RV.Net Open Roads Forum: Class C Motorhomes: AM Reception
 > AM Reception
fizikpal
East Northport NY USA
Posted: 07/23/12 11:47am Link  |  Quote  |  Print  |  Notify Moderator
Not sure if this is a class C problem or not but...
I never get great AM reception. FM is fine but AM mostly static. Not sure if the cabover (which blocks the antenna) has anything to do with it.
This is my second radio in the unit with the same problem.
Any tips would be appreciated.
THanks
tom
The Lynch's
2002 Shasta Cheyenne 308
TOAD: 2003 Honda Civic
Sterling Tow Bar with Brake Buddy
bukhrn
Lanexa, Va
Posted: 07/23/12 11:51am Link  |  Quote  |  Print  |  Notify Moderator
Can't really help, as I never listen to AM in any vehicle, but my guess is that you're correct about the overhang, blocking the signal.
2007 Forester 2941DS
2005 KIA Spectra
old guy
Oregon (pronounced Or e gun)
Posted: 07/23/12 12:21pm Link  |  Quote  |  Print  |  Notify Moderator
are you plugged into 110 when this happens? if so it might be the converter and putting static into you radio. if so only thing you can do is put a filter inline to the 12v side of the radio. if any thing 12v like a fan or any thing with a motor to it is running, that might upset the 12v going into the radio. radio shack has filters for that.
dsurette
Ooltewah, TN
Posted: 07/23/12 12:30pm Link  |  Quote  |  Print  |  Notify Moderator
My AM reception is terrible in my C. The FM isn't so great either. Got a Sirius radio and a multi vehicle kit so I can move it between vehicles. Problem solved.
rockhillmanor
On the Road
Posted: 07/23/12 01:08pm Link  |  Quote  |  Print  |  Notify Moderator
I never get great AM reception. FM is fine but AM mostly static. Not sure if the cabover (which blocks the antenna) has anything to do with it.This is my second radio in the unit with the same problem.Any tips would be appreciated.THankstom
Are your talking about your AM radio in the dash?
Is so, look and see if your antenna is touching the cabover. Mine will touch the cabover when fully extended. I pulled it down just enough to not touch the cabover and now I have good clear AM.
"We must be willing to get rid of the life we've planned,
so as to have the life that is waiting for us".
Beverley&Ken
Tottenham,Ontario
Posted: 07/23/12 02:03pm Link  |  Quote  |  Print  |  Notify Moderator
It is probably the antenna location. The dash radio with the fender mounted (Winnebago even moved it forward on the fender infront of the cab over) does NOT get near as good reception (AM/FM) as the outside entertainment radio, with an antenna mounted on the roof of the MH. Both are cheap Magnadyne radios.
Beverley and Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
Coach-man
Posted: 07/23/12 02:59pm Link  |  Quote  |  Print  |  Notify Moderator
I have had 2 class A's and one class C before my current Class C. The previous units all had good AM reception, my current C Coachmen Prisim does not get any AM stations, it has a "window" antenna, which I attribute to the problem.The second radio in the "media" center" has no problem picking up AM, FM or sirious stations, but it has its own separate antenna!
Kemahsabe
Kemah, TX
Posted: 07/24/12 08:29am Link  |  Quote  |  Print  |  Notify Moderator
Go to a local shop that installs and services automotive sound systems. Have them diagnose the problem and recommend a solution.
crasster
Dallas
Posted: 07/24/12 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
This is exactly what I was going to say. It worked for me like a charm. I think it has to do with the antenna getting grounded by the side of the cab.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
Dakzuki
Carnation, Wa, USA
Posted: 07/24/12 10:04pm Link  |  Quote  |  Print  |  Notify Moderator
Yep. AM antenna requires a ground plane to operate properly. If the antenna is not grounded properly your reception will suffer.
2011 Itasca Navion 24J
95 Chinook Premier
 > AM Reception
