lamopar
Oregon
Where do I get a grill that does not have a regulator so the pressure from the RV propane system will work and I don't have to carry an extra propane bottle or rig up this crazy system of hoses from the two tanks. Is there a grill that will just connect to the propane line and heat up the meat?
jauguston
Bellingham, WA
Camping World
2005 Coachman Sportscoach Elite 402 40'
350hp Cat C-7 w/MP-8
7500w Onan quiet diesel generator
6-Kyocera 130w solar panels SB3024i MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
lamopar
Oregon
I spent an hour at camping world and did not find a grill that did not have a regulator. I guess I need to go online.
Camper8251
Skagit Valley, WA
If you do a search on here you will find a bunch of info on Low pressure grills. The only one CW sells is this
http://www.campingworld.com/shopping/item/stainless-steel-mountable-grill/37764
Here is a start http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/23861072.cfm
edited 07/21/12 10:01pm by Camper8251 *
2008 Chevy Silverado 2500 DMAX
2008 Arctic Fox 811
Vision Wheels with
Toyo M608z's 225/70R19.5 14 plys rated at 3970
kckettridge
Northern California
Good luck Lamopar...I have been down this road already. Bought a Weber Go Anywhere grill thinking it could be converted with the Camco/Olympian valve but the burner tube design on the gill won't allow this modification/conversion.
Weber should make one specifically for those millions of us that have RV's.
Needless to say, I returned the Go Anywhere Grill. I'll use the bbq box for our Tahoe Camp Stove to bbq my steaks and hamburgers.
Dutch_12078
Great Sacandaga Lake, NY
Why not just choose the appropriate hose and adapter for your setup and use any regular grill and regulator you want? Once the adapter is installed, it's just a single hose hookup. I use a 12' hose with a 4-port Extend-A-Stay adapter on my fixed tank, and it works fine.
Dutch
1995 Coachmen Catalina 322QBXL
F53 chassis, 460 V8, TST TPMS
Quadra Bigfoot EZE Levelers
Bonefish
Midland, TX
I just went to ACE Hardware and bought the proper fittings to remove the regulator and plumb the gas line back in.
lamopar
Oregon
I am now moving to eliminate the regulator as well. I tried the extended stay hose assembly with the hoses I could not get it to connect to my double tanks and use the existing connections. I would need to buy a longer hose to connect to the one tank. The next is the length of the hose from the tank to the grill would not reach my awning. In Oregon camping in the drizzle I need the grill under the awning. I like the idea Bonefish has. I am working on this. I thought I saw places on some campers that had actual grills for the camper though. I know I have seen them advertised right on the side of the camper with connections for the grill.
Queens Carriage
Treasure Coast, FLorida
I was also looking at the Q but it only has about 8000 btu's. Been looking at the one at sams for $99 21000 btu's, Has anybody tried one of these looks like they would adapt to a low pressure hookup.
Ron3rd
Upland, CA USA
To the OP, this question comes up so often I wish they would make a sticky for the topic at the top of this forum. Basically, you just remove your regulator (Weber Q is popular for this mod) and install the necessary fittings in place of the regulator so you can connect your hose. I quick search will bring up many posts on how to do it.
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
