Dave H M
IL
I usually see a post about the cost of an injector pump. Do any of the modern day diesels out there have an injector pump?
I am only familiar with the HEUI (hydrauli electric unit injector)system on the powerstrokes. no injector pump there for years.
recycler
michigan
had water a couple of times the light is nice just drained it and put in some diesel 911 good to go...
$800 injector pump i wish $1,200 was cheapest i could find a rebuilt, but the $62 a peice injectors makes up for it
1968 franklin 11fk
back to my 93 cummins
camping man
Central Fla.
Not so far , and 100k miles. Found about a pinch of what looked like sand in the bottom of my filter canister though.
05 Dodge CTD NV5600 6speed (100K Mile Club) / 97 Sprinter 5er
joe b.
Never a drop of water found in 135,000 miles on my 2002 Dodge Cummins. It had a Bosch high pressure injection pump, a VP-44 model as I remember
Water in the fuel was a problem with my 41 foot sailboat when in the Carribean. Had two large Racor filters that would often catch large amounts of water.
joe b.
Stuart Florida
Formerly of Colorado and Alaska
Chevy 3500 DRW Dmax CC - Rockwood 8281 SS 5th Whl & 2008 Lance 845 TC
www.pajbcooper.com web site
Alaska Trip 2011 posted
Colo-Utah-Ariz 2012 trip posted
"Without challenge, adventure is impossible".
ScottG
Bothell Wa.
Dave H M wrote: I usually see a post about the cost of an injector pump. Do any of the modern day diesels out there have an injector pump?
No, they have a much more simple (but have tighter tolerances) High Pressure pump.
Scott, Grace and Wesly
H0NDA eu2000i
mowermech
Billings, MT
No, I never have.
But then, when I was working on aircraft, we drained the sump on every fuel tank every morning as part of the daily inspection, and we VERY seldom found any water or dirt.
But, we did it every morning anyway.
CM1, USN (RET)
Toad: 2006 Jeep Rubicon LJ
mr. ed
Madison, SD (but usually elsewhere)
Chiefcpo wrote: Keep your tanks full and there is less surface area for condensation and Pray that the fuel stop has good filters/separators.
That's a good point and in fact I have been doing that all along, especially in cold, damp climates. I usually hang out in the desert southwest so the issue isn't as great but I still fill up when the tank is about half full (or half empty, depending if you're an optimist or pessimist )
Mr. Ed (fulltiming since 1987)
2007 Hitchhiker II LS Model 29.5 LKTG
2007 Dodge Ram 3500/6.7 CTD/QC/4X4/SB/SRW/6-speed man/Big Horn edition
jaycocamprs
Ringgold Georgia
Yes, Flying J exit 201 Jackson GA. Light came on within 20 miles, when I stopped and drained the filter I could smell the water. That was the 1st time I'd ever seen the DIC message. I get lot of false DIC messages now that quite a few of the retailers are now selling bio-blend. Even changed the sensor with no change.
2005 Silverado 3500 DRW
2011 Montana Mountaineer 285RLD
Wills250psd
walnutcove NC
My last 3 psd trucks have all had the WIF light come on. everyone had water in them and once after filling up I drained it 3-4 times and got 2-3 quarts of water out of it. I will never buy diesel from stores with above ground tanks as they seem to have more water in them, atleast in this area. I drain mine once a month or so because these newer trucks tend to have alot of problems if water makes it to the pump and injectors.JMO, WILL
Farmerjon
Niangua, missouri
Yes. once.
the truck started missing. We pulled over into a parking lot and I drained the filter bowl. I never saw any water but I didn't have the means to catch the fuel as it drained.
we were only 10 miles from home. Drove it home, drained the bowl again this time catching the fuel in a container,never saw any signs of water,replaced the filter. the truck has never acted that way again. but I assumed it had water in it.
edit
The WIF lite never came on.
00 F350 SC LB 4x4 DRW 7.3 PSD 6sp 3.73 DYI over load bumpers
99 Starcraft 953
87 F250 460 4x4 4sp 4.11 ex cab 8ft
95 jeep YJ 4cyl 5sp
69 f250 360 4sp
