98
on the road
Posted: 07/13/12 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
Weighed our combo, total weight 26,620# truck front axle 5,100# Rear 8,280# trailer tires 13,240#
Truck unloaded front 5,000# rear 3,880# = 8,880# trailer weight 17,740#
Pin weight is 4,400# on the rear axle and 100# on the front ... OUCH! Actually the rear tires still have over 3,000# capacity before they are at the limit.
NC Hauler my combo sits like yours does in your pic.
I think I need to raise the springs on the rv or get the wife to unload a few things! Problem most of the weight is on and forward of the axles.
2011 Ram Laramie Longhorn 3500 Dually Long Bed, Cummins 350/800 HO, Towin Machine
B&W Companion Hitch, Maghytec Trans and Rear Dif Covers, AMZ/OIL Top To Bottom
2007 1/2 Mobile Suites 36 SB3 27,000# Combined
I'm Rick James
Reno, NV, USA
Posted: 07/13/12 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
Holy sh!t that's alot of pin weight.
SoCalDesertRider
SanDiego, CA, USA
Posted: 07/13/12 03:08pm Link  |  Quote  |  Print  |  Notify Moderator
What's a 'TL' spec??
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
NC Hauler
Asheville NC
Posted: 07/13/12 03:25pm Link  |  Quote  |  Print  |  Notify Moderator
"Totally loaded"? "Trailer Laded"? Got me on that one
Cummins12V98, my 5er, last time I weighed it was 15,400# and pinweight was almost 3400#...GVW on my 5er is 16,900#, but when I tow, all tanks, 'cept propane are empty...and the wife and I really don't carry a whole lot.....( pin weight went up a little when I put the combo Splendid washer/dryer in the room that was set up for it, up front...
That picture was taken a little over 2 yrs. ago when I purchased the truck, June of 2010...I had the hitch moved from my 07.5 Chevy Dually to the Dodge and had to tow the 5er from the lot home, about 5 miles. Salesperson took a picture of the rig...if it hadn't been for that, guess I wouldn't have that picture in my sig..(had a buddy add the picture for me, I was too dumb to figure out how to do it myself)
Cummins12V98
on the road
Posted: 07/13/12 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
Yea I about fell over!
When I bought it I pulled it to the truck scales and the pin wt was 3,500# including 100# on the front axle. We added about 2,000# of stuff but 1/2 of the wt went to the truck. When I bought the rv the springs were in the highest holes and it rode nose high so I lowered the springs to the lowest holes to make it barely nose high. I ordered the GY G6114 H 17.5 tires and Alcoa wheels today from trailertiresandwheels.com. So I may raise the springs back up and transfer more weight to the back axle now that I have a huge buffer with the H tires.
Any thoughts?
MadMav
Colorado Springs, CO
Posted: 07/13/12 09:47pm Link  |  Quote  |  Print  |  Notify Moderator
Man you are within 100lbs of overloading that hitch on the pin. I would be carefull there.
I wouldn't recommend towing nose high either. You could risk overloading one of the trailer axles. Check the specs on those. I'm guessing they are 7k units and you are close on them.
Mav
"A fifth wheel trailer is a bi-level towable mobile home."
 > Dodge 3500 Specs
