RV.Net Open Roads Forum: Hi all....new here. Need some help with my Weekend Warrior
Search only in Toy Haulers
 > Hi all....new here. Need some help with my Weekend Warrior
joe blow
in a city
Posted: 07/18/12 06:15pm Link  |  Quote  |  Print  |  Notify Moderator
Hello,
I have a 2008 CR3705 Weekend Warrior. For the most part the trailer has been fantastic. I took it out last weekend and got to really use the A/C's. I rarely do since I usually camp in the winter.
Anyway, here is what I experienced:
The front A/C (bedroom) fan operation, although on HIGH, was blowing really LOW but still COLD. I removed the sponge filter and cleaned it. The unit was off for about 30 minutes. When I restarted the unit it worked great for the remaining two days. I am not sure what the issue with this unit was but maybe you guys can offer some advice.
The main A/C in the living area worked flawless the entire trip. When I got home and started to unload the trailer, I started the generator and fired it up. After a short while the darn thing started blowing WARM but the fan operation was normal. Any ideas on this one?
I did have a few questions for those that are familiar with these units:
Are these units serviceable with normal A/C gauges or are they sealed units that require special skills/procedures to service?
If the units are serviceable, can anyone please tell me the HIGH and LOW pressures for recharging the system?
What freon type do these units use...R134, R12 or R22?
I would like to start with pressure checks and any obvious problems. The units are run frequently in my driveway and have always worked, this is the first time I have run them for days on end and the units gave me issues.
Thanks for the time and help!
Joe
stripit
Casa Grande, AZ
Posted: 07/18/12 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
They are not serviceable with the traditional set of gauges.
Stacey Frank
'04 Mobile Suites 36 TK3 #1341
'99 Int'l 4700 Lo Pro MDT
'08 Lexus 400H
joe blow
in a city
Posted: 07/18/12 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
Oh man....so my only option is to have it serviced?
Any idea what might be going on with my units? Low pressure perhaps?
Thanks
Joe
allcool
sFL Glamis PHX
Posted: 07/18/12 09:43pm Link  |  Quote  |  Print  |  Notify Moderator
joe blow wrote:
Hello,
Sounds like a clogged or dirty filter that you took care of.
Not enough info. Was the compressor running?
Joe
Well, the only thing stopping you from putting your gauges on it might be no service valves. Many of these type units have no service valves from the factory and are charged by a charge tube that is crimped off and welded shut.
If your unit was service before it might have valves in it now.
Some techs will silver braze valves in if they are evacuating the system. If just wanting to check pressure and super heat/sub cooling, bolt on self piercing tap a line valves can be used. They do tend to leak eventually, sometimes.
If the unit is running(comp&fans),and the suction line is coming back cool, probably not a freon problem.
Check for compressor and fan both running.
Check both coils for being plugged or dirty and clean them as needed. Don't brush them. Use low pressure water from a garden hose and nozzle with coil cleaner.
Depending on your unit and its age it could have r22 or r410, should say on the unit somewhere.
jmo
2007 WW FSW3200
RZRS k&t Turbo
2 LT500
1 Lt500 hybrid
big buford
Buena Park, Ca
Posted: 07/19/12 08:16am Link  |  Quote  |  Print  |  Notify Moderator
A friend just went thru a simular senerio. A new thermostat fixed him up.
04.5 GMC 2500HD D/A
06 38 CKS Dune Chaser
Chenowth 4-seat Subaru pwr
06 Rhino
06 Raptor 700
Beautiful wife that's much nicer than me
joe blow
in a city
Posted: 07/19/12 09:25am Link  |  Quote  |  Print  |  Notify Moderator
I am going to check some of the suggested stuff out....very good information.
Thank you
