RV.Net Open Roads Forum: Do you balance and rotate your trailer tires
Search only in Toy Haulers
 > Do you balance and rotate your trailer tires
N-Trouble
NorCal
Posted: 07/17/12 10:26am Link  |  Print  |  Notify Moderator
Like you would your car/truck?
2015 Attitude 28SAG w/slide
2012 GMC 2500HD SLT Duramax
B&W Turnover w/Andersen Ultimate 5er hitch
skipnchar
Topeka or somewhere else
Posted: 07/17/12 10:33am Link  |  Print  |  Notify Moderator
ON your car or truck, you have both steering and driving wheels. All are equal on a trailer so generally no rotation is necessary. The exception might be if your axles are not properly aligned and you're getting uneven wear (but it would always be BETTER to correct the alignment issue). Balancing any wheel is always a good idea to maximize your tire wear.
DutchmenSport
Between Anderson, Pendleton, & Lapel, Indiana
Posted: 07/17/12 10:39am Link  |  Print  |  Notify Moderator
balance yes, rotate no.
My tires dry-rotted LONG before they needed any kind of rotations. Replaced tires only once on the current TT. Balanced yes. It came standard with the tire, so why not?
DutchmenSport
2013 Outback 298RE
2014 Chevy Silverado 3500 Duramax Dually
1400 / 14000 Equal-i-zer Weight Distribution
2 Dachshunds, 1 cat, 2 old folks and lots of love!
ch-ta
MN
Posted: 07/17/12 11:09am Link  |  Print  |  Notify Moderator
I don't unless I start to see tread wear.
2014 Bridgeview BV-40CK2BH (Park Model)
nypatnva
Amelia Ct Hse Va
Posted: 07/17/12 11:17am Link  |  Print  |  Notify Moderator
Depends, 12 & 13 inch....No. My Airstream (15") yes. No to rotation
2000 Chev 1500 Silverado
1965 22' Airstream Safari (restored)
Yamaha EF2800i generator
Prodigy
2012 Old Town Stillwater 14 canoe
1970 Serro Scotty Highlander (restored)
1978 Serro Scotty Highlander (restored)
troll3193
SouthWest, MI USA
Posted: 07/17/12 11:19am Link  |  Print  |  Notify Moderator
yes and yes.
I rotate when I do my bearings every 2-3 years
Bryan
2006 RAM 3500 MegaCab w/Cummins Turbo Diesel
Mopar Exhaust Brake
2004 Dutchemen 31BK
mapguy
Puget Sound
Posted: 07/17/12 11:21am Link  |  Print  |  Notify Moderator
On triple axles seem to need rotation to have even tire wear. Tandem axles don't seem to be as picky unless nose high -then rear tires wear much faster than fronts
Old-Biscuit
Verde Valley
Posted: 07/17/12 12:08pm Link  |  Print  |  Notify Moderator
Balance yes....rotate no
BigDogF250
Ramona, CA
Posted: 07/17/12 12:46pm Link  |  Print  |  Notify Moderator
Yes and Yes. Triple Axle and twisty roads cause faster wear on the rear axle. Rotate them every year, middle to back, back to front, front to middle. Same side only on the rotation.
They last about 3 years before wearing out. Did I mention twisty roads that are very fun on a motorcycle.
Don't take life too seriously, it's not permanent.
06 Weekend Warrior FSC3200, Axles flipped, Bridgestone Duravis Tires
2005 Ford F250 PSD 4x4
07 Yamaha YZF450 White/Silver, 94 Husqvarna WXC610
2008 Polaris RZR 800, 2011 Honda CBR1000RR & one Goffin Cockatoo
ssduane
San Diego, Hooli #380
Posted: 07/17/12 01:16pm Link  |  Print  |  Notify Moderator
yes and yes. rotate when I can since I never know if the trailer load is even, and piece of mind. As for balancing yes I balance the wheels and also use balance plates because after talking to my dad (30plus years in RV service) he mentioned the drums are not balanced either. Now I know they are quite smaller but they do weight quite a bit and rotational mass is a lot more, plus I got them free. [emoticon]
06 GMC2500HD DMAX/AL, 4XCC/SLT SRW
07 Cherokee Wolfpack 295
2012 KTM 450 XC-W
Raptor 778cc SE2
KFX434 her's
Z434 son's
DINLI DB90
