RV.Net Open Roads Forum: Slideout won't close all the way shut on one side
 > Slideout won't close all the way shut on one side
maggie61
Renfrew, Ontario
Posted: 07/18/12 04:48pm Link  |  Print  |  Notify Moderator
When our slideout is closed, it doesn't close tight on one side and my husband thinks it is out one or two cogs on that side. Is he able to do anything to fix it himself?
maniac007
South Carolina
Posted: 07/18/12 05:19pm Link  |  Print  |  Notify Moderator
Not sure what RV you have. If he is mechanically inclined he can pull the roll pin on eather gear and reset it to match the other side. Before he does this, he needs to check ALL the bolts and nuts on the outer eds on both tubes and make sure none has loosened up or slipped.
02 F350SD 7.3 CC 4X4 DRW, 06 Cougar 314EFS Eastern Edition
maggie61
Renfrew, Ontario
Posted: 07/18/12 06:13pm Link  |  Print  |  Notify Moderator
It is a 2012 Coleman (Dutchmen) 5th wheel RV
57 Panhead
Foothills of the Sierra Nevada
Posted: 07/18/12 06:15pm Link  |  Print  |  Notify Moderator
Had this happen one time recently on our Jayco and couldn't figure out why until the end of the next trip. While on the roof cleaning off the slide roofs I saw a Magnolia cone on the slide roof that was smashed up. It blocked the slide enough to keep it from closing flush on one end. Removed it and all is good now. You see, we have a big Magnolia in front of our house and when I had the trailer opened up in front of the house a cone had fallen onto the slide roof and went unnoticed by me. Was lucky that it didn't damage the bulb seal or any of the flange.
Get up on the roof with the slide open a bit and check for an obstruction, it could be that simple.
Hope it's something simple
Steve
Retired Teamster
2012 Jayco Eagle Superlite 31.5RLTS
07 F250 PowerStroke
U Y B
Ron Nielson
Berryton, KS
Posted: 07/18/12 11:48pm Link  |  Print  |  Notify Moderator
Absolutely! Figure out what kind of a slide system you have (mfgr and model) and go to their website and look for the instructions on 'timing the slide', making it go in and out in an even manner. They're all similar, but also a little different. Will help to have an assistant to do some of the tasks.
schlep1967
Harrisburg, PA
Posted: 07/19/12 07:03am Link  |  Print  |  Notify Moderator
It's a 2012. Take it back to the dealer and make them fix it for nothing. It should have been right when you got it. If hubby trys and screws something up it will not be covered by warrantee.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
maggie61
Renfrew, Ontario
Posted: 07/19/12 07:13am Link  |  Print  |  Notify Moderator
It was ok when we bought it, it is just the second last time we were out camping, when we got home we noticed it wasn't closing tight on the left side
schlep1967
Harrisburg, PA
Posted: 07/19/12 07:29am Link  |  Print  |  Notify Moderator
It may have "looked" right when you got it but something was not right or you would not have this problem. It should still be under warrantee and the dealer should have no problem with fixing it. If the dealer is a long ways off and there would be a large cost involved to get there, then you might consider fixing it yourself.
On another note, are you sure there is nothing inside blocking the slide from going in? We have to turn our recliners sideways and slide them back against the wall to get out slide in. We always watch them when operating the slide and have saved damage twice when the slide caught on them.
phillyg
SWFL
Posted: 07/19/12 08:10am Link  |  Print  |  Notify Moderator
If it's a Lippert slide system they seem to have fairly good manuals on their website. But, if it's still under warranty, get the dealer to do it.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
maggie61
Renfrew, Ontario
Posted: 07/19/12 08:27am Link  |  Print  |  Notify Moderator
I don't know what slide system it is. Where do I find out? It is a Coleman (Dutchmen) make of RV
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
