RV.Net Open Roads Forum: Fifth-Wheels: Fifth wheel hitch education needed
 > Fifth wheel hitch education needed
trike2
idaho
Posted: 07/22/12 09:32pm Link  |  Quote  |  Print  |  Notify Moderator
Good Day:
All of the other responses you got are great, follow them and you should haved no problem. However, check and make sure the hitch has clip that will hold the arm in place for safty reason. ( It should )But I use a lock every time I pull my fifth wheel. I have heard and seen results of some one who just happens to pull the arm open, truck unattended, and the owner drive's off. Unfortunely, now they have a big problem to contend with. Yes it does happen, sorry to say. Juat an added extra safty thought.
2005 gmc 3/4 hd, sb, 4x4, 8.1 gas/allison 17,000 and climbing.
2005 Lakota, by Monaco, 3 slds, 29f.
mobilcastle
OH
Posted: 07/23/12 04:03am Link  |  Quote  |  Print  |  Notify Moderator
I have used Pullrite slider and B&W.
Short bed use slider-long bed use B&W(super hitch)
2010 Heartland 3670RL Demco,dual panes,2-AC,
7000lb axles,G rated LT tires,38' high profile,
2011 Chevy 3500HD,Dually,D/A,LB,EB,4X4,
B&W Companion,GVWR-13,000
Dave H M
IL
Posted: 07/23/12 05:55am Link  |  Quote  |  Print  |  Notify Moderator
6021
Be careful about the advice that you have to have a slider for a short bed. In most cases that is urban legend. do a search and read until you fall to sleep on the subject.
Try going to etrailer.com and look up the install kit for your truck, possibly they will have a video on how to, they did for mine.
4x4ord
Canada
Posted: 07/23/12 06:00am Link  |  Quote  |  Print  |  Notify Moderator
I've used the B&W hitch on my last two short beds. Really like it.
2011 F350 SRW short box 4x4 CC 6.7 PS King Ranch
B&W TurnoverBall and Companion
2003 Citation Supreme 34 RLTS
riggsp
Charlotte, NC
Posted: 07/23/12 07:29am Link  |  Quote  |  Print  |  Notify Moderator
No slider needed with a long bed truck.
Martyn
Bennett, Colorado, USA
Posted: 07/23/12 09:06am Link  |  Quote  |  Print  |  Notify Moderator
FiverDragger wrote:
I'm not sure they make a slider 15k pro model.
They do - I have one
2004.5 Dodge Ram 2500 QC CTD 4x4 SLT; 2007 Coachmen Chaparral 267RLS;
Reese 15K Slider; Prodigy; JT's & Rotochoks; 2 Honda EU2000i's;
2006 Glastron MX175;
2009 Subaru Tribeca for the DW
wittmeba
Virginia
Posted: 07/23/12 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
Here is some info that may help assess your needs.
http://gotnarcosis.com/brucewittmeier/technical/FifthWheelHitchComments.html
I was born in Great Falls, Mt. My parents moved when I was 5. I found them when I was 10 - they were in California.
Firefox® 21.0
Log home images - Updated 05/19/2013
houstonstroker
Houston, TX
Posted: 07/23/12 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
Just my 02 cents, but I prefer one that has a four way swivel head and is completely removable.
TV 2002 Ford F-250 Powerstroke 4WD Crew Cab
5th Wheel 2009 KZ Spree 305BH
ependydad
Columbia, MD
Posted: 07/24/12 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
dlturner00 wrote:
I love my B&W Companion so far but its the only one I've ever had.
X2 and I love the completely empty bed after removing it.
2013 Sabre 36QBOK
Truck: 2012 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: B&W Turnover Ball + Companion hitch
Nights Camped: (2013: 10, 2012: 52, 2011: 28)
Blog about learning to RV, mishaps and adventures
jerem0621
Sequatchie, TN
Posted: 07/24/12 09:05pm Link  |  Quote  |  Print  |  Notify Moderator
OK, never saw that one before.. what hitch is it?
Thanks!
TT: 1995 Layton 2910
Tow Vehicle: 1999 F-350, v10, 2wd, Crew Cab, Dually
Hitch: Draw-Tite Trunnion WD Hitch
Sway Control: Valley dual friction sway control
Brake Control: Tekonsha Voyager
"It's Kind of Fun To Do The Impossible"
~Walt Disney~
