flathead92
Chandler AZ
my brake away cable drags on the ground and the wire split on last trip. How long should it be? and can one buy a new one with the protective plastic coating on it?
WI Bowhunter
Shiocton, WI
Several choices
Yes, you can replace the cable with a coated one. Mine is too long also, I just tie a loose knot in it to take up the slack.
Keep the Shiny Side Up!
2011 F150 Supercrew, 4X4 3.5 Ecoboost, 145" wheelbase, 3.73 gears, Max trailer Tow package
2014 Puma 30DBSS
Equali-I-Zer WD Hitch
3 kids and 1 DW
Oasisbob
Portland Oregon 97266
Better too long than too short. Last thing you want is your TT wheels locking up. I weave mine through the safety chain a few times until it is slack but no where near dragging.
Oasis Bob
Wonderful wife & 4 Really Fun kids
2008 KIA Sedona 3.8L 24 valve V-6
2001 Bantam Trail Lite B-19
HAPPY TRAILS
Turtle n Peeps
California
Your going to get a lot of different ideas and opinions on this.
IMHO it should be just long enough to make your turns without pulling the pin in the tightest turn you can make but shorter than your safety chains. That is the way mine came from the factory and I agree with that.
You can buy plastic coated cable from any good hardware store and make up your own.
outside the fire"
flathead92
Chandler AZ
Thanks for the tip weave through the chain
Mark and Linda
Smyrna, Tennessee
I have weaved my through my safety chain that attaches on the left side of my tv. I put a d ring on the end...and have U type clevis attached to my lower bumper area. I just have to pull a pin, insert the d ring, put pin back in and I am ready to go.
ianblaster
Dothan, AL
I bought one of these from camping world. Works really well.
Moderator edit to re-size picture to forum limit of 640px maximum width to avoid scrolling.
edited 07/22/12 09:37am by an administrator/moderator *
2007 Expedition EL Limited 4x2 w/Tow Pkg
2009 KZ Spree LX 318 BHS
chevor
US/Canada
I always try to keep it shorter than the break away chains. Support it by running it through a padlock hooked to the hole in the ball latch. I hook mine to the bumper of the truck that isnt the hitch rechiever. If the trailer ever does seperate from the truck I want the break away switch to be pulled before the chains go tight.
2010 Gmc 2500 Duramax,1ton rear springs, 90g box tank, 0ver 495,000 Odometer miles, 20k Curt fifth wheel, 18k Curt rear mount hitch. Cobra CB/Weather Radio, Bridgestone Duravis R500 HDs Rancho 9000 Shocks, Firestone Airbags, bypass oil filter, Fass 95HD
MitchF150
Washington, the State
Bungie cord to hold up the slack works great.
Mitch
*Anything I post is for entertainment purposes only and what usually works for me.. Your Mileage May Vary..
wcjeep
Tacoma, Wa
ianblaster wrote: I bought one of these from camping world. Works really well.
I have the exact unit from a different source on my carhauler. It is an absolute must have. Never a problem now.
edited 07/22/12 09:38am by an administrator/moderator *
