03 RoadKing
Summerfield NC 27358
Looking for extra cold storage. The Dometic units are a little pricey are there any option other than Dometic?
Jim and Deb
The Furchildren Abby and Baylee
USAF Retired
2001 Newmar Mountain Aire
GMC_jon
Arizona/Virginia
Go with a dorm/apt size 120v + an inverter. Saves $$ and much more reliable & efficient.
FWIW
John
Tarheel 2
North Carolina
I believe it is hard to beat the Dometic. Mine is on a slideout right next to my entry door and can be used for cooling, freezing, or both. It runs on both my inverter or a 12V plug in, whichever I choose. I'm not sure of their cost, mine came with my coach.
Tarheel
JC2
Mo
Tarheel 2 wrote: I believe it is hard to beat the Dometic. Mine is on a slideout right next to my entry door and can be used for cooling, freezing, or both. It runs on both my inverter or a 12V plug in, whichever I choose. I'm not sure of their cost, mine came with my coach.
We also have a similiar setup for a small fridge/freezer in our unit and want to add one. Is the electrical cord one of the coiled ones so it doesn't maybe get caught when the slideout drawer goes in/out.
2004 Newmar DSDP 4015,370hp Cummins ISL,Spartan MM Chassis,2008 Saturn Vue,FMCA #402879,NKK 19776
Tarheel 2
North Carolina
JC2 wrote: Tarheel 2 wrote: I believe it is hard to beat the Dometic. Mine is on a slideout right next to my entry door and can be used for cooling, freezing, or both. It runs on both my inverter or a 12V plug in, whichever I choose. I'm not sure of their cost, mine came with my coach.
JC2-
Mine is a WAECO by Dometic. It measures 24"L, 19"H, 15"W. Both the AC and DC cords are straight and both plug in directly behind the slideout unit. I've never had a problem with them getting caught and I use the unit frequently every time we are in the rig. If I use it for refrigeration only, it will hold a case+ of beer, soft drinks, and a few bottles of wine (just thought I would throw that in! .
JC2
Mo
Tarheel 2 wrote: JC2 wrote: Tarheel 2 wrote: I believe it is hard to beat the Dometic. Mine is on a slideout right next to my entry door and can be used for cooling, freezing, or both. It runs on both my inverter or a 12V plug in, whichever I choose. I'm not sure of their cost, mine came with my coach.
JC2-
Thank you for the info. Did you have to secure it any special way or does it just sit on the slide tray? My apologies to the OP for interupting his thread. Now, back to regular programming.
pigman1
Delaware
I know you said cost was a consideration, but here's one to consider. http://www.sportfridge.com/60-liter
We've been using one of these for about 7 years. Keeps our frozen Salmon and Halibut hard while in Alaska and all the way home. Even in 100 degree+ days. It uses a 120/12v Danfoss compressor.
John
Pigman & Piglady
2013 Tiffin Allegro Bus 43' QGP
2011 Chevy Silverado 1500
BlueOx Aventa LX Tow Bar
SMI Air Force One toad brake
Street Atlas USA Plus
00 BUCK
NE Ohio
JUrban wrote: I know you said cost was a consideration, but here's one to consider. http://www.sportfridge.com/60-liter
John
Wow OVER 1,000.00 dollars
I just saw dorm fridges on sale at the WalMart
79.00
2011 Newmar - VENTANA -- with COMFORT DRIVE
2011 Jeep Wrangler Unlimited Sahara
Blue Ox Aventa LX Tow bar w/ Roadmaster adapters
AirForce One brake system
Life Member GOOD SAM Club
FMCA Member
If your not the lead dog
the view never changes
dons2346
Sioux Falls, SD, formerly of So. CA
00 BUCK wrote: JUrban wrote: I know you said cost was a consideration, but here's one to consider. http://www.sportfridge.com/60-liter
John
79.00
Kinda hard to stand up a dorm fridge in the basement of a motorhome.
ISM500
Manitoba
We use a Koolatron Electronic Cooler/Heater. 12 volt cigarette socket plug in.
Optional AC adaptor. Will hold 48 12 oz cans. Around a $100.
Probably 10 years old and still ticking.
