clotus
ca
I just discovered flushable wipes, greatest thing ever On the package it states it is safe for sewer and septic. Will it be safe for RV use? In moderation of course. Thoughts.....
Camper: 03 Lance 820
Truck: 08 Dodge 2500 quad cab 4x4 diesel
-Airbags, supersprings, hellwig sway bar, rancho 9000xl, toyo open country tires, torklift Superhitch and torklift tie downs
Dogbone
Ontario Canada
Sounds OK the more biodegradable the better.
2006 Holiday Rambler Vacationer 35SBD
36ft Workhorse 8.1
narcodog
Georgia
I wouldn't use them. In a home system you flush power to force the stuff down the pipe. In an R/V it is just gravity.If one got hung up along the way you may have a problem.
MKish
SF
I researched these a bit while potty training a kid--this was for a home sewer system. Apparently they do have a tendency to block up household plumbing if overused. So we tried to keep the volume down and didn't have issues (and the plumbing in that house was probably not as good as on your camper . We required professional assistance with clogged pipes but no incidents were attributed to wipes.)
In moderation? Hmm. Perhaps you would be so kind as to test it for us? I'd sure like to know!
skipnchar
Topeka or somewhere else
Since no RV has either a septic system or a permanent sewer hook up, I'd certainly never allow them to be put into MY holding tank. Treat it like a septic system and plan on clogs. Someone posted on these forums in just the last week, an instance of clogging their black tank completely from using "flushable wipes".
Good luck / Skip
214mrj44
quinlan,tx.
The first thing you have to do is go to home depot and get a short sewer snake because you are going to need it. Dont ask how I know. Dont put in black tank.Mike
tmmar
Nassau County, Long Island, NY
narcodog wrote: I wouldn't use them. In a home system you flush power to force the stuff down the pipe. In an R/V it is just gravity.If one got hung up along the way you may have a problem.
X2!!
2008 40' Forest River Berkshire DP Bunkhouse
dupreet
High Point, NC
I'd stay far away from them and would not put them in the tank. RV's have holding tanks, different than septic or sewer systems. Anything more solid than TP will tend to sink and coagulate.
Todd
Todd
1993 Ford E-350 pushed by a 1988 Wilderness 24' TT
kerry4951
East Central Pennsylvania
Yes and if you happen to use a sewer macerator pump, then you will really have problems.
2009 Chevy Silverado 3500 dually D/A, Supersprings, Stable Loads, Bilstein Shocks, Hellwig Sway Bar, Front Timbrens.
2010 Arctic Fox 1140 DB, 220 watts solar, custom 4 in 1 "U" shaped dinette/couch, 59 interior and exterior mods to date and still adding
Old-Biscuit
Across the USA
There was a post on here not to long ago asking for suggestions on how to unplug the black tank drain line.......wife found them 'disposable wipes' and had been using them
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
