hedge
Airdrie, Alberta, Canada
I just bought some scissor steps for my camper, they were used so I don't have any instructions with them.
I have a bracket just under the camper door that has upward hooks on it, I assumed this would be how the steps attached. I've found the steps are narrower than the hooks.
Am I missing another bracket or something to attach it to the camper? I can't do a direct bolt on, they'd stick out too far. For safety do the steps just sit on those steps or what keeps them from coming unattached?
Bedlam
PNW
I have the Glow Steps made by Torklift and they use a u-shaped bracket bolted to the camper and quick release pins to remove the steps. What brand do you have? Can you post a link?
Arctic Fox 811S-Ford SuperDuty F250-Honda Passport C70B-Interstate 20' Car Carrier-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX-Tank Touring 150SE-VW 1300sp-VW Jetta TDI
View my profile for rig details.
Super_Dave
Sacramento, CA
hedge, did you have a single flip down step that came with your camper? I chose to utilize my stock step mounting spot to mount my scissor steps. Similar to your hooks, I bought a piece of metal angle that worked.
Truck: 2006 Dodge 3500 Dually
Camper: 2007 Eagle Cap 850
Boat: 2003 Jetcraft 2125 - Yamaha 150 HP & 8 HP Kicker
Bedlam
PNW
I like that setup, but my DW did not like the large step between the bumper and doorway due to the basement height. That u-shaped bracket attached to your angle is bolted just bellow my door frame and has quick release pins so the steps go all the way to the door using the same tread pitch.
hedge
I'll have to take a picture when I get home. It's an older camper, '99 Adventurer 810WS. It doesn't have a bumper at all and didn't come with any steps.
msiminoff
Silicon Valley, CA
Here's what I did:
Cheers
-Mark
'04 Alpenlite Saratoga 935, 326W of solar, 300Ah Odyssey batt's, Trimetric, Prosine 2.0
05 Ram3500, Cummins, Goerend Trans, Vision 19.5 w/XDE's, Dynatrac Hubs, RR airbags w/ping tanks, Superhitch, Roadmaster Swaybar, Thuren trackbar, RS9000XL/MyRide
hedge
Here's the pics, as you can see it has a bracket already mounted that has hooks on it. I think I can build a bracket to drop into the hooks, just not sure what's supposed to keep it there other than gravity.
weymard
NORMANDY
I have the same bracket, I do not know how to do to fix the step. I thougth drill to holes and screw the step, but need to fix bottom when drive, not sur how to fix it and keep an easy deployment.
Lance 815 2007
France, Normandy
LanceDuyen
Houston, TX, US
That flat hook setup is what I used to have any it really annoyed be. It always seemed like the step was uneven and about to pop out of one side. Not to mention I had to put the steps inside for transportation. I bought some glow steps and I sure like them. The bracket they use has pins and will not come loose. You can also install some locks in place of the pins.
Mello Mike
Mesa, AZ
Here's my Glow Step Setup:
Glow Step Installation
2011 Wolf Creek 850N/Polar Cub/240w Solar/2-6v Lifeline AGMs/Morningstar Sunsaver w/RM-1 & SureSine-300 Inverter
2011 Ford F-250/6.2L/3.73/Bilsteins/Air Bags/Torklift TD w/Fastguns
2004 Jeep Wrangler/4.0L/5-spd
US Navy Ret.
My Truck Camper Adventure Blog
