Open Roads Forum
Print  |  Close
Topic: Sewer hose storage
Posted By: Crodad on 07/16/12 07:09am
I replaced my factory bumper with a thicker steel bumper. My sewer hose no longer fits inside. I tried to use a 4 inch water pipe, but the end attachments still don't fit inside. What mods have you done to store your sewer hose?
2008 F-250 PSD 4x2 Lariat
2016 Silverback 31RK
Posted By: Joy on 07/16/12 07:22am
A 6 - 8" PVC pipe?
See ya' down the road!
Don-SCPO USN Ret.Corpsman
Joy-Ret.Off.Mgr.
Maggie-Chihuahua
Chrissie-Chihuahua
Lucy-Jack/Rat
'06 42' Allegro Bus DP
'06 Saturn Vue
LIFE ISN'T ABOUT HOW TO SURVIVE THE STORM BUT HOW TO DANCE IN THE RAIN.
Posted By: Helmsey on 07/16/12 07:24am
I use one of these and it is currently zip tied to my rear bumer: Clicky It will get mounted permanantly in a couple weeks, haven't decided where.
I have these bungeed on each end to keep the slinky inside: Clicky
I can't remember if it is the 4 or 5 inch post, but it works rather well.
KK4PFX
2015 Chevy 3500HD LTZ Dually
2013 Sandpiper 365SAQ
Posted By: jetboater454 on 07/16/12 07:26am
Maybe get the 4 to 5"(or 6) adapter for on the end.
Hunting down a 5th wheel toyhauler
'07 Toyota Tundra
Harley Dyna Lowrider
Posted By: MegaJohn on 07/16/12 07:41am
I went the route of attaching a 6x6 vinyl post across the frame in front of the bumper. Our hose fits with a LOT of room to spare.
Search around... you'll find some other creative solutions people have used. [emoticon]
Happy Camping!
John.
* This post was edited 07/16/12 11:09am by MegaJohn *
Stock 2006 Dodge Ram 3500 MegaCab, 5.9L Cummins, Automatic, 2WD, Dually
- 30' 2006 Pilgrim Interntional travel trailer, dry weight ~7k pounds, GVWR ~9k pounds
- Husky weight distributing hitch, friction anti-sway control, electronic brake controller
Posted By: downtheroad on 07/16/12 08:00am
I used a PVC fence post with end caps...attached to a frame cross member with super heavy duty zip ties all from Lowes...Works great and has not budged in 3 years.
Arctic Fox 25Y
GMC Duramax LBZ
Blue Ox SwayPro
Posted By: W4MBG on 07/16/12 08:10am
i used what downtheroad used, but it IS my rear bumper. my sister-in-law crunched the oem bumper, so i built a pair of adapter brackets and mounted the plastic fence post cover. the pic does not show the end covers, or the fact that i cut off the viable parts of the brackets and painted the new "step" white and added some non-skid to it.
1999 Winnebago Minnie, 29', Triton V10, mostly stock. So far...
Posted By: TGarrett on 07/16/12 08:42am
I added a roll of black 3ply garbage bags under my sink. When its time to store the hose one of them is tied up mounted in the compartment forward of my hookups with the hose in it and nothing else. Very Cheap, Very Easy, and no tools required... [emoticon]
Garrett
2004 Fleetwood Expedition 38N
Full Timer
Toad(still to be setup) 2011 Jeep Rubicon
2nd (to be put on double trailer with 1st when moving) 2008 Honda S2000
Posted By: MegaJohn on 07/16/12 11:12am
I drilled access/drain holes in the post and using a long extention on my drill, attached the post directly to the frame rails with self tapping screws.
Happy Camping!
John.
Posted By: tvman44 on 07/16/12 11:33am
I used a 5" PVC fence post with end caps...attached to the frame with super plumbers tape (metal strips with holes) and screwed to frame. I eve put a hinge on one end cap to be able to open the holder like a door and used a section of PVC rain gutter inside for a slide out tray and drilled several holes in the bottom of the tray and fence post to allow water to drain out and air to circulate to eliminate smell. I placed it right next to my sewer drain so it is very handy and easy to get to. I love it.
Papa Bob
Husky 16K hitch, Tekonsha P3,
Posted By: bondebond on 07/16/12 11:38am
I ended up attaching two 40mm ammo cans to my rear bumper with square U-bolts. The left side holds the black water hose, the right holds the gray water hose. I have an on-board black tank but external gray tank. The way the hoses fit in there, each end is always pointed up, so that minimizes dribble inside. I just pop the lids when I get home to allow for drying. The actual bumper houses the awning poles.
This space left intentionally.
2006 Fleetwood Sequoia and mods...one of the tallest highwall pop-ups on the planet after flipping the axle.
Posted By: C.B. on 07/16/12 12:24pm
5" X 5" fence post cover with PVC rain gutter inside.
Mounted it just ahead of tank drain.
C.B.
CBVP2004~FORD~F350~CC~LARIAT~SRW~SB~4X4~6.0D~
AUTO~PULLRITE 16K SUPERGLIDE~DEMCO GLIDERIDE~
PRODIGY CONTROLLER~C-BETR MIRRORS~EMS-HW50C~
CB Family Fleet
Butch/Barb=2013-Cedar Creek 36CKTS
Duane/Holli=2005-Cedar Creek 362BBS
Kris/Katy=2006-Cherokee 32B
Posted By: hershey on 07/16/12 01:02pm
I used a length of PVC pipe. I have a living room slide that the basement storage bays move with the slide.
I bolted the PVC pipe to the wall of the bays so that when the slide is in travel position, nothing is visible. When I setup for living, the end of the PVC pipe is visible and I can just slide my sewer hose in our out of the PVC pipe. Just a couple pieces of plumbers strap hold the PVC pipe in place.
hershey - albuquerque, nm
Someday Finally Got Here
Face Book Group: All About RVing and We Fly RC's
Expedition - Chevy Equinox
Posted By: Exocet on 07/16/12 07:27pm
I used a 4" vinyl post cover, with hinged covers on both ends. The covers are secured with plastic thumb screws. Holds 20 ft hose and fittings without any problems.
2008 Nissan Titan SE, Crew Cab, 4x4
Long Bed, Big Tow, Roadmaster Active Suspension
2009 Spree 318BHS
Reese Strait-Line 1200#
Tekonsha Prodigy
Posted By: mlts22 on 07/17/12 02:34pm
I'd take a look at this:
It can mount on the bumper and provide rust-proof storage of hoses, as well as the fittings. Stuffing the hose in the normal bumpers just means it will rust in the inside, then the hose abrades on the rusted sections causing pinholes.
I have a good amount of storage space, so I keep my sewage hose in a plastic tub. This way, it is well secured, easy to get in and out, and I can hose down the tub and hose with bleach water before putting away for storage.
Posted By: dkoley on 07/17/12 06:40pm
I used a 6" PVC pipe, glued cap on 1 end, threaded cap on the other. Drilled drain holes in bottom. 3 hoses plus fittings fit.
04 Tailgator Toyhauler
03 Harley ElectraGlide
04 F250 Diesel
?? 10ft popup TC
Posted By: thgoodman on 07/17/12 06:55pm
C.B.
I was very impressed with this design when C.B. first posted it (maybe a year ago?) and decided to build one for my rig, too. Problem is, nobody has given me a "round tuit" yet. [emoticon]
Tom & Jan
Full timers since April '06 - 1 fur kid (Archie - mini Poodle.)
2006 Beaver Patriot Thunder towing 2012 Subaru (4 down)
Started workamping Sept '07 - "This isn't too bad. Think we'll do it some more."
Posted By: C.B. on 07/18/12 12:53pm
New improved[emoticon] "round tuit's"[emoticon] for sale only 3 left $149.95 plus shipping. Cash only no CC or checks.[emoticon]
Posted By: WeBeFulltimers on 07/18/12 03:48pm
I have 1 "round tuit" that I will give to the first person that will pay shipping/"handling".
2012 Ford F-350 PSD SRW ** CURT Q24 ** 2018.5 MONTANA 3791RD
Posted By: retired-tech on 07/18/12 08:58pm
mine is a piece of drainage field pipe. it is slightly larger on the inside than regular plastic pipe. it also has holes in it that allow the pipe to breath so my slinky is always dry. the end cap is just a cap for the pipe with a single hole that you stick a slightly open cotter pin into. there are also slots cut for the tabs to slide into which holds it nicely at the end.
2014 North Country teardrop in wood
2009 Cougar 320 SRX
Posted By: Shadow_Grey on 07/19/12 09:02am
That will help offset the cost of the 5x5 fence post cover/caps and fancy drawer pull with custom gutter stops you put on the end of the gutter. [emoticon]
What is the big white PVC thing forward of the sewer pipe?
'11 F150 XLT Red Candy Met. Ecoboost 4X4 Screw 5.5', Max Tow,Reese R16k 5th wheel hitch,Ride-Rite Air Springs, E Rated Tires, Extang Cover
'13 Keystone Cougar X-Lite 29RES,triple slides,Mor/Ryde suspension, Reese 5th Airborne Sidewinder, 16" E rated tires
Posted By: C.B. on 07/20/12 08:15am
There's a roll of indoor/outdoor carpet 8' wide by 18' long stored in there.
C.B.
Posted By: Cummins12V98 on 07/20/12 09:48am
Coil it up in a 5 gallon bucket.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Posted By: dlturner00 on 07/22/12 02:34pm
C.B.
X2. Mounted mine on top of the.rear bumper.
2004 F350 CC 4WD DRW Powerstroke
B&W Companion Hitch
Prodigy Controller
2013 Cedar Creek Silverback 35QB4
Posted By: CTD2005 on 08/23/12 08:49pm
westend wrote:
CTD2005, what size is that PVC fence post? I have a 4" pvc fence post and the round Rhino fitting is 4 3/8", won't fit inside with the hose.
dlturner00 is correct, it's 5". I also got the fence post from HD and the gutter from Lowes. Everything else I used was already laying around the house.
Nick and Suzanne
The Pugs - Tuff, Raphy
Boerne, Texas.
2009 Heartland Sundance
2005 Dodge 2500 QCSB 4X4, 5.9L CTD
Posted By: CTD2005 on 08/23/12 08:52pm
westend wrote:
I bought the gutter, the gutter end caps (3), the 4 3/4" PVC fence post, and the fence post caps all from Lowes. I had all of the other bits at home. I have everything built, just waitiing for paint to dry before installing.
Don't forget to post up some pics.
Posted By: down home on 07/22/12 10:52pm
You can buy the pvc pipe type thing from CW, or could, with mounting base and caps that seat with a quarter turn. Designed to be mounted under a towable or anywhere.
Posted By: BarneyS on 07/23/12 07:37am
Sewer hose storage from Camping World.
Barney
Hensley "Arrow" 1400# hitch
2016 Ram Laramie 2500, 6.7L CTD, 4x4, SB
Posted By: Dave-Sparky on 07/30/12 09:02pm
I just finished and took my storage tupe on the road this weekend.
I used a piece of 6" PVC pipe, an end cap and a cleanout fitting with a plug. I used some kindorff channel and straps to fasten it to the frame. Took about an hour to install and total cost for all the parts was under $60.
This is the capped end
And this is the accessible end.
Dave
Dave and Colleen
Colleen's Beach House
1991 Dutchman TT 24FK
2007 Chev Avalanche AWD
Posted By: Tango, AE7UI on 08/09/12 06:54am
I finally got around to building the hose carrier designed by C.B.
5" fence post and vinyl gutter inside.
Can't wait to try it on next months trip
2007 Tango 2660RKS Fifth Wheel, 2006 Chevy D/A 3500 with service body,
Posted By: Shadow_Grey on 08/09/12 07:59am
I too have used C.B.'s design. Special thanks goes out to him for this idea.
Will post pix soon.
Posted By: ford coupe on 08/09/12 03:46pm
used system from c.w. used square u-bolts from tractor supply-bolted to square rear bumper, works great
Posted By: Ductape Dave on 08/11/12 01:23pm
I have 3 pcv square tubes stacked on top of each other with 1" gaps between them on top of the steel bumper. With the pvc caps hinged with latch and locks with gutter trays. They are about 5' long to leave clearance for the tail lights. They look and work great for my rhino hose, 2-5' extensions, short dump hose, gloves and pliers. Thanks to C.B.'s idea! I then use a pvc gutter tray in the steel bumper for my extra awning poles and broom handle without getting scratched or rusty and never have to reach in to get something. [emoticon]
Posted By: covered wagon on 08/11/12 09:00pm
This one really needs a picture bad, when you get a round toit would be good.
Posted By: CTD2005 on 08/12/12 06:29pm
I used the pvc fence post style mounted next to my sewer hook up. Has plenty of room for my sewer hose kit, and the 10' extension hose as well as the ends. Works out perfectly.
Moderator edit to re-size pictures to forum limit of 640px maximum width to avoid scrolling.
* This post was edited 08/12/12 07:25pm by an administrator/moderator *
Posted By: westend on 08/13/12 07:05pm
'03 F-250 4x4 CC
Posted By: dlturner00 on 08/13/12 07:58pm
It's a 5" fence post cover. I had to get mine at Home Depot but I had to get the gutter to go inside at Lowe's. Neither place carried both items.
Posted By: gkainz on 08/14/12 01:30pm
Story of my life ... and sometimes it takes a trip to Ace to round out the great parts and pieces easter egg hunt for most of my projects. [emoticon]
'07 Ram 2500 CTD 4x4 Quad Cab
'10 Keystone Laredo 245 5er
Posted By: westend on 08/14/12 01:36pm
Thanks, guys, I'm just about out the door to get a bigger post and gutter, that idea is just too cool to pass up.
Posted By: Tango, AE7UI on 08/14/12 05:22pm
I had the same problem; HD for the fence post and Lowes for the gutter.
Posted By: Shadow_Grey on 08/15/12 06:46am
Neither Lowes nor HD carried 5" PVC fence post...went to fence company, then Lowes for gutter. About 50 bucks stuck in the whole thing.
Posted By: westend on 08/22/12 09:46pm
Posted By: Brandon327 on 08/23/12 06:59am
If you have a y fitting where do you store it?
2013 gmc 3500 hd cc Drw 4x4
2016 Dutchmen voltage 3990
Posted By: thetechie01 on 08/25/12 10:20am
I have seen a lot of different ideas on how to store the stinky slinky, and I took the one I saw that I liked the best, which was posted by C.B., and took some of my own ideas to it and came up with this!
It's a 4-3/4"x4-3/4" vinyl fence post from Lowes with vinyl gutter inside. I then cut some laminated shelving pieces to fit the contours of the inside of the gutter to section it off for "compartments" for the different sections of hose, fittings etc.. Then took the post caps, riveted hinges and latches on and riveted them on to the fence post. Here is the finished product, it stores my 15' Rhino hose, end fitting, 45 degree fitting, and 5' extension. I then mounted it under the trailer to the frame, right next to the sewer connection, so everthing is right there. I can access it from either side of the trailer, as both ends have hinges and latches.
2007 Coachmen 31DSB pulled by a 2012 F350
Posted By: BarneyS on 08/25/12 01:35pm
Very nice! Thanks for the post and good pictures.[emoticon] [emoticon]
Posted By: westend on 08/25/12 03:12pm
Ok, another man's version of the storage system:
You can see that I have the caps hinged from the side, that is so I could attach the fence post with no interference. I mounted it on the bumper because I'm doing some underbelly work on the sanitary system and I didn't want the storage tube in my way.
The same locking clasp:
I made the mounting brackets out of 1/8" aluminum plate. Cut threaded rod to length, cut beauty tubing also out of aluminum. All of it was painted with a primer coat of "Bulldog Adhesion Promoter" (an auto body thing) and Rustoleum Universal Any Surface paint. If I have time, I'll shoot on a couple of coats of clear to help durability.
First, thanks to CB, the originator of this system, AFAIK and all those that have tread the path previously. Your examples were well done and gave me the easy route.
A few notes about the materials: Maybe I bought something different or Lowes has changed stock but the 5" fence post is actually 4 3/4" exterior and 4 1/2" interior dimension. I tried to use the vinyl end caps for the gutter as divider and end cap and the gutter wouldn't fir into the post. I fashioned plywood caps and divider of 4" in length and the gutter now slides well. A builder will also have to think of how the fasteners are directed because in certain orientations the fasteners may interfere with the gutter sliding through the post.
Might as well ask about this since maybe you guys have done this: Is it possible to remove and replace Rhinoflex fittings on the end of the hose? I bumped into a good deal on the Rhinoflex kit so purchased another. I am thinking about removing the dump fitting end and replacing it with a Rhino "Lug fitting" so I can mate the two hoses together. That will give me 30 ft. of dump hose, I scoff at your badly engineered dump locations,lol.
Posted By: CTD2005 on 08/25/12 05:55pm
Everything looks great, nice clean job! Yes the ends do remove. If I remeber correctly I think they are reverse thread. I used a 5' extension, replaced the ends with the same as the main kit and keep it for use with my blue portable tank. Works out great.
Posted By: westend on 08/25/12 08:41pm
Thanks, CT. I could order up that lug end for the hose, then. Another 15' footer won't fit in the gutter so I may be better off just getting the 5' extendion and leaving this new one intact. though. That way I could have one for just a tote, also.
Posted By: CTD2005 on 08/26/12 05:00pm
Your welcome, the 5' extension works out great because it's always there to use as an extension still if you need it. Just swap the ends back and your good to go. I keep a small plastic container in the basement with my rarely used sewer hose ends.
I use a small cooler to keep all my fresh water items in. Then it doubles for drinks if we need it.
Posted By: notruffinit on 08/28/12 08:29am
I got a 5 gallon bucket with a lid. Curl the slinky into it, slap the lid on and set it in the basement. No mess and even if there is a little water in the slinky it stays in the bucket. Every now and then put water in the bucket with some detergent and soak and wash the entire mess down. I also keep my rinse hose in the same bucket.
'11 Ram 3500 Cummins
'12 Cameo 34SB3
Posted By: tracyb1101 on 09/02/12 11:12pm
We did ours today with the gutter inside of the 5x5. I still have to add the dividers to the gutter ($3.00-10' for the gutter at Menard's)We added two 1-4x4 for indoor/outdoor rug & 5x5 for sewer hose. Looking at the painted post I think tomorrow that will be my project I want them to blend in better. We used U-Bolts to connect it to the bummer and it lays on top of the bike rack's extra spacing. then we connected smaller U-Bolts to connect the two together. After seeing the spring latches I think I am going to take my long bolts I have on the caps off and replace with them they seem much easier. thanks for your photos.
Here are mine attached to the extra space between the bumper and the bike rack.
TMcB & VJK
plus 2 kids and 2 boxers
NW Indiana
Camping and geocaching with a smile....
2007 Fleetwood Orbit 240 XPS
1999 Star Craft Venture popup (Sold 9/15/12!!!)
Posted By: CTD2005 on 09/03/12 06:22am
Nice job, looks great! It will be so much more convenient.
Posted By: tracyb1101 on 09/05/12 12:45am
well put some the other fasteners on and spray painted them to match the bumper..
Close up of the new fasteners I like them better then the screw though the lid.
tomorrow I'll change the other one and move on..
Posted By: Chevyman2006 on 09/29/12 04:15pm
Hey guys...got a question.
I took our 5th in for service work to be done and on the way home, picked up the fence post and gutter.
Are y'all using the entire length of fence post? I should have measured, but didnt. If anyone can provide a measurement would be great, that way I can have it done and ready to go on when I pick it up.
Thanks
2006 Chevrolet 2500HD 4wd CC/SB Duramax/ Allison
2009 Keystone Copper Canyon 298fwbhs
Wife and two BEAUTIFUL girls!!
Nights camped in 2010: 64
Nights camped in 2011: 58
Nights camped in 2012: 75
Posted By: thetechie01 on 09/29/12 05:49pm
I used the entire length. Seemed to be right about perfect.
Posted By: westend on 09/30/12 07:53am
Thanks
You'll need to know the width of your TT and how much you wish to have the fence post in from the sides. The Rhino hose and fittings can fit in about 5 1/2' of the gutter. The fence post is easy to cut with conventional tools.
Posted By: texasjayco on 09/30/12 07:20pm
Are y'all finding the fence post in stock at a big box store (Home Depot, Lowes, etc)? I've looked around the Austin area and can't seem to find any place that carries them in stock.
Thanks,
Mark
2010 Sierra 355 QBQ
2011 Ford F-350 Lariat Diesel Dually
PIC OF BOTH
My home town
Posted By: CTD2005 on 09/30/12 05:44pm
Thanks
I used the entire fence post length, and cut the gutter to fit it. Was a perfect fit on my 5th wheel.
Posted By: Chevyman2006 on 09/30/12 07:30pm
Thanks,
Mark
I got mine at Lowe's. The fence posts are going to be in the outdoor department (pavers, wall blocks, chain link, etc). That threw me off at first.
Posted By: CTD2005 on 09/30/12 08:02pm
Thanks,
Mark
The Home Depot in my area didn't carry them in stock so I had them order it for me.
Posted By: no2tracks on 09/30/12 09:40pm
I got mine at Home Depot in the fence aisle, with the chain link and wooden gate stuff.
1987 21'Kit Companion
Posted By: Shadow_Grey on 10/01/12 06:07pm
Our big box stores do not carry 5" square fence post cover. I had to go to the plastic fence company close to my house. Bought a 10' length and cut it off. The gutter inside fits perfect.
Print  |  Close
