24fb freedom
littlerock,ca
just got our 5th wheel th with fuel station,filled fuel station with fresh fuel and today went to get fuel out (needed some hand cleaner) and fuel was dark yellow, could the tank be dirty alredy? generater runs fine with fuel but it just seems to dark, what could cause this?
jackxclan
bakersfield
Thats usually just the fuel in the hose. For some reason the hose colors the fuel. Did it
Gun metal gray 07 new body style 3500 diesel crew cab 4x4 dually
blue 06 Ragen fa 3405
red 400 ex
black 250ex
red 400ex
red KW heavy iron hauler
HOOLIGAN # 385
Jerrybo66
AZ
I always put the first "squirt" in a can before gassing the ATV. It makes a great starter for the campfire..
Support the Country you live in or live in the Country you support
2003 Sierra SP 26'Toy Hauler
1997 F-350, PSD, 4X4, red Crew Cab, long bed.
2007 Arctic Cat Prowler, Arctic Cat 500
Golden_HVAC
Fulltime, CA, USA
IS his the very first time you filled the tank?
IS this a new Toyhauler, or recent purchase?
What brand fuel did you buy?
I know at least one brand is tinted blue, don't know about the others.
I just know that if you use red dye fuel in your truck, it is a huge fine! for not paying the road fuel tax. Red dye fuel is only for off road vehicles, generators, and things like tractors on a farm.
If it is a brand new toyhauler, first congratulations on the new purchase, and also they might have coated the inside of the fuel tank with oil when they manufactured it, and this might have changed the fuel color a little bit. So how full did you fill the tank? If only 10 gallons in a 36 gallon tank, it might have a high percentage of oil to fuel, but if you filled it all the say, it should have diluted a lot.
Fred.
big buford
Buena Park, Ca
jackxclan wrote: Thats usually just the fuel in the hose. For some reason the hose colors the fuel. Did it
X2
04.5 GMC 2500HD D/A
06 38 CKS Dune Chaser
Chenowth 4-seat Subaru pwr
06 Rhino
06 Raptor 700
Beautiful wife that's much nicer than me
jeffws
Ladera Ranch CA
X3
00 FLHR
03 XR 50
05 CRF 70
03 XR 80
05 CRF 230F
06 Yamaha Rhino
06 KTM 525 EXC
05 F-250 CC,4X4,6.0 PSD
06 Gearbox 295FS
05 Carson 7x10
24fb freedom
littlerock,ca
thanks for the replies guy's, yes its a new trailer and yes first time i filled tank,its a 40gal, so if its the fuel in the hose then it will be yellow every time i pump right??
jackxclan
bakersfield
24fb freedom wrote: thanks for the replies guy's, yes its a new trailer and yes first time i filled tank,its a 40gal, so if its the fuel in the hose then it will be yellow every time i pump right??
Yes first pint /quart not a problem with using it. You might have dislocation from everything being new but, its normal for the hose to color the fuel.
mr. old style
wisconsin
jackxclan wrote: 24fb freedom wrote: thanks for the replies guy's, yes its a new trailer and yes first time i filled tank,its a 40gal, so if its the fuel in the hose then it will be yellow every time i pump right??
X2
nayther
Burbank, CA
jeffws wrote: jackxclan wrote: Thats usually just the fuel in the hose. For some reason the hose colors the fuel.
X3
X4
DIRT BIKES RULE
'12 Duramax CC short bed
'06 3005 Rage'n Falcon
