RV.Net Open Roads Forum: How do you inflate your Class A tires ?
 > How do you inflate your Class A tires ?
Page of 5
wtfjr
Ormond By The Sea FL
Posted: 07/14/12 12:17pm Link  |  Quote  |  Print  |  Notify Moderator
I just have to tell you all about how great our new Viair 40047 RV tire inflator really is.
We bought it online for about $245 a couple of months ago & have used it several times in the past with great results.
Today I hooked it up to the battery & went around to each of the six tires & topped them off as needed. When thru & packing up the Viair I felt like that old commercial said sometime ago, that you will forget the price paid for the item & be delighted with it for many years to come.
This is probably the best money I have ever spent on RVing.
Now we can air up any tire, any time & any where as long as we have 12 volts power.
Just had to share my thoughts on how to air up our tires ??
Later.
Bill in FL
* This post was last edited 07/14/12 02:07pm by wtfjr *   View edit history
Chuck_NJ
New Jersey
Posted: 07/14/12 12:25pm Link  |  Quote  |  Print  |  Notify Moderator
Not to throw cold water on your post but I would never leave a tire inflating un attended. I own an auto repair shop and had a mechanic leave the air hose atached to a suv tire. He then leaned it against the inflate pedalof the tire machine to attend to a customer. Well the resulting explosion was devastating took out windows and damaged a few vehicles, thank god no one was standing near.
Sully2
Cincinnati
Posted: 07/14/12 12:34pm Link  |  Quote  |  Print  |  Notify Moderator
I agree with chuck!
As far as the whoop de do machine....I bought a Sears compressor that goes to 150 PSI...for right at 150 bucks!!!
2000 Country Coach Allure; Cummins ISC 330 HP; 71/2 - 8 MPG regardless
2002 Jeep Liberty
Goldencrazy
madison wi
Posted: 07/14/12 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure what Chuck's post is referring to in the Original post. I didn't read that he left the compressor hooked up for extended period. I am curious how large this is.
wtfjr
Posted: 07/14/12 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
It is a small carry around light compressor & NO it is not left unattended while inflating. In fact you have to squeeze the air control handle to release air into a tire.
Do a Google search for this item for pics & info.
Later.
Bill in FL
Chuck_NJ
New Jersey
Posted: 07/14/12 01:24pm Link  |  Quote  |  Print  |  Notify Moderator
ok i read a quick review on amazon said it was an auto inflate system MY BAD Sorry
Bob & Ann
Vinemont AL
Posted: 07/14/12 02:18pm Link  |  Quote  |  Print  |  Notify Moderator
We have a flat saucer tank compressor that we bought from Lowes. It will pump 150 pounds. On a big trip I throw it in the back of the toad. With the generator it can be used anywhere.
Bob and Ann
One HAPPY Schnauzer - Della
One FRISKY Chihuahua - Lola
2005 37 DB Allegro Bay
Workhorse Chassis
GM 8.1L (496 CID)
340 HP
Onan 7000 Watt
Double Slide
2006 Suzuki Grand Vitara Toad
GMC_jon
Arizona/Virginia
Posted: 07/14/12 02:21pm Link  |  Quote  |  Print  |  Notify Moderator
If you've only had this compressor 2 mos. & have had to use it several times to air up/top off your tires I think you have a REAL PROBLEM that is NOT being addressed.
JMHO
John
rv2go
Fulltime (Knoxville, TN).... or someplace else
Posted: 07/14/12 03:23pm Link  |  Quote  |  Print  |  Notify Moderator
I carry a small 12 volt compressor in the Jeep in case I need to air up the Jeep tires if I am away from the MH.
I use the on board air system to air up the tires on the MH. The Journey came with a 50 hose. I have even been able to help others with low tires.
Winnebago Journey
TN Lic. RV 2 GO
Jeep Cherokee 4x4
www.rv2go.us
I'm here #4335
Travel Photos
wny_pat
Western NYS
Posted: 07/14/12 03:35pm Link  |  Quote  |  Print  |  Notify Moderator
Bill in FL,
You have a Tiffin 36' Phaeton diesel pusher don't you? If so, your engine has a on board air compressor. All you need to do is tie into a air line somewhere, and I think the quik connection tie in is already there.
Page of 5
