smkettner
I recommend having a battery if traveling. Those that ask about no battery have often not moved in 5+ years. You have seen them... up on blocks, Patio & stairs built onto the front door, carport built onto the opposite side.
675 watts solar
ktmrfs
Portland, Oregon
While you may not "need" a battery for the converter to work, Having one installed is a good idea for several reasons if your trailer is used for normal camping and not set up on blocks.
1) If you ever loose CG AC power, you at least now a backup for things like water pump, lights, furnace etc. And my experience is that CG is not overly reliable. Several times storms have knocked out the power.
2) When you stop for a lunch break or whatever, you have power for the above as well if you want to use anything. You don't need to rely on 12V from the TV. On my TV 12V shuts off to the trailer when the ignition is off to keep from draining the battery.
3) Your fridge will NOT work unless it has 12V DC. That means no frige cooling when your traveling unless your getting 12V from the TV
4) you don't need to hook up to power for the electric jack etc.
5) when arriving at a CG you can relax and decide when to hook up instead of having to hook up immediately for 12V power. Likewise when leaving, you can disconnect 120V whenever, not the very last thing you do.
6) You MUST have a 12V battery installed for the breakaway switch anyway. May as well just use a decent 12V marine battery rather than a wimpy expensive battery just for the breakaway switch.
2011 Keystone Outback 295RE
2004.5 Silverado 4x4 CC/SB Duramax/Allison
Wherever I happen to park
That line about a power fail is good too.
The campground I'm parked in just now, I think it was last year they were doing some construciton work,, Sliced through the primary wires that bring power into the park.. Took days to get power restored to the entire park, The same backhoe operator did it again the next week and another one the week after that.
kpconnell
Seattle, WA
Ok, but who cares if the battery charger will better operate certain equipment without a battery if you need one and everyone has one?
BFL13 wrote: You are missing the point that the newer technology does not need the battery because the battery was used to "filter" or "clean up" the DC output of the older converters.
Some things in the Rv work ok on dirty DC while other things need clean DC or they will have big problem$.
The switch-mode type puts out clean DC, so does not need the battery as a filter. Nobody said the RV does not still need a battery for other reasons.
BFL13
Victoria, BC
Apparently, few read my earlier post, so here is a re-run:
"So can you pull the battery? Sure, but why? "
My routine for generator charging is to plug the shore cable into the Honda 3000 and let the OEM 7355 converter run the trailer, disconnect the battery bank (so no battery for trailer), plug the 100amp PowerMax converter into the Honda as well, and recharge the batteries.
I can exploit the fact the 7355 does not need a battery by charging the batteries with no draw on them while I am trying to charge them up. Saves gen time.
If my trailer came with the old 6300 instead of the 7300 I would not be able to do that. ISTR the 2001s, maybe 2002s, had the 6300, so we just made it having a 2003 model trailer.
2003 Chev 2500HD Gas, 2003 Komfort 26FS 5er
See Profile for Equipment List
mena661
Wow, I didn't know this was such an issue. LOL!
Trojan L16 6V's 740 Amp-hours
smkettner
Really it is not a big deal.
SCVJeff
Santa Clarita, CA.
We should be able to get another couple of pages out if this one...
Jeff - WA6EQU
DryCamper11
Hartford
My vintage 1972 RV has an automatic relay that disconnects the RV from the battery whenever the transformer type converter has AC power. The original design was for the RV to run off the converter power only and for the battery to be isolated as it charged.
The original system is still in place, although the old converter is just there as a backup. DC power was lousy off the old system, but it didn't need the battery, despite its age. I suspect the power was so bad that leaving it connected to the battery would have burned up/boiled off the battery too quickly.
In the Boonies!
MrWizard
Traveling
well if that old converter is a magtec 63xx
the charge rate is only a few amps , typically 3>6 amps depending on version
so while it would eventually get to full charge it takes a long time to get there at low amps and 13.8v
Connected thru Verizon with HotSopt WiFi using a Samsung Galaxy Nexus
I BOUGHTthis phone
