RV.Net Open Roads Forum: 3TB drive for STORAGE Formating GPT or MBR
 > 3TB drive for STORAGE Formating GPT or MBR
TenOC
On the road -- Full time
Posted: 07/14/12 08:28am Link  |  Quote  |  Print  |  Notify Moderator
Older Dell computer Win XP Pro SP3. I need to upgrage my STORAGE hard drive not my boot hard drive. Too many photos of travels.
If I purchase a 3TB HD I think . . . . that my BIOS (?) -- or maybe it is a limit on the MBR formating -- can only see it as a 2.2TB drive (?). Must I format it as a GPT? I am not sure my computer support GPT (?)
I need to be educated. .
Sorry I think I posted this in the wrong forum. Please move to correct on.
Please give me enough troubles, uncertainty, problems, obstacles and STRESS so that I do not become arrogant, proud, and smug in my own abilities, and enough blessings and good times that I realize that someone else is in charge of my life.
Travel Photos
96Bounder30E
America is my home!
Posted: 07/14/12 08:32am Link  |  Quote  |  Print  |  Notify Moderator
Moved from tech issues
mangler
Calgary, Alberta, Canada
Posted: 07/14/12 08:42am Link  |  Quote  |  Print  |  Notify Moderator
This is a limitation of the operating system you are using. If you have XP 32-bit version, there isn't much you can do. Use it as a 2.2 TB disk or upgrade your OS to windows 7 (a complete reinstall).
Even if your PC doesn't support 64-bit, windows 7 will work with this as a data drive. See this article for more info.
2.2GB limitation
Travelling with the wife and two kids (16and14)...
5th: '08 Colorado 29BHDS (10-11,000 lbs wet)
TV : '04 Chevy Silverado 2500HD Duramax/Allison Crew Cab
mena661
Posted: 07/14/12 08:46am Link  |  Quote  |  Print  |  Notify Moderator
It's more than likely a BIOS limit. See if there is a newer BIOS that allows larger hard drives. Regardless, given the age of your computer, you likely don't have GPT support.
Trojan L16 6V's 740 Amp-hours
sgip2000
Oregon
Posted: 07/14/12 09:26am Link  |  Quote  |  Print  |  Notify Moderator
Definately would need GPT to utilize the eitire drive. Windows XP with SP3 will see and use GPT partitions; but as some have said, you may have a BIOS limiting issue.
I'd suggest a USB enclosure. This will eliminate all of these limitations.
TenOC
Posted: 07/20/12 08:30am Link  |  Quote  |  Print  |  Notify Moderator
Up-Date I purchased a Seagate 3TB internal drive. With Win XP Pro 32 bit, I could not format it as ONE 3TB partition. However, Seagate has software and a very good "how to video" that show how to use the drive as a 2.2TB partition and a 0.8TB partition. Not what I wanted but I still get 3TB of data storage on one physical drive. I now have an "F" and a "G" drive (read partitions) to store my photos on.
