RV.Net Open Roads Forum: Tech Issues: norcold fidg top get cold bottom dont
 > norcold fidg top get cold bottom dont
larryvandivort
missouri
Posted: 07/21/12 06:09am Link  |  Quote  |  Print  |  Notify Moderator
nor cold 1200 frezer part gets cold and bottom will only get to 48 i noticed the buttons on the inside of left door are really hot cleaned the one off that was not real clean and still dont work any help
Golden_HVAC
Fulltime, CA, USA
Posted: 07/21/12 06:17am Link  |  Quote  |  Print  |  Notify Moderator
Is your door gasket heater on?
I owned my refrigerator about 5 - 8 years before finding the switch that turns on the heater for the freezer door gasket. Normally left off, only turned on if you find there is humidity freezing on the door surface near the freezer door gasket.
HOw level is the refrigerator?
How long have you had it running?
How hot outside?
Is it on electric or gas?
Do you have spiders that might have built a nest inside the gas burner area?
The refrigerator will work much higher capacity on gas than on electric.
Try running the refrigerator on gas for 24 hours , and see what happens.
Fred.
larryvandivort
missouri
Posted: 07/21/12 06:33am Link  |  Quote  |  Print  |  Notify Moderator
hey fred thanks for reply just had new cooling unit installed went and picked it up and didnt cool rite so took it back and they said it worked gread was at 33 in-fridge part and 14 below in freezer where is the switch for the heater in door your talking about i am not familiar with that thanks for the help
larryvandivort
missouri
Posted: 07/21/12 06:42am Link  |  Quote  |  Print  |  Notify Moderator
hey fred larry again freezer working proper but fridge is not how do i ajust the thermostat thing on the fins i hear you either move it up or down for colder do you know witch way
dupreet
High Point, NC
Posted: 07/21/12 06:50am Link  |  Quote  |  Print  |  Notify Moderator
Hi,
Generally, moving it up lowers the temp a few degrees, not really a big deal. Make sure the resister bulb in the clip is not touching the metal fin.
How long has it been running. These cool the freezer down near 0 before they start on the fridge compartment. Give it 18-24 hours to stabilize.
Todd
Todd
1993 Ford E-350 pushed by a 1988 Wilderness 24' TT
larryvandivort
missouri
Posted: 07/21/12 07:03am Link  |  Quote  |  Print  |  Notify Moderator
ok thanks todd
the thing has been running about 36 hrs the fins in fridge have drops of water on them and some of the drops are froze but i have therometer cliped on top rack and its showing 46 this morning
thanks for all the help from everyone have to go outside for little bit come back in and check again in few hours thanks
dougrainer
Carrolton, Texas
Posted: 07/21/12 07:20am Link  |  Quote  |  Print  |  Notify Moderator
This procedure is for AUTO temp refers ONLY. That means refers that have NO adjustable tstat. Moving the thermister UP or DOWN will NOT affect the temp of a refer with an adjustable tstat. Doug
dougrainer
Carrolton, Texas
Posted: 07/21/12 07:23am Link  |  Quote  |  Print  |  Notify Moderator
ok thanks todd
The INTERIOR temp of the refer will be 10 degrees Warmer than the fin temp. So, if you have a 32 degree fin temp (drops are ice) then the refer temp will be 40 to 42 degrees. The NORMAL fin temp on a 1200 without anything in the refer is 24 to 28 degrees---34 to 38 degree refer temp. Make SURE the rear fans are running. If not, that will account for poor cooling in the lower refer. Doug
dougrainer
Carrolton, Texas
Posted: 07/21/12 07:27am Link  |  Quote  |  Print  |  Notify Moderator
dupreet wrote:
Hi,
Todd
NOT correct at all. It does NOT cool the freezer FIRST and then the lower refer. It cools BOTH at the same time. The freezer just gets colder faster due to the cooling unit lines are colder at the freezer. YES, you are correct in that it takes at least 24 hours to get the refer to correct operating temp. The Thermister BULB SHOULD touch the metal fin. It HAS too, because the metal clip that holds it secures it to the metal fin. Doug
j-d
Sunny Florida USA
Posted: 07/21/12 08:21am Link  |  Quote  |  Print  |  Notify Moderator
We have Norcold N811. A different series, but we found the fridge door was not closing at the bottom corner. Latch holds it well at the top, but our door isn't stiff enough to compress the gasket all the the way down and therefore not compressed at least part of the way across the bottom. I can rack the door so the corner touches first, but it doesn't stay that way. We've now got a door closing gesture that includes latching the top and kneeing the bottom. Shouldn't have to, but it really helps.
Also, I got a couple little computer fans. I forget the MM size, but they're about 3", and rigged them to keep air moving upward over the outside coils.
With the new cooling unit, I think the Norcold uses two contact points to the inside of the fridge. One against a plate that absorbs heat from the freezer, the other from the fins in the fridge. Cooling unit has to fit flat against those points with "thermal mastic" to enhance heat transfer. Ask your tech about that phase of the assembly process.
God Bless, jd
2003 Jayco Escapade 31A on 2002 Ford E450 V10 4R100
