RV.Net Open Roads Forum: Melted extension cord? Please help, what caused this?
 > Melted extension cord? Please help, what caused this?
Page of 10
ch-ta
MN
Posted: 07/15/12 09:45pm Link  |  Quote  |  Print  |  Notify Moderator
Wow! Consider yourself lucky if the only loss was a cord.
2012 Chevrolet Silverado 2500HD CC 4WD LTZ
2013 Keystone Sprinter 266RBS
shaneallenhenderson
Manitowoc, Wisconsin
Posted: 07/16/12 05:44am Link  |  Quote  |  Print  |  Notify Moderator
boogie_4wheel wrote:
I'm going to disagree with everyone... It isn't that the cord was too small, there was a loose connection AT THE PLUG. The loose connection resulted in arcing, heat from the arcing melted the molded plug end. The cord could have been 1/0 and the plug would have still melted. A 15A plug is rated at 15A constant load, just like the 15A breaker that was feeding the outlet that the cord was plugged in to. There wasn't an overload condition, just a loose connection.
I do agree with having heavier extension cords. A 12ga cord is good, a 10ga is great. As load increases over a run, the resistance in the wire (even small resistance) will cause the voltage to drop. The size of cord, wire gauge, depends on the load and length of the cord. With nothing else running in the trailer, you could run most AC units on a 50ft 12ga cord without too much voltage loss, with the assumption that you don't have low house voltage to begin with.
This could be why it never happened all summer till now.
RoyB
King George, VA
Posted: 07/16/12 05:54am Link  |  Quote  |  Print  |  Notify Moderator
I lucked out and found some contractor grade real heavy duty 10 GAUGE (10-3) extension cords at a yard sale. These are not going to be cheap at the stores...
It is must have item however... One of my trailers is about 60-feet away from my garage connections and I use an 30AMP RV extension cord on the end of the 30AMP shore power cable and then connect to my 10-GAUGE extension cord going to the garage.
Also I could not get away with using the small round type RV30A-15A adapters. I had to get one of those 18-inch long "dogbone" type adapters. WALMART sells one in their RV parts section. The little round and triangle type black adapters always got hot on me after being run for a short time. Hook everything up and get you air conditioner going then go feel your connections everywhere after awhile and make sure nothing gets warm to hot on you. This can damage your air conditioner as well as when something gets hot it will drop your operating voltage feeding the trailer. I have an RV 120VAC plug-in meter in my trailer where I can see it in plain view so I get to observe the power reading easily. This meter has a GREEN scale marked on it which is the SAFE ZONE to be used when the air conditioner is running. Good to have around...
Use this type adapter...
DO NOT USE these type adapters...
this is the RV meter I use to monitor 120VAC line voltage with inside trailer. Don't use air conditioner if the reading is outside the green "SAFE ZONE" reading.
Been doing this for five years running my OFF-ROAD POPUP trailer and a Fifth Wheel trailer off separate 20AMP Garage 120VAC receptacles without any issues. I can run everything in the trailer including air conditioning but have to watch what is being turned on at the the same time. i.e. if I turn on the Microwave Unit when running the air conditioner it will trip my garage breaker. The main thing that is running in both my trailers in the converter/charger keeping the battery banks up and running and during the winter months I run a oil-filled electric heater set on low to keep things from freezing inside the trailer.
Its also kinda neat to have a quiet place to watch NASCAR and the grandkids love sleeping-over nights in the trailers. we do as well haha...
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
boondockdad
Dearborn
Posted: 07/16/12 05:59am Link  |  Quote  |  Print  |  Notify Moderator
In this day and age, where getting fleeced by insurance companies is legally acceptable... I recently learned, many (homeowner) insurance policies have clauses exempting the underwriter from costs associated with damage caused from using a 'temporary' electrical cord in a 'permanent' application. For example: using an extension cord for a window air conditioner... if you hadn't caught that flame-out, and it had burned down your house, you would be S O L.
Airstream 30' S/O Classic Limited + 8.1L Suburban LT
http://www.boondockdad.com
See you down the road!
2112
Posted: 07/16/12 06:09am Link  |  Quote  |  Print  |  Notify Moderator
You could make your own by measuring the length you need and go to HD to buy 2 conductor grounded (3 wires total) 12 or 14 awg SO cord and evironmental connectors. Black wire goes to the Gold screw. You don't save much money this way but you will have the proper length.
2011 Ford F-150 EcoBoost SuperCab, Timbrens, PullRite SuperGlide 2700 15K
2013 KZ Durango 1500 2857
Johnworth914
USA!
Posted: 07/16/12 06:10am Link  |  Quote  |  Print  |  Notify Moderator
dodge guy wrote:
Don`t just get a big cord! get one that is rated at 20amps which would be 12ga. wire. some cords just have a very thick covering that makes them look HD but are really still a 15 amp cord. and as far as the house outlet goes 15 amps is the max that can be put through it, I`m assuming it is a 15 amp circuit. so turn on nothing else when running the A/C!
And get the SHORTEST 20 amp cord that will work.
Alaska is next! Still trying to fit the pontoons to the RV so We can get to Hawaii!
Homer
Northeast Indiana
Posted: 07/16/12 06:16am Link  |  Quote  |  Print  |  Notify Moderator
A big ass cord needs a big ass source of at least 30 amp for an A/C. Another problem you could have is low voltage which will burn your A/C motor out. 110 volts 15-20 amps over any distance is not enough.
tenbear
Northern Vermont, USA
Posted: 07/16/12 07:03am Link  |  Quote  |  Print  |  Notify Moderator
I think it is interesting that only the hot, no pun intended, pin of the plug/socket is burned. Certainly the cord was too small, but I think something else was going on.
boogie_4wheel may have the answer, a loose connection at the plug causing arcing.
Class C, 2004/5 Four Winds Dutchman Express 28A, Chevy chassis
2010 Subaru Impreza Sedan
Camped in 45 states, 7 Provinces and 1 Territory
mich800
Pontiac, MI
Posted: 07/16/12 07:13am Link  |  Quote  |  Print  |  Notify Moderator
Are we looking at two different cords. The male end is two prong but the female end appears to have a ground. Were the two extension cords plugged to each other?
hottubkid
SCHAUMBURG,IL
Posted: 07/16/12 07:41am Link  |  Quote  |  Print  |  Notify Moderator
Those cords are rated 20 amp. How many amps are you pulling with the air and ????? I suggest another 30 amp cord . also what size breaker are you running off of?
hottubkid60193@yahoo.com
2004 SOUTHWIND 36E Tow 2003 CRV
Page of 10
