RV.Net Open Roads Forum: General RVing Issues: that ******* shower hose
 > that ******* shower hose
pasusan
PA
Posted: 07/22/12 05:07am Link  |  Quote  |  Print  |  Notify Moderator
robatthelake wrote:
We have always just unscrewed the Hose and By passed that stupid Do hickey!
I understand that it is designed so the Hose can't drop into the Shower pan and backfeed Grey Water into the fresh water tank!
Thanks for explaining that - I was beginning to wonder why the doohicky after reading this thread.
Trip Pics
"Don't let the sound of your own wheels drive you crazy." JB & GF
Susan & Ben ~
84 Bronco & 90 Award Classic 23 joined with a Hensley Cub
jetboater454
Camping or home
Posted: 07/22/12 05:18am Link  |  Quote  |  Print  |  Notify Moderator
Never even had one.
"If momma not happy ....Who cares.I have my TH AND my toys .
2007 Gulfstream Endura Max 40
2001 Polaris Ranger 4X4
Mod Pics
Wills250psd
walnutcove NC
Posted: 07/22/12 05:30am Link  |  Quote  |  Print  |  Notify Moderator
PegLW wrote:
We just simply disconnected our hose, by-passed the the little plastic dohicky, and reconnected the hose. Easy and it works just fine.
Peg
After I struggled with this dang thing my wife said just bypass this thing, so mine also holds her razzer. We do lay the shower head in the tub when travling so it doesnt fall and break.
PegLW
SW Missouri
Posted: 07/22/12 05:52am Link  |  Quote  |  Print  |  Notify Moderator
Wills250psd wrote:
Peg
We always lay the shower head on the shower floor too when traveling for the same reason. Some things just require common sense. Right?!
Peg
Dave and Peggy
2012 Open Range 345RLS
2012 Ford F350 6.7L turbo
Bonefish
Midland, TX
Posted: 07/22/12 06:12am Link  |  Quote  |  Print  |  Notify Moderator
Shower Head Holder
Our shower has two of these mounted one high and one lower allows you to move and hold the shower head and angle it where you need the spray.
ryanallie1
Magalia, Calif
Posted: 07/22/12 06:30am Link  |  Quote  |  Print  |  Notify Moderator
Hi All.
I guess we are lucky, as our Motorhome never had one to start with, We only have the split holder that holds the Shower-Head, and even that we the right size when we put on our Oxy Shower-Head.
And it is high enought for the both of use. DW is short and I'm tall, I guess Rexhall does good agian.
Good Luck. Happy Travels. Dan & Jill
1998-33.5 Rexhall, Rexair SL. 460 EFI. F-53. 7.3 MPG. TST TPMS. HWH Levelers. 5.5G Gen. Convection/Microwave Water Purifier/Water Softner. 2 A/C's. Alarm Systems. Honda EU2000i's W/Kit. Steer-Safe. CR-V W/SMI System. FMCA #F414397 Nam-Vet, 66-67-68&70-71
portscanner
Georgia
Posted: 07/22/12 06:32am Link  |  Quote  |  Print  |  Notify Moderator
There was a thread some time ago that discussed useful applications for the hose keeper. Suggestions ranged from holding your shot glass of wiskey to holding your glass eyeball. I will have to see if I can find it.
One beautiful wife, two brittney spaniels
2011 Dodge 3500 4x4 DRW Crew Cab 6.7 Cummins, 6 speed auto, 3.73 rear end
Torklift Stableloads, Superhitch, Torklift Tiedowns
2002 Alpenlite 1150
2005 Jeep Liberty toad w/ ReadyBrake/ReadyBrute
Web Site
garyhaupt
Back living in Kitimat..northern BC.
Posted: 07/22/12 07:29am Link  |  Quote  |  Print  |  Notify Moderator
coolbreeze01 wrote:
My guess is most folks remove them, how long did you put up with it??
*gasp*...remove them? are you nutz? I paid 40,000 for those clips, I ain't about to remove them, geeezus. Two years to get around to it. Them 'get around to it's' are hard to find, sometimes.
And mine has a head holder upper.
Gary Haupt
I have a Blog..about stuff, some of which is RV'ing.
http://mrgwh.blogspot.ca/
coolbreeze01
Redding, Ca
Posted: 07/22/12 07:39am Link  |  Quote  |  Print  |  Notify Moderator
Gary Haupt
$40K?? I knew them rings were expensive
2008 Dodge 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2007 Komfort 212 on 225 75R 15E Maxxis ST Tires.........
Raymon
Phoenixville, PA
Posted: 07/22/12 10:23am Link  |  Quote  |  Print  |  Notify Moderator
Peg
X2 Just unscrewed the hose and removed from the holder; very easily done.
Ray
