RV.Net Open Roads Forum: Just how noisy is a 98 Dodge Cummins 12 valve inside?
Search only in Tow Vehicles
 > Just how noisy is a 98 Dodge Cummins 12 valve inside?
Page of 6
jspringator
Versailles, KY 40383
Posted: 07/19/12 12:41pm Link  |  Quote  |  Print  |  Notify Moderator
Got a line on an upscale 98 Cummins CTD (has power leather seats).
Just how noisy are these things on the road with the windows up? I had a 99 Suburban 6.5 and it wasn't loud (while on the road) at all.
I understand I will have to turn off the truck going through drive throughs. I'm just concerned about noise while going down the road.
Jim & Sherri
05 Jayco Eagle 308 FBS, Dual Cam
2001 Ford Excursion 4.30 LSD,V-10,2WD,RAS,5-Star tuner
Honda EU2000 & EU1000 gensets;
2000 watt Tripp-Lite inverter/charger APS 2012
Saturn SD365 inflatable, 15 hp 2 stroke Yamaha
"Scout" Springer Spaniel
rhagfo
Portland, OR
Posted: 07/19/12 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
Well my 01 24 valve is noisy with the windows down, but not bad with them up. I also shut down at drive ups and always stay a truck length back of the person being served when in line.
If it is an SLT Laramie it will likely have a noise reduction package, extra insulation.
Russ & Paula
The Beagles Hedwig and Precious.
Portland, OR.
2005 Copper Canyon 293 FWSLS
2001 Dodge 2500 4X4, 5.9 Cummins 5 speed, 3.55 gears, Pacbrake, Power Puck, 258K
catfishmontana
montana
Posted: 07/19/12 12:57pm Link  |  Quote  |  Print  |  Notify Moderator
My fathers 01 is surprisingly quiet inside the cab. The aftermarket air filter makes for more turbo noise than engine rattle inside the cab.
Mine ~ 2011 Ford F350 6.7 SRW, CC/LB, Lariat, Navigation, FX4, 20's, Black with Black Guts.
Hers ~ 2012 Ford F150 Raptor, Blue Flame, Crew Cab, 6.2L
GONE!!! 2010 Chevy Tahoe LTZ 5.3 ~ Most worthless POS ever!
2007 Keystone Montana Mountaineer 30FKD TT
Trail-Mate
Frederick, MD
Posted: 07/19/12 01:01pm Link  |  Quote  |  Print  |  Notify Moderator
Its about as loud as my 7.3 is or my sons 2002 5.9. Loud out side not so bad inside. Not sure what the DB rating would be. I like the sound of these older diesels. Exhaust setups can add to or quite some of the noise. I have a MBRP on my 97 and my son had stock with Walker muffler. The both sound about the same to me loudness wise. In either of out trucks if we turn the radio to vol 8 or higher you can hear music clearly. His Dodge is a Work Truck No carpet and just basic everything. I think the sound would compare well with a GM 6.5. Lots of good soundproofing stuff out there where you cut the sound quite a bit. Dynamat is just one.
1997 Ford F250 Extended Cab, 7.3 Diesel, 8 foot bed.
Reese 16K Hitch
(Moved into Shed) Hensley Arrow
Jordan Brake Controller, Hensley TruControl Gold Shelved.
Open Range 5th Wheel, Roamer RF392 BHS
Happy Camping !!
MM49
Brighton, MI, USA
Posted: 07/19/12 01:25pm Link  |  Quote  |  Print  |  Notify Moderator
The 5.9L is music to most people’s ears. It is a symbol of honesty and integrity.
MM49
jspringator
Posted: 07/19/12 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
It is a Laramie SLT.
SoCalDesertRider
SanDiego, CA, USA
Posted: 07/19/12 01:52pm Link  |  Quote  |  Print  |  Notify Moderator
My 7.3 and 6.0 XL trim level vehicles are very loud outside but tolerable inside. I have a good stereo in the 7.3 truck that drowns out the engine just fine.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
path1
seattle
Nothing high tec electronics won't fix. Turn up the tunes!
Beyond that is sounds like a machine that will last many years.
(To cheap to buy new)
1990 37 ft 5th wheel that hasn't moved since 1996 (our best home)
1997 33 ft trailer (winter home in much warmer climate)
2005 25 ft M/H (our "stand up B" for traveling)
travelnutz
West Michigan - On the Lakeshore
Posted: 07/19/12 01:58pm Link  |  Quote  |  Print  |  Notify Moderator
It's not bad at all if you are already deaf!
A superb CC LB 4X4, GM HD Diesel, airbags, Rancho's, lots more
Lance Legend TC 11' 4", loaded including 3400 PP generator and my deluxe 2' X 7' rear porch
29 ft Carriage Carri-lite 5'er - a specially built gem
A like new '07 Sunline Solaris 26' TT
ecoast
NW NJ's Highlands
Posted: 07/19/12 02:28pm Link  |  Quote  |  Print  |  Notify Moderator
it's diesel; you will hear it!
I never shut mine off at drive thru's or the bank...no problem being heard
07 5.9 CTD & 2000 Northstar Laredo TC towing 87 Samurai ORV on dual axle trailer
Page of 6
