RV.Net Open Roads Forum: General RVing Issues: that ******* shower hose
 > that ******* shower hose
garyhaupt
Back living in Kitimat..northern BC.
Posted: 07/21/12 06:21pm Link  |  Quote  |  Print  |  Notify Moderator
I cannot get enough slack hose to get properly wet/rinsed. I finally bought a spare hose keeper, and cut the one in the shower stall, so that the hose can be fully used.
Used a Dremel tool with a cutting wheel.
Gary Haupt
I have a Blog..about stuff, some of which is RV'ing.
http://mrgwh.blogspot.ca/
PegLW
SW Missouri
Posted: 07/21/12 06:32pm Link  |  Quote  |  Print  |  Notify Moderator
We just simply disconnected our hose, by-passed the the little plastic dohicky, and reconnected the hose. Easy and it works just fine.
Peg
Dave and Peggy
2012 Open Range 345RLS
2012 Ford F350 6.7L turbo
fla-gypsy
North Florida
Posted: 07/21/12 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
Peg
X2, never had an isssue not using the keeper
eend
Alberta
Posted: 07/21/12 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
Gary Haupt
did exactly the same thing, not sure why it is there for,can't even take the shower head off to rinse out the tub with that silly do-ma- hicky there.
2008 Jeep Grand Cherokee with 3.0L diesel.
2005 Chevy Silverado 1500 4x4
2010 195wbs Shadow cruiser travel trailer.
Dutch_12078
Great Sacandaga Lake, NY
Posted: 07/21/12 07:36pm Link  |  Quote  |  Print  |  Notify Moderator
As the others have said, I just removed the hose from it. The doohickey works just fine holding my razor.
Dutch
1995 Coachmen Catalina 322QBXL
F53 chassis, 460 V8, TST TPMS
Quadra Bigfoot EZE Levelers
Camper Mama Bear
New Jersey
Posted: 07/21/12 08:01pm Link  |  Quote  |  Print  |  Notify Moderator
great idea! I don't understand why they install the shower heads so low. our first stop after we got our trailer was a supply store for a longer hose and a second mounting bracket. we also have our thing bypassed, never had a problem though the minor OCD in me would like it either used or removed. might have to add that to hubby's to do list, or figure out how to do it myself.
Good Sam Life Members. Camping with two young children in a 2007 Pilgrim fifth wheel (278BHSS) pulled with a 2002 F350.
coolbreeze01
Redding, Ca
Posted: 07/21/12 08:26pm Link  |  Quote  |  Print  |  Notify Moderator
My guess is most folks remove them, how long did you put up with it??
2008 Dodge 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2007 Komfort 212 on 225 75R 15E Maxxis 8008 Tires.........
robatthelake
Vancouver Island
Posted: 07/21/12 09:36pm Link  |  Quote  |  Print  |  Notify Moderator
We have always just unscrewed the Hose and By passed that stupid Do hickey!
I understand that it is designed so the Hose can't drop into the Shower pan and backfeed Grey Water into the fresh water tank!
Rob & Jean
98 Dutch Star Diesel Pusher ..92 Tracker 4X2
beemerphile1
I'm 57, I'm not a
Posted: 07/21/12 09:52pm Link  |  Quote  |  Print  |  Notify Moderator
Bypassed mine also, seems to be a consensus!
Even if you are on the right track, you'll get run over if you just sit there.
- Will Rogers, American actor
W4MBG
Williamsburg, VA
Posted: 07/21/12 11:33pm Link  |  Quote  |  Print  |  Notify Moderator
That grey water would have to be a few feet deep to get past the faucet, and then when you turned it on it would flush the hose. But codes is codes!
1999 Winnebago Minnie, 29', Triton V10, mostly stock. So far...
