RV.Net Open Roads Forum: Class A Motorhomes: help! stranded at park
 > help! stranded at park
Page of 14
yoquedo
Houston.,TX USA
Posted: 07/22/12 09:32am Link  |  Quote  |  Print  |  Notify Moderator
We are at a state park where the shore power breakers were replaced.... long story.... everything was fine till then. When they finished and plugged me back in.... nothing in the coach would work. The breakers are all good but theMagnum Energy inverter says No Inverter Communication. Ive done all reset proceedures...still says No Communication with inverter.Good Sam roadside sent guy out to no avail. So here we sit.... cant get slides in or awnings AND NO AC!
gswcgi
Wandering
Posted: 07/22/12 09:35am Link  |  Quote  |  Print  |  Notify Moderator
The park gave you a gift of a surge & probably fried your coach electrical system. You needed a surge protector.
'03 Safari, DP, 36" Nissan 4X4 toad
bhivetravels
Chattanooga
Posted: 07/22/12 09:36am Link  |  Quote  |  Print  |  Notify Moderator
Perhaps a silly question but did the Good Sam rep check the shore power?
Jim and Monica
Maj. USAF Ret. -- High School Teacher Ret.
2007 Coachman Epic - 05 Honda Element
Full-Timing with Meiko and Marlie
trickyvic3
Raymond NH.
Posted: 07/22/12 09:42am Link  |  Quote  |  Print  |  Notify Moderator
X-2
I was just about to ask the same question.
workhardplayharder
Treasure Coast Florida
Posted: 07/22/12 09:43am Link  |  Quote  |  Print  |  Notify Moderator
I don't know you abilities but if it were me I would build an external power source to bypass the electrical system to power the slides and awning.
wolfe10
Posted: 07/22/12 09:49am Link  |  Quote  |  Print  |  Notify Moderator
Mike,
First, it would help if you put what coach you have in your signature.
Do you have 30 or 50 amp coach? Is shore power 30 or 50 amp?
Absolutely, before even thinking about replugging into shore power, VERIFY correct polarity, voltage and presence of good ground. If you tell us whether this is a 30 or 50 amp connection AND whether you have a digital voltmeter, we can tell you how to do it.
Do you have a generator? If so, run it with shore power disconnected and tell us exactly what works/doesn't work on generator vs shore power.
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
yoquedo
Houston.,TX USA
Posted: 07/22/12 09:52am Link  |  Quote  |  Print  |  Notify Moderator
Yes after three attempts he got shore power working and Good Sam rep. Also tested.
yoquedo
Houston.,TX USA
Posted: 07/22/12 09:53am Link  |  Quote  |  Print  |  Notify Moderator
2012 Tuscany 50 amp. Shorepower is 50 also
yoquedo
Houston.,TX USA
Posted: 07/22/12 09:55am Link  |  Quote  |  Print  |  Notify Moderator
Generator is out too. Dead.
bhivetravels
Chattanooga
Posted: 07/22/12 09:58am Link  |  Quote  |  Print  |  Notify Moderator
Do you have an automatic power transfer switch? Perhaps it was zapped when new shore power applied. Did generator work before?
Page of 14
