Luke Porter
Not on the road :(
Went to Flying J to get some DEF at the pump. They have a combined pump with both DEF and diesel.
Swipe my card, go through the menu--one selection was Tractor fuel or Reefer fuel--I selected tractor.
It then said "remove nozzle" so I grabbed the DEF nozzle and hit the DEF button. It then said "replace nozzle" which I did. Then it said "remove nozzle"---then replace, remove, replace.
Got on the phone. They didn't know what was up, said come in to pay.
I'm wondering if I did something wrong? Do you have to get diesel first? I followed the directions on the pump for DEF.
Yep, actually drove to all of these places---in the last eight years. Missed Rhode Island and New Jersey.
jfritz_drfritz
canada
I buy my def in bottles precisely so that I don't have those issues
Luke Porter
Not on the road :(
Yeah, well $2.59 a gallon vs. $4.79 a gallon. Pick your issues.
I got about 10 gallons, so saved about $22.00
jfritz_drfritz
canada
Luke Porter wrote: Yeah, well $2.59 a gallon vs. $4.79 a gallon. Pick your issues. 5 gallon capacity 4.59 - 2.59 = 2.00 = $10.00 difference for a full tank refill over ~ 5000 miles. Different strokes - how much does it cost if you have to take it in for contaminated def?
Cummins12V98
on the road
Most of the truck stops are like that, Joe public has to go inside and tell them how much you want to spend. Then you can fuel up and if you spend less they credit your card then charge the correct amount. I send the wife in as soon as we can see what pump number we will be using. She tells them $150 and when it says lift handle I fuel up and when I finish I call her and let the phone ring twice then hang up so she knows I am done and can get a reciept for the correct amount. Once you get a system down the truck stops are a good way to go. Most have a RV frequent fueler program that will save .03 per gallon.
2011 Ram Laramie Longhorn 3500 Dually Long Bed, Cummins 350/800 HO, Towin Machine
B&W Companion Hitch, Maghytec Trans and Rear Dif Covers, AMZ/OIL Top To Bottom
2007 1/2 Mobile Suites 36 SB3 27,000# Combined
NewsW
US
Can't you just get a six pack and make your own?
Luke Porter
Not on the road :(
NewsW wrote: Can't you just get a six pack and make your own?
$7 for 72 oz?
dave17352
LINCOLN, NE
Curious here does the DEF nosal only pump DEF or can it pump deisel too. I assume it must only pump DEF. I have never seen a pump with DEF.
Turtle n Peeps
California
dave17352 wrote: Curious here does the DEF nosal only pump DEF or can it pump deisel too. I assume it must only pump DEF. I have never seen a pump with DEF.
DEF only.
outside the fire"
Luke Porter
Not on the road :(
The pumps have both DEF and diesel. One hose for each. The diesel has a huge nossel--on the right side of the pump. The DEF is on the left with a small, say 5/8" nozzel, on the left.
The DEF nozzel is enclosed under a cover---probably to protect it from freezing.
