RV.Net Open Roads Forum: Fifth-Wheels: Pullrite superglide hitch question
 > Pullrite superglide hitch question
MiPilot
Michigan
Posted: 07/20/12 08:31pm Link  |  Quote  |  Print  |  Notify Moderator
OK,
I am looking at buying a new to me fifth wheel and am installing a superglide hitch.
The questions is ...can I pull it home with the superglide - Without - the capture plate? Then once home install the plate then.
2007 GMC 2500HD Classic 6.6L Duramax/Allison Tuned w/ EfiLive - 16K Superglide Hitch - 2007 Cardinal LE 30RK
pcm1959
home
Posted: 07/20/12 09:02pm Link  |  Quote  |  Print  |  Notify Moderator
No, I do not believe so. If it has the MorRyde pin box, be sure your have gotten the capture plate prior to arriving for the pick-up. Good luck. Phillip
2011 Silverado Crew 3500 SRW Duramax/Allison
2011 Carriage Cameo 31KSLS
Jacksonville, FL
kennethwooster
Perryton Tx USA
Posted: 07/20/12 09:50pm Link  |  Quote  |  Print  |  Notify Moderator
I would not try to do that. I understand there is something you can get from Pullrite to keep the hitch from sliding, then you can pull it. I read this several years ago on this form. Why don't you call Pullrite. Very nice people to visit with. You can also get a bolt on capture plate from them and just bolt it on. I saw one the other day and was very impressed. I really wish that is what I had.
kenneth wooster- retired farmer. Biblical History Teacher in public HS, and substitute teacher.
wife Diana-adult probation officer, now retired.
31KSLS Full Body paint Cameo
Ford F250 2011 model, 4X4, King Ranch.
18K SuperGlide Hitch
PikeRoadWarrior
Pike Road, Alabama
No, but the good news is that all you need are hand tools to put on the capture plate. 10 to 15 minutes is all you need, plus allen wrenches and a small wrench, 3/8" or so... Forget the size... At any rate, it's easy.
2004.5 Dodge 2500 Cummins 4x4
2009 Sabre 31BHDS
rthibodaux
NewOrleans(Marrero), Louisiana
Posted: 07/20/12 10:05pm Link  |  Quote  |  Print  |  Notify Moderator
I would not pull it without a capture plate. The capture plate on my 5th wheel is screw in with 2 in. self taping screws. I think there is about 12-15 of them.
B.O. Plenty
Minnesota
Posted: 07/20/12 10:14pm Link  |  Quote  |  Print  |  Notify Moderator
No it won't work the hitch will slide all over the place. If you get the right capture plate that's made for your pin box the are no holes to drill at all. They slip into place, you usually have 2 screws that go in sideways in the front maybe with some shims and one setscrew that tightens against the king pin..that's it. I don't think they even sell the old ones that required drilling a bunch of holes and bolting it on. Takes all of 5 minutes to install it.
B.O.
2011 Big Country 3250TS...2010 Ram CC Laramie 4wd Cummins
15k Super Glide, Firestone Ride Rite, TrailAir Tri-Glide
Michelin XPS Ribs. Just say no to Chinese tires.
Twin Cities Mn.
greyhd
Oak Hills, CA
Posted: 07/20/12 10:47pm Link  |  Quote  |  Print  |  Notify Moderator
As the others have said, no you shouldn't. Without the capture plate nothing will be preventing the hitch from slamming to rearward position. Basically since the pin isn't captured the hitch will be able to slide back and forth regardless if you are turning or not. Have the dealer install the capture plate or use a different truck to pull it home.
phillyg
Front Royal, VA
Posted: 07/21/12 12:03am Link  |  Quote  |  Print  |  Notify Moderator
You must use the plate. Some attach with multiple screws, and some with one. It depends of the pinbox mfgr.
2002 Keystone Cougar 286, 8,400lbs loaded, pulled with a 2004 F150 Supercrew, 5.4, 3.73 gears. Retired and enjoying life
MiPilot
Michigan
Posted: 07/21/12 05:23am Link  |  Quote  |  Print  |  Notify Moderator
I will order the plate....
Thanks everyone
jims1
NC
Posted: 07/21/12 07:13am Link  |  Quote  |  Print  |  Notify Moderator
Its easy to install the capture plate.
2- small c-clamps or vice grips
1/4" drill bit
7/16 wrench
cordless drill
The capture plate comes with the allen head bolts and allen wrench.
What I did was clamp the plate in place and drill the holes from the bottom side.
Go slow with the drill speed, and a decent pressure and you'll have it done in 5 minutes or less.
'06 Ram with a Cummins
Tuned w/ EFI-Live
'09 36MAX1 Carrilite
Me, Alie, and Salie
