RV.Net Open Roads Forum: Truck Campers: Bigfoot needs to be wider for dually.
 > Bigfoot needs to be wider for dually.
aaronmt
Port Orchard, WA
Posted: 07/15/12 09:55am Link  |  Quote  |  Print  |  Notify Moderator
We have a 03 Dodge Ram dually and 99 Bigfoot 9'6" 2500.We have the Happi-Jacks as well as the dually swing outs on them.The problem is still very tight getting pass the flares.Im not if anyone has added to these or extended them some how.If doin that what would the extra leverage on the jacks be.Surely someone else has had this issue.
trander
southern Colorado
Posted: 07/15/12 10:05am Link  |  Quote  |  Print  |  Notify Moderator
I have about an inch on each side, take my time and they are ok. All you need to watch is the driver's side, the other should be good also.
2003 Lance 1121, 2006 Dodge 3500 quad cab Laramie 4X4, auto, 4.10
SoCalDesertRider
SanDiego, CA, USA
Posted: 07/15/12 10:15am Link  |  Quote  |  Print  |  Notify Moderator
You can add a piece of 3/8" thick flat bar in an appropriate width and length to use as a width spacer to set the jacks out further. Welding them on is the easiest way to attach them.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
campn4walleye
Central WI
Posted: 07/15/12 12:06pm Link  |  Quote  |  Print  |  Notify Moderator
We have less than 1/2" on each side even with the swingout brackets. We too have considered extending them, but DH has learned to maneuver by taking his time and getting out serveral times to check progress.
Sometimes it's a matter of maneuvering a bit diagonally to get the positioning correct, but he can usually have it loaded within 15 mins or less. The key is to take your time and check your progress. It also helps if you have a spotter to assist.
If you look up my previous posts, I have asked the question as well. I just don't know how to post a link to it. Search key words like swingout bracket extensions and you'll find the suggestions.
Good luck.
2011 Adventurer 910FBS,Torklift tie downs,Fastguns & Wobbl-stopprs
2012 Dodge 3500 DRW 6.7L CTD, 4x4, LB,CC,6 speed auto,3.73 axle, General 17" on/off road
2008 Lund 1825 Explorer Sport,115 Merc,9.9 kicker,Torklift Super Hitch,42" Supertruss
USAF ret E-9&E-7
