RV.Net Open Roads Forum: Tech Issues: Pumping water through city port?
 > Pumping water through city port?
Mamacast
Breckenridge
Posted: 07/15/12 04:13pm Link  |  Quote  |  Print  |  Notify Moderator
I have posted this in another forum but am not getting much feedback.
Has anyone had any success in overriding the pressure required to fill your tanks from the city fill water port? That is the only port available on our TT, otherwise we must bring containers of water (muddy mess) into the trailer, balance the couch (no small issue) then fill. We could run a long hose from inside the trailer to the outside but as one member points out that would seriously diminish the suction and we would not be able to use any water in the trailer while filling. Would love to know what kind of pump would be required to pump enough pressure to overcome the city fill check valve. We dry camp solely and need to figure this out. Most other campers have figured out great systems for gravity filling with pumps but before we buy a pump we want to know how strong it needs to be. Would have loved a heads up about this during our orientation!
hmknightnc
Wilmington, NC
Posted: 07/15/12 04:21pm Link  |  Quote  |  Print  |  Notify Moderator
Can't really tell what you are talking about I assume you have a TT with a city water connection only and no gravity fill for the freshwater tank. If that is the case you simply need to use your winterization connection to suck water from your portable container using your on board water pump to fill the fresh water tank. No special rigging or seperate pump needed
Artum Snowbird
Campbell River, B.C., Canada
Posted: 07/15/12 04:28pm Link  |  Quote  |  Print  |  Notify Moderator
I would imagine that just a few feet of lifting up a water container with a hose in it would allow the water to flow into your tank. Just make sure your onboard water pump is not on, and a tap is open with nothing coming out.
Fill your water hose line, put one end in your water container, screw the other end onto your RV, then lift up the water container and see how long it takes to get five gallons in. The higher the lift, the faster it will flow into your tank.
Mike and Carole
2007 Snowbird 9'6" Super Slide
2005 16.6 Double Eagle
2000 F350 7.3 SC 4X4
previously 8'10" Snowbird Camper
2006 Triple E Regency 27 foot SXL SOLD!
Mamacast
Breckenridge
Posted: 07/15/12 04:33pm Link  |  Quote  |  Print  |  Notify Moderator
In order to use the winterization hose we have to do all the switching from inside there- is no access from the outside. So currently we bring the containers into the TT and siphon from there but it is a muddy mess and you can't use the TT water system while doing this. Would take 20 feet of hose to keep the tanks outside. We are hoping to purchase a separate pump to use to force water in but wanted to make sure we knew what kind of pump to get to overcome the check valve.
Mamacast
Breckenridge
Posted: 07/15/12 04:34pm Link  |  Quote  |  Print  |  Notify Moderator
There is a check valve in the city water port to keep the tanks pressurized so gravity doesn't work. Wish it did!
rrupert
NW PA
Posted: 07/15/12 04:39pm Link  |  Quote  |  Print  |  Notify Moderator
What make and model is your TT? Maybe someone knowing that has had experience with filling the tank. You have to be doing something wrong. Are you sure there is no gravity fill port? Do you have the owners manual? It may actually have directions for filling the tank.
Rich and Joyce
2010 HiLo 2310H
2012 Ford F150 4X4 Supercrew EcoBoost
Reese Strait-Line Dual Cam Hitch
Amateur Radio K3EXU
rvten
Crossville,TN
Posted: 07/15/12 04:44pm Link  |  Quote  |  Print  |  Notify Moderator
You sure there is not a lever or knob to turn to fill tank from city conn.?
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008 Type C
Ford Flex SEL 2010
There is no B+
downtheroad
Pacific Northwest
Posted: 07/15/12 04:55pm Link  |  Quote  |  Print  |  Notify Moderator
Are you saying that your trailer has a fresh water tank, but no way to fill it from the outside???
Are you sure?
If so then.......
What manufacturer???
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
Old-Biscuit
Across the USA
Posted: 07/15/12 04:59pm Link  |  Quote  |  Print  |  Notify Moderator
Buy a 12v DC water pump.....
Suction line in your water container
Discharge line connected to your city water/fill
Pump away.
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
Mamacast
Breckenridge
Posted: 07/15/12 05:07pm Link  |  Quote  |  Print  |  Notify Moderator
No gravity port on the Spree 220. We rewatched the video that I made of the orientation many times. We didn't know enough at the time when the technician mentioned that there wasn't a gravity fill model on this one to have that raise any questions. This is our first TT. The owners manual does have directions for filling the tank from inside the trailer. We can do it that way but as I said it is a muddy mess. We are wanting to pump water from outside the trailer through the city connection.
