RV.Net Open Roads Forum: Hybrid Travel Trailers: Trailer Tires?
Open Roads Forum  >  Hybrid Travel Trailers
 > Trailer Tires?
ryanb-72
Boerne
Posted: 07/22/12 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
Just got back from an overnite trip in some pretty rough terrain and was thinking I should look into lifting the camper. So I went out and started to look under the frame when I noticed the tires are almost worn out! We have a 2012 Jayco X17Z with the tiny 13 inch tires. The trailer has probably 4500-5000 miles on it. Shouldnt the tires last longer than that? Should I look into getting bigger rims and tires? Better quality tire? I looked on line and there isnt a large selection of 13" D rated tires. Any body have any suggestions? anyone put 215/75/14 tires and wheels on this camper before? I guess my big thing is I dont want to upgrade only to find the tires are worn out in less than a year again.
Ryan
2012 Jayco X17Z
2009 Niisan Frontier 4x4
Kipor KGE 3000TI
skipnchar
Topeka or somewhere else
Posted: 07/22/12 07:48pm Link  |  Quote  |  Print  |  Notify Moderator
I average about 40,000 miles on a set of ST trailer tires. Bad tires may be PART of the problem but I'd have the alignment checked along with all other suspension parts. WAY too much wear for so few miles. My trailer takes load range C tires because it is only 8000 lb. max.
Good luck / Skip
MitchF150
Washington, the State
Posted: 07/22/12 07:49pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like you have an alignment problem more than a tire problem?
I've got the 13" tires for a #5000 GVWR trailer and I'm on my second set in 10 years.. (replaced the OEM's last year)
I got my LR D tires online from etrailer and while they are not the most popular country of origin, they are doing fine so far!
Good luck with your situation.
Mitch
*Anything I post is for entertainment purposes only and what usually works for me.. Your Mileage May Vary..
KD4UPL
Swoope, VA
Posted: 07/22/12 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
I have ST175/80R13 tires on my boat trailer. I have no idea how many miles are on them but they are 9 years old. They still look like brand new with no cracks and no leaks. I know you're supposed to replace them before 9 years but that takes money. I do have a spare if one decides to blow.
You must have some seriously defective tires or alignment problems if yours are worn out that fast.
ryanb-72
Boerne
Posted: 07/22/12 07:54pm Link  |  Quote  |  Print  |  Notify Moderator
If it is an alignment issue is this fixable? Do they align these like a car? it is a single axle trailer.
Ivylog
Blairsville, Ga. USA
Posted: 07/22/12 08:10pm Link  |  Quote  |  Print  |  Notify Moderator
Hope you still have some warranty left as NO it's not a simple alignment like on a car.
04 Monaco Dynasty 42' quad slide
Where am I?
How I tow.
RandK-M
NY
Posted: 07/22/12 08:37pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 17Z and changed my tires and wheels to ST205/75R14 radials. I never liked the 13" and my Duro tires were getting a couple of small cracks in them.
I like the 14" much better. Also, The load range D 13" tires that were stock are generally special order only in that size and I didn't want to have trouble getting a replacement on the road if needed. The ST205/75R14 are common.
Ray
Jayco 17Z
Dodge Ram 1500 Quad Cab
Prodigy P2
Equal-i-zer Hitch
US Navy Veteran
ScottG
Bothell Wa.
Posted: 07/22/12 09:12pm Link  |  Quote  |  Print  |  Notify Moderator
Different method of alignment than a car but it can be done. And since your tires wore down so quickly, I would get it checked.
Scott, Grace and Wesly
H0NDA eu2000i
wmoses
Houston, Texas, USA
Posted: 07/22/12 09:43pm Link  |  Quote  |  Print  |  Notify Moderator
Ryan
You need to get the alignment checked. That amount of wear is not normal. I went on a road trip to Canada last month and did 4000 miles on my essentially new made in China Goodyear Marathon C rated trailer tires and they show no wear our blemishes whatsoever. And they did not blow up or perform anything but perfectly.
I did upgrade to 14" tires and aluminium rims which also was great. With that I have more capacity than the rated GVWR of the trailer and peace of mind.
Regards,
Wayne
2010 Jayco Jayfeather EX-Port 17Z | Tekonsha Prodigy P3 brake controller
2010 GMC Sierra 1500 SLE 5.3L Vortec V8 6-speed with Power Pack Plus Package | Hypertech Max Energy tune
_
Chuck&Gail
In the Colorado Mountains
Posted: 07/22/12 10:57pm Link  |  Quote  |  Print  |  Notify Moderator
Did I miss HOW they wore? Were they worn only in center, only on both edges, only on one edge?
We need that answer first I think.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
 > Trailer Tires?
