shightower
fla
From Sioux Falls to Washington state... What would be the Flatest route? Worried I don't have enough to make it over/....
Pulling Northtrail FB21 (~25 ft) with E150 4.2 v8... Got this far from Florida Ok but??????
Thanks for your help
docj
Fulltime--Home is where we park it
I-90 going west is about as flat as anything out west will be. Interstate grades can't be any worse than 6%. Lookout Pass at the MT-ID border is a bit steep, but you'll be going down not up! To get anything much flatter you'd probably have to go south on I-15 at Butte to I-84 and that would add many miles to your trip.
Sandie & Joel
2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12
2009 Chevy Malibu LTZ with ReadyBrute tow bar/braking system
Official WiFiRanger Ambassador WFRAMB303
Follow our adventures on Facebook at Weiss Travels
paulj
Seattle
Where in Washington are you headed? Where we don't have mountains we have deep river canyons. I don't want to scare you away, but you can't enjoy the state without going up and down a bit. The pass climbs in Montana and Idaho aren't any worse than the ones in Washington.
On interstates you have a right lane where you can take your time.
WyoTraveler
Northwest, Wyoming
I'm confused again. Don't you have to go up the grade before you can come down the other side. From St Regis, Mt to Lookout pass you will climb about 2,000 ft. Really not a bad climb. Very slight grade through Butte, MT
2013 Monaco Monarch motorhome
2012 Jeep Wrangler toad
AC6CV/7 ex-W8RUR since 1954
path1
seattle
deleted
edited 03/10/13 11:45pm by path1 *
(To cheap to buy new)
1990 37 ft 5th wheel that hasn't moved since 1996 (our best home)
1997 33 ft trailer (winter home in much warmer climate)
2005 25 ft M/H (our "stand up B" for traveling)
jamesu
Snohomish, WA
I-90 all the way.
You'll have Lookout Pass at the MT/ID border, 4th of July Pass west of Kellogg, ID and Snoqualmie Pass over the Cascades heading into Seattle. Piece of cake.
My rig's longer than yours, I tow with an F-150 also, and I make it over the mountains just fine. I don't go as fast as a lot of other rigs pulling over the Passes, but my objective is to get over the top not to get there first. Leave the overdrive "off", use your head, and don't be in a hurry. You can do it.
2003 Ford 150 Supercrew, 4x4, 5.4L, 3.73 rear
2005 27' Trail Bay with pop-out
GO COUGS !
WyoTraveler
Northwest, Wyoming
Also run your 4 way flashers when going a lot slower than the normal flow of traffic up the grades.
jones4110
Champlin, MN
You also will want to be very diligent on descending these passes. Keep your gearing down and speed down. Auxillary braking is encouraged.
Joan and Bruce
05 Excursion 39L
powered by 350 KittyCATS on a Spartan
2010 Traverse LT toad (Blue Ox & Breakbuddy)
...and a "road dog" named Max and his gabby sister, Abby.
"May the wind be always at your back and your destination the one you chose"
shightower
fla
Thank you all very much.. I feel better about going now... I90 is the favorite.
We want to get to the coast and go down to california Thru Oregon. I also want to eat some of those famous dunginess crabs in Washington...
What do you all know about hwy 2 near the Canadian border? Steep or better?
Thanks again
paulj
Seattle
US2 is a frequent topic, particularly among those going to and from Glacier NP. Someone just mentioned driving it in a thread about taking the TransCanada back east (Canada section).
In terms of passes it may be easier than I90, since it has a low pass cross the Continental Divide just south of Glacier. But it's pass over the Washington Cascades is a bit harder than I90, but also a bit more scenic. It's perfectly flat until Glacier NP.
Portions of US2 are divided (but not limited access), other parts are still 2 lane.
