CT_WANDERER
E. Lyme, CT
GBaxter wrote: CT Wanderer,
I believe it is a 5 amp fuse that runs the control board for the PCS. The control board has relays that in case of power outage default to the n/c position. In this case without DC power in the coach it wouldn't make any difference because anything that needs dc to the control circuit even to run on shore power like the the a/c wouldn't work anyway.
So yes without the 5 amp fuse power the PCS control board is dead which in turn does not allow the Magnum info to pass through the PCS to the inverter so "no comm" on the Magnum remote.
Gary
Thanks for the information, I am not up with the Magnum Inverters. Yesterday was my first time looking to find out what makes them "tick".
Executive
To the OP...thank you for your response. We were concerned that you were still stuck in the CG. Since most of us have been there a time or two, it's certainly not fun. If the family's with you, the stress goes way up. Now that you're home we can all relax and simply wait to see what your problem was. Thanks again for the update and ignore the ignorant.....Dennis
Dennis and Debi
Chevy HHR W/ ReadyBrute
Fourth Year Full Timing Click here to view our travel blog
Grillmeister
BBQ TOUR USA
Executive wrote: To the OP...thank you for your response. We were concerned that you were still stuck in the CG. Since most of us have been there a time or two, it's certainly not fun. If the family's with you, the stress goes way up. Now that you're home we can all relax and simply wait to see what your problem was. Thanks again for the update and ignore the ignorant.....Dennis
Well said Dennis!
Show me the GRILL and STAND BACK!!!!
yoquedo
Houston.,TX USA
Well almost 12 days now and Camping World still does NOT have an answer for me. I have called and emailed 6 times inquiring about the status.
Tomorrow they get a visit in person !
enblethen
Moses Lake, WA
That doesn't sound good. They should be letting you know what is going on.
Thanks for keeping us up on the status.
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
Executive
Let us know too, if they've even LOOKED at it...Dennis
wny_pat
Western NYS
yoquedo wrote: Well almost 12 days now and Camping World still does NOT have an answer for me. I have called and emailed 6 times inquiring about the status.
Tomorrow they get a visit in person ! Well, you can always get hold of the boss (Dear Marcus) at the Top of the forum under Dear Marcus.
VinCee
Western NY State
I would think 12 days is a little on the long side to at least have an idea of what's going on. Good Will CW creates by getting the OP there is being lost for what now appears to be a lack of good service, go figure!
RayChez
Barstow, Ca. USA
It seems like if he does not have any AC power into the coach, it seems like the big fuse right behind the inverter on mine mounted on the wall would have blown and nothing gets past that if blown. Another thing in the inverter is a transfer board, IF that goes bad, NO power into the coach. It seem like a good tech at CW would have tracked it down already.
Sometimes you have to push them people to work on your coach or else you might find yourself waiting for a long time. I stay right with them and push them to work on the coach and it has worked for me so far. Either fix it or else pull it to a place that can fix it.
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar
3000 Allison Transmission
Neway Freightliner chassis
2013 Honda CR-V EX
Aventa II
FMCA member
yoquedo
Houston.,TX USA
The sevice writer tells me they order a SOLENOID and are waiting for it to come in. I have him checking what the eta is now. They "think that will resolve the 12 volt problem".
