ROYBUCK
Newport NC
This is not my day. I posted earley about removing my old tv, well I removed it when and picked up a 26" VIZO LED LCD HDTV. I put it in and hooked it up screen says no signal, the old tv was working when I took it out. Now I had a digital box for the old tv, I have not un-hooked it but it is not on. I am getting a signal in the back but of course no picture, any suggustions
Thanks Roy
Roy B Coal Miners Son
USMC Ret
Semper Fi
2002 Endeavor 330 ISC 3 Slides
SS Slacker
Lino Lakes, MN
You may need to remove the digital converter or at least turn it on like you may have had to do previously. Also, on the new TV, check the "source" and be sure it is set to TV/Cable as I assumed you hooked up the same coax cable that threads on and was used on your old TV.
Dan & Tracy
2 kids ages 9 and 11
2003 HR Neptune 36PBD
300 ISB Cummins/5-Speed
dupreet
High Point, NC
With the antenna hooked up and booster amp turned on, have you gone into the setup menu and had it search for channels? You shouldn't need the box anymore.
Todd
Todd
1993 Ford E-350 pushed by a 1988 Wilderness 24' TT
Artum Snowbird
Campbell River, B.C., Canada
Signals aren't just there the first time... each different place you set up you should do a search for channels.
Mike and Carole
2007 Snowbird 9'6" Super Slide
2005 16.6 Double Eagle
2000 F350 7.3 SC 4X4
previously 8'10" Snowbird Camper
2006 Triple E Regency 27 foot SXL SOLD!
ROYBUCK
Newport NC
I cannot get to the channel set up, I can go up and down with the arrows but it will skip channel set. They are no change with the coax hooked or un-hooked shows on screen no signal. Roy
ROYBUCK
Newport NC
vbnjay
Arizona
Search for channels and make sure you are on the right INPUT.
The new LCD tvs can have 5 or so inputs, pc, hdmi, component, composite, tv/ant.. If you SE on the wrong input, you can see that message. Should not need the digital box, as the new LCD tv is digital ready.
I would hit the input buttons a few times to scroll through all of the options to make sure you are on the right one, then do a channel search. Should be that easy.
Enjoy the sweet new TV.
27' Four Winds 5000
300w solar, Sunsaver duo, 2 AGM batteries
Hf/VHF + APRS
peaches&cream
Northwest Georgia
Do away with the old convertor box. You do not need it with the new tv. If it does not have a pass through, it will block your signal. Hook directly to the new tv from your selector box. Make sure the antenna amphlier is on. Then do a channel scan. Should be good to go.
2005 Holiday Rambler Ambassdor, 36PRT, 330 Cummings
Toad 1995 Miata
paulcardoza
Southeastern Massachusetts
Make sure you have the TV INPUT set to Antenna or CABLE. NOT HDMI.
ROYBUCK wrote: I cannot get to the channel set up, I can go up and down with the arrows but it will skip channel set. They are no change with the coax hooked or un-hooked shows on screen no signal. Roy
Paul & Sandra
New Bedford, MA
2003 Monaco Executive M43 DS2
hottubkid
SCHAUMBURG,IL
Go to setup or inilize of the tv and run throught it and it will pick up the chanels you are aimed for . Also make sure your antena is up
hottubkid60193@yahoo.com
2004 SOUTHWIND 36E Tow 2003 CRV
