woodworker215
Olmsted Falls,OH
I am thinking about purchasing a Honda generator. Since my brother owns a power mower shop I have borrowed both kinds 2000 and 3000 and a genny with a briggs and Stratton and swore then I would never do that again, the noise made camping unenjoyable. The 3000 handi will power my TT with the A/C and the 2000 will not. However we usually don't boondock that much in the summer when A/C is needed. And my thought is to purchase a 2000 Companion now and if needed another 2000 if we see the need. Genny would also be used in case of a power outage at home. Your thoughts
old guy
Oregon (pronounced Or e gun)
I think you are on the right track. the two honda's are the way many have gone
time2roll
Since noise is a concern stick with the 2000.
675w Solar pictures back up
mlts22
Austin, Texas
The 3000 Handi doesn't have a big fuel tank. You will be refilling that thing fairly often.
If you know you are needing A/C and lugging generators is an issue, go for a 2000 Companion and a regular 2000, and pair them. You can down the road get extended run gas tanks for them so you can keep the A/C going a lot longer.
ArcticDodge
Sammamish, WA
Sounds like a very reasonable plan to me.
2009 Komfort 256TS
2001 Dodge Ram 3500 QC 4x4 Cummins DRW
2005 Dodge Durango Limited AWD HEMI
2006 Dodge Charger R/T HEMI
2001 Sebring Convertible
1995 Miata M-Edition
1 Wife "> 2 Boys UW & Bellevue College
1 Trixie (Bichon Frise)
Only 21 years to retirement!!!!
Sandia Man
Rio Rancho, NM
Honda are great generators but the Honda Handy 3000 is 65db when heavily loaded and is rated at 2600 watts. The original Honda 3000eu is heavier, but is much quieter, has higher wattage rating, and cost less to boot. Of course a pair of Honda or Yamaha 2K units would be a good choice as well.
phillyg
SWFL
I have a Handi and it's great, but if not running the AC, then a 2000 or two 2000s provide better portability and one running is slightly quieter than the Handi. No sense in burning up fuel in a Handi when you don't need AC.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
woodworker215
Olmsted Falls,OH
Thanks for all your comments I have used the 3000eu before and it is a great generator but it takes two men to lift it in to the bed of a truck. And I have a hard tonneau cover on the bed of my truck and the 3000eu will not fit under it. Yes the Handi is louder than the 3000eu or the 2000.
I think this makes up my mind. I’ll get one 2000 companion and the adapter/cable now before the lights go out. And if we see the need I can get the second one to handle all my power needs.Thanks for all the comments Happy Camping!
ktmrfs
Portland, Oregon
woodworker215 wrote: I am thinking about purchasing a Honda generator. Since my brother owns a power mower shop I have borrowed both kinds 2000 and 3000 and a genny with a briggs and Stratton and swore then I would never do that again, the noise made camping unenjoyable. The 3000 handi will power my TT with the A/C and the 2000 will not. However we usually don't boondock that much in the summer when A/C is needed. And my thought is to purchase a 2000 Companion now and if needed another 2000 if we see the need. Genny would also be used in case of a power outage at home. Your thoughts
honda 2000 and another if needed. Much easier to carry than the 3000 handy, noticeably quiter than the handi, easy to use external fuel tanks if neededed, easier to store.
OR a yamaha 2400 or so. the honda 3000 is nice and quite but way to heavy for me, the handi to noisy.
2011 Keystone Outback 295RE
bill h
hassayampa valley
A pair of 2000s is easier to lift and store. And, if air is not needed, you need carry only one.
NOTE: Any incorrect spelling is intentional to prevent those annoying popups.
84 Barth 30Tag powered by HT502/Thorley/Weiand etc, Gear Vendors OD.
Siamese Calvin and Airedale Hobbes, 4WD Toyota toad
