jolooote
Miami, FL
Learjet...20 amps is 20 amps no matter Whats loading or Recharging it...its, comparitively, ALOT of current...
Joe & Charlotte, 2015 Thor Vegas 24.1 Ford E-350 305hp V10 5speed, Jeep Wrangler & Honda Element 'TOADS'
Rosie, Morky Dogs
Leroy's a Conure
"Once it starts breakin'...GET RID OF IT!"
wolfe10
Sorry, lack of math here.
WATTS is WATTS
Amps of 12 VDC is NOT equal to Amps of 120 VAC.
20 amps @ 12VDC equals 2 amps @ 120 VAC.
Brett Wolfe
2003 Alpine 38'
MrWizard
Traveling
that cabin cool is a chassis/ basement style unit , not small for the roof
but boy it does seem super efficient
he sure did not help the oem a/c and onan by starting and stoping the generator withe the a/c turned on
these guys should go to an RV show and demo these units
Radiate The Happy
1997 F53 Bounder 36s
Learjet
Louisiana
jolooote wrote: Learjet...20 amps is 20 amps no matter Whats loading or Recharging it...its, comparitively, ALOT of current...
you might want to check that sir
2017 Ram Big Horn, DRW long box, 4x4, Cummins, Aisin, 3.73
2015 Wildcat 317RL, MoRryde rubber pin box, Titan Disc Brakes, Trojan T105
B&W Ram Companion
Yamaha EF2600c tri-fuel generator
Champion Model 46595- 3000/3500w
mena661
wolfe10 wrote: Sorry, lack of math here.
WATTS is WATTS
20 amps @ 12VDC equals 2 amps @ 120 VAC. X2
Trojan L16 6V's 740 Amp-hours
Learjet
Louisiana
WATTS is WATTS
Thank you! electrical advice on this forum gets pretty scary sometimes.
jolooote
Miami, FL
Lear, the man wants an AC thats going to draw 20 amps...that all thats important. He's gonna have to recharge those batteries after drawing 20 amps/hour. A good battery is gonna last about 4-5 hours. Than he's gonna have to run his generator all evening to recharge for the next days heat. Seems silly to me. Or he could cover an acre of land with solar panels. lol
time2roll
An acre? Not quite that much. Probably 800 watts would about do it. 400 watts to run the air an 400 watts to recharge the battery to run the air into the evening. Maybe another 400w and more battery if it is to run well into the night. Should cycle some by then.
675w Solar pictures back up
mena661
smkettner wrote: An acre? Not quite that much. Probably 800 watts would about do it. 400 watts to run the air an 400 watts to recharge the battery to run the air into the evening. Maybe another 400w and more battery if it is to run well into the night. Should cycle some by then. Yep, this is a hell of a lot more feasible at 20 amps.
MEXICOWANDERER
las peƱas, michoacan, mexico
Until someone I trust stands under one on a hot day and says "Man that thing puts out some cold air, I'll tell ya" this critter goes into the "Good tasting salt substitute" and "Bernie Madoff's fund has the very best return" dept. Sorry.
