RV.Net Open Roads Forum: Fifth-Wheels: Parking on concrete?
 > Parking on concrete?
Page of 5
brentbullets
Nebraska
Posted: 07/22/12 11:59am Link  |  Quote  |  Print  |  Notify Moderator
I am going to have a 30' x 30' concrete pad poured to park my Montana on at our seasonal camp ground. We can leave the camper there year round and plan on doing so. My questions are;
Would you put down treated wood under wheels and landing gear?
Just put wood down under landing gear?
Any thoiughts and suggestions would be appreciated.
Thanks, Brent
Jack_Diane_Freedom
Milton Ontario Canada
Posted: 07/22/12 12:20pm Link  |  Quote  |  Print  |  Notify Moderator
Why would you put wood under anything when on concrete. Can see doing it on asphalt but not concrete.
HappyKayakers
Black River Falls WI
Posted: 07/22/12 12:26pm Link  |  Quote  |  Print  |  Notify Moderator
X2
Joe and Dakota, the wacko cat
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2006 Heartland Bighorn 3600RL, MorRyde suspension, TrailAir pinbox
http://happykayakers.com/blogger/
newk
Gillette, WY
Posted: 07/22/12 12:32pm Link  |  Quote  |  Print  |  Notify Moderator
I make the center 2-3 inches higher than the edges so water will drain. If you do that there shouldn't be any point in blocking up anything.
WWH
Posted: 07/22/12 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
My fiver has been sitting on concrete for years with no problems.
trike2
idaho
Posted: 07/22/12 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
Good Day:
I park my fith wheel legs on concrete, but where I live it does get below -20, I do not set my wheels on concrete. I place them on treat wood to protect the tires from the concrete in the cold. Also I raise the whole frame up as to lighten the wt. on the wheels during the time. Tires on my first camper lasted until I was ready for new. I do the same for my fifth wheel.
2005 gmc 3/4 hd, sb, 4x4, 8.1 gas/allison 17,000 and climbing.
2005 Lakota, by Monaco, 3 slds, 29f.
larry barnhart
wenatchee. wa usa
Posted: 07/22/12 01:06pm Link  |  Quote  |  Print  |  Notify Moderator
If you read anything about tires it is recommend to put something between the tires and what ever they are touching. Even if you don't feel this is needed it is an easy thing to do.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
trickyvic3
Raymond NH.
Posted: 07/22/12 01:11pm Link  |  Quote  |  Print  |  Notify Moderator
chevman
X-2
Never hurts to play it safe.
skipnchar
Topeka or somewhere else
Posted: 07/22/12 01:13pm Link  |  Quote  |  Print  |  Notify Moderator
The wood may protect the concrete from movement but other than that, your call.
whiskyrunner
Oconto Wisconsin
Posted: 07/22/12 01:25pm Link  |  Quote  |  Print  |  Notify Moderator
chevman
So I put wood between the tires and concrete, what do I put between the tires and the wood????
2000 Ford F250,4x4 diesel short box,Firestone airbags
2004 Terry Quantum 36ft fiver,4 slides
Page of 5
