RV.Net Open Roads Forum: Travel Trailers: Lab Sealant Question
 > Lab Sealant Question
clearnetedm
Alberta
Posted: 07/18/12 01:38pm Link  |  Quote  |  Print  |  Notify Moderator
Hey folks I hope you can help me out here. I'm getting some conflicting answers. I wish to do some roof maintenance by adding some additional lap sealant. I was told by the dealer to use their Dicor 502-LSW stuff which I purchased. However as I started to read things I noticed that my Rockwood has a TPO roof and it says not to use any PETROLEUM DISTILLATES. I noticed though that the Dicor 502-LSW has a warning saying it contains PETROLEUM DISTILLATES in the form of Naptha. I found a tube of Dicor 501 as well and it says it's good for EPDM and TPO roofs. But it also has the "contains PETROLEUM DISTILLATES". What gives?
2008 Ford Expy EL
2012 Rockwood 2601S
ronfisherman
SE Michigan
Posted: 07/18/12 02:05pm Link  |  Quote  |  Print  |  Notify Moderator
From Dicor site.
Note: Dicor Products Lap Sealant contains a type of petroleum distillate used strictly in the curing process. As the Lap Sealant cures, the petroleum distillate evaporates. This will not harm or cause permanent damage to your roof.
Kodiak Chassis Class C Forum
harold1946
Surprise Arizona
Posted: 07/18/12 02:13pm Link  |  Quote  |  Print  |  Notify Moderator
ronfisherman wrote:
From Dicor site.
X2.
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer toad
clearnetedm
Alberta
Posted: 07/18/12 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
ronfisherman wrote:
From Dicor site.
Oh I guess I didn't look hard enough. Thanks for finding that for me as I was loosing my mind. Started with the difference between 501 and 502 sealant.
ronfisherman
SE Michigan
Posted: 07/18/12 02:41pm Link  |  Quote  |  Print  |  Notify Moderator
I did a Google search. With luck this tech page came up.
Tech Report: Taking care of your RV's rubber roof The Note is in FAQ.
clearnetedm
Alberta
Posted: 07/18/12 03:30pm Link  |  Quote  |  Print  |  Notify Moderator
I actually happened to cross this page and this quote didn't help
One supplier of cleaning products told me that their roof treatment had only a very small percentage of petroleum in the neighborhood of 10 to 30 percent. Is a small percentage like that OK to use on my roof?
No. Usually the percentage is given based on weight. Since petroleum distillates are significantly lighter, the reality is that 30 percent by weight might be 40 percent or more by volume! THERE IS NO LEVEL OF PETROLEUM DISTILLATES THAT IS RECOMMENDED.
harold1946
Surprise Arizona
Posted: 07/18/12 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
The Dicor Corporation makes both TPO and EPDM roofing materiale. Their sealants are compatible with both.
