RV.Net Open Roads Forum: Sewer hose storage
Page of 7
Crodad
Lafayette, LA
Posted: 07/16/12 07:09am Link  |  Print  |  Notify Moderator
I replaced my factory bumper with a thicker steel bumper. My sewer hose no longer fits inside. I tried to use a 4 inch water pipe, but the end attachments still don't fit inside. What mods have you done to store your sewer hose?
2008 F-250 PSD 4x2 Lariat
2016 Silverback 31RK
Joy
Henderson KY 42420
Posted: 07/16/12 07:22am Link  |  Print  |  Notify Moderator
A 6 - 8" PVC pipe?
See ya' down the road!
Don-SCPO USN Ret.Corpsman
Joy-Ret.Off.Mgr.
Maggie-Chihuahua
Chrissie-Chihuahua
Lucy-Jack/Rat
'06 42' Allegro Bus DP
'06 Saturn Vue
LIFE ISN'T ABOUT HOW TO SURVIVE THE STORM BUT HOW TO DANCE IN THE RAIN.
Helmsey
Knoxville, TN
Posted: 07/16/12 07:24am Link  |  Print  |  Notify Moderator
I use one of these and it is currently zip tied to my rear bumer: Clicky It will get mounted permanantly in a couple weeks, haven't decided where.
I have these bungeed on each end to keep the slinky inside: Clicky
I can't remember if it is the 4 or 5 inch post, but it works rather well.
KK4PFX
2015 Chevy 3500HD LTZ Dually
2013 Sandpiper 365SAQ
jetboater454
Camping or home
Posted: 07/16/12 07:26am Link  |  Print  |  Notify Moderator
Maybe get the 4 to 5"(or 6) adapter for on the end.
Hunting down a 5th wheel toyhauler
'07 Toyota Tundra
Harley Dyna Lowrider
MegaJohn
NW Geogia
Posted: 07/16/12 07:41am Link  |  Print  |  Notify Moderator
I went the route of attaching a 6x6 vinyl post across the frame in front of the bumper. Our hose fits with a LOT of room to spare.
Search around... you'll find some other creative solutions people have used. [emoticon]
Happy Camping!
John.
* This post was edited 07/16/12 11:09am by MegaJohn *
Stock 2006 Dodge Ram 3500 MegaCab, 5.9L Cummins, Automatic, 2WD, Dually
- 30' 2006 Pilgrim Interntional travel trailer, dry weight ~7k pounds, GVWR ~9k pounds
- Husky weight distributing hitch, friction anti-sway control, electronic brake controller
downtheroad
Pacific Northwest
Posted: 07/16/12 08:00am Link  |  Print  |  Notify Moderator
I used a PVC fence post with end caps...attached to a frame cross member with super heavy duty zip ties all from Lowes...Works great and has not budged in 3 years.
Arctic Fox 25Y
GMC Duramax LBZ
Blue Ox SwayPro
W4MBG
Williamsburg, VA
Posted: 07/16/12 08:10am Link  |  Print  |  Notify Moderator
i used what downtheroad used, but it IS my rear bumper. my sister-in-law crunched the oem bumper, so i built a pair of adapter brackets and mounted the plastic fence post cover. the pic does not show the end covers, or the fact that i cut off the viable parts of the brackets and painted the new "step" white and added some non-skid to it.
1999 Winnebago Minnie, 29', Triton V10, mostly stock. So far...
TGarrett
TN/SC
Posted: 07/16/12 08:42am Link  |  Print  |  Notify Moderator
I added a roll of black 3ply garbage bags under my sink. When its time to store the hose one of them is tied up mounted in the compartment forward of my hookups with the hose in it and nothing else. Very Cheap, Very Easy, and no tools required... [emoticon]
Garrett
2004 Fleetwood Expedition 38N
Full Timer
Toad(still to be setup) 2011 Jeep Rubicon
2nd (to be put on double trailer with 1st when moving) 2008 Honda S2000
MegaJohn
NW Geogia
Posted: 07/16/12 11:12am Link  |  Print  |  Notify Moderator
I drilled access/drain holes in the post and using a long extention on my drill, attached the post directly to the frame rails with self tapping screws.
Happy Camping!
John.
tvman44
Southwest Louisiana
Posted: 07/16/12 11:33am Link  |  Print  |  Notify Moderator
I used a 5" PVC fence post with end caps...attached to the frame with super plumbers tape (metal strips with holes) and screwed to frame. I eve put a hinge on one end cap to be able to open the holder like a door and used a section of PVC rain gutter inside for a slide out tray and drilled several holes in the bottom of the tray and fence post to allow water to drain out and air to circulate to eliminate smell. I placed it right next to my sewer drain so it is very handy and easy to get to. I love it.
Papa Bob
Husky 16K hitch, Tekonsha P3,
Page of 7
