Hey, guys. New member of the forum.
Looking for some advice here. I just bought a 2006 four winds 26L
trailer, weighing in at 6840 lbs. I currently have a 2000 F150 4.2L , V6. The towing capacity on the vehicle says 7500lbs.
My question would be,,, can this truck tow the trailer safely and if it cannot what will tow it .
There are more experts on here, but by the time you put your family in your truck, luggage, food and all the other items, you will be pass the safety zone of your truck.
You'll also be pass the capacity of the transmission and engine.
Dan, Tammy, Cory, Leah and Adam
2011 Chevy Silverado 2500HD 6.0
2012 Conquest 297DBS
Equal-i-zer Hitch
GM Integrated Trailer Brake Controller
It will safely tow a trailer that fully loaded for camping doesn't exceed 7500 lbs, with a tongue weight that when conbined with the weight of occupants and gear in the truck does not exceed the payload capacity or the rear axle rating of the truck.
6800 lbs towing with a V6 gas engine. It really depends on your driving style and patience but my guess is you will not like it. I doubt that that combination will get out of drive and you'll have trouble maintaining interstate speeds
Just as a point of reference we spent several years pulling a 6,000 lb TT with a 5.3L V8 Tahoe with a complete towing package including low speed rear end. Pulled around 40 thousand miles without any trouble but I would not want to pull anything heavier than that 6,000 TT with it. Spent most of it's towing time with engine above 3,000 rpm. Your V6 isn't as powerful as that vehicle and your talking about pulling a heavier trailer.
You just answered the question here. It is not much engine for the trailer's weight. Is it safe, that is up to you, the driver. Is it going to be working the engine hard, yes.
'05 Dodge Cummins 4x4 dually 3500 white quadcab auto long bed.
'09 299bhs Tango.
scoop9 wrote: snip..... The towing capacity on the vehicle says 7500lbs......snip
Food for thought....: The published tow rating (capacity) is based on the "curb weight" of your vehicle.., which includes a 150lb driver, full tank of fuel, and all other fluids required for operation. The combined weights of your TV's options, passengers, and cargo will have to be subtracted from the published tow rating of 7,500lbs to get a more accurate tow rating.
Please note that one's tow rating and payload capacity are two different weight limit specifications.
hmknightnc wrote: 6800 lbs towing with a V6 gas engine. It really depends on your driving style and patience but my guess is you will not like it. I doubt that that combination will get out of drive and you'll have trouble maintaining interstate speeds
You know none of us actually answered your second question. For that trailer any of the modern (2010 and up) 1/2 ton trucks with the heavy duty tow packages will tow it. If you elect to go with 3/4 ton you will be happier with the larger frame, brakes, and stability. You don't need the expensive diesel option but do get a tow package. If your looking used and older than 2010 I would stick with a 3/4 ton
