RV.Net Open Roads Forum: Class A Motorhomes: re-paint, re-clearcoat
 > re-paint, re-clearcoat
CaptGEB
florida
Posted: 07/15/12 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
Does anyone know the cost to repaint a beaver 35'? I am looking at one that needs to be re clear coated over one of the two colors or possibly the etire coach repainted, not sure.
Also, do these coaches ever delaminate? I was told NO by the seller.
Thanks for any help.
Johnworth914
USA!
Posted: 07/15/12 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
Try zep or red max pro, much cheaper, and you'll be amazed at the result
Alaska is next! Still trying to fit the pontoons to the RV so We can get to Hawaii!
RayChez
Barstow, Ca. USA
Posted: 07/15/12 06:38pm Link  |  Quote  |  Print  |  Notify Moderator
A good paint job will cost you around 15K $$$
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar
3000 Allison Transmission
Neway Freightliner chassis
2013 Honda CR-V EX
Aventa II
FMCA member
jorbill2or
Oregon
Repaint 10 - 15 grand have no idea if re clear coat would work.
My post's are my opinion The advice, comments etc are free and worth what you paid
Bill
bluwtr49
Green Valley, AZ
Posted: 07/15/12 06:44pm Link  |  Quote  |  Print  |  Notify Moderator
Check in with the folks at he Beaver forum. Several have repainted. You could also ask BCS in bend as they have all the factory paint info.
BAC
Beaver Coach Sales
Good luck
Dick
2000 40" DP Beaver Patriot Thunder Cat C-12 425 HP, 1550 Tq
1997 Jeep GC Limited ---toad
2008 Toyota Tundra Crew Max Limited TRD (Retired)
2009 Cougar 268 RLS ~8700 lbs road wt (Retrired)
2006 Jeep Liberty Turbo Diesel.....TV in Training
slumberguy
okanagan canada
Posted: 07/16/12 09:24am Link  |  Quote  |  Print  |  Notify Moderator
Regarding your delam question, they are all fiberglass with internal steel or such framing with foam insulation..delam coaches used a luan foam filon type sandwich....consider yours built similar to a boat, with different framing materials....delam occurs for several reasons, and on the filon wall types, high temps such as with darker decals would cause separation, as would moisture infiltration, such as below a window..in these cases, when the filon wall was cut at the mfg for windows ect, it puts the bond at risk, and is a common failure point. Cant say delam WONT happen, but is usually localised due to improper fg layup, and is fixable, and wont cause a critical problem
CarlGeo
Central San Joaquin Valley, CA
Posted: 07/16/12 11:20am Link  |  Quote  |  Print  |  Notify Moderator
What year is your Beaver? I believe Beaver coaches had aluminum sidewalls until they were purchased by Monaco. Aluminum siding does not delaminate.
Check you sidewall material.
RayChez
Barstow, Ca. USA
Posted: 07/16/12 11:28am Link  |  Quote  |  Print  |  Notify Moderator
I believe the buttom quarter of the coach is aluminum, just like my Scenic Cruiser. The upper three quarters is fiber glass.
